Old 09-12-2006, 02:01 PM   #1
rallyme
Member#: 70803
2004 WRX PMS
DB18G w/ METH GOODNESS
Default quick question...smc
i just wanted to make sure what i have heard on here...
is it completely fine to run a smc kit on 100% water without a tune on a 2004 wrx?
....its running on water until friday when i get tuned for meth....
rallyme is offline   Reply With Quote
Old 09-12-2006, 02:15 PM   #2
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Wouldn't it just be safer to pull the fuse till you get tuned? My spray at all. It's only a few days..
WRX-ERROR is offline   Reply With Quote
Old 09-12-2006, 02:49 PM   #3
tasq
Member#: 62362
2005 wrx
CGM
I wouldn't do it. Pull the fuse like wrx-error said.
tasq is offline   Reply With Quote
Old 09-12-2006, 02:55 PM   #4
rallyme
Member#: 70803
2004 WRX PMS
i know but the water doesnt change the afr's so why is it bad?
Old 09-12-2006, 02:57 PM   #5
jays05
Member#: 78165
05 STI 35r + e85
It will make your car slow as crap, but if that's what you want go ahead. Or just pull the fuse.
I tried this.
jays05 is offline   Reply With Quote
Old 09-12-2006, 02:57 PM   #6
tasq
Member#: 62362
2005 wrx
CGM
Sounds to me like you haven't done much research... Why would you dump water into your motor without a tune? Common sense really...
Old 09-12-2006, 02:58 PM   #7
rallyme
Member#: 70803
2004 WRX PMS
i jsut heard that people where doing it here with no problems
Old 09-12-2006, 04:01 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
What would you think if someone else typed that? People with cars do a lot of things, and they think they have no problems. This doesn't mean they had no problems even though they might not have, and imo it's not a good reason to do something(point).
It's good to know the injection system works before you get your car tuned, and that's the reason most people use for injecting without being tuned for it. Course, you can test the system without injecting stuff into the engine, and imo it can do more harm then good to inject stuff into the engine without being tuned for it. If you inject water without being tuned for it, you could end up with a good amount of water in your oil(screech, screech, plop), hydrolock(plop), misfire(silence), and you will lose power. This basically makes doing it(injecting without being tuned for it) useless unless you need to do it to prevent something bad from happening, and even then it would be wise to weigh the options and deside not to drive the car. Course that's just how I see it.......
peace
Old 09-13-2006, 11:28 AM   #9
rallyme
Member#: 70803
2004 WRX PMS
Thanks guys
injection questions..smc kit..50/50 water denatured or 50/50 water methanol...discuss mpower22 Water/Methanol Injection, Nitrous & Intercooler Cooling 28 08-26-2005 12:24 AM
quick quick question for .. yub2da Brakes, Steering & Suspension 3 08-15-2005 12:58 PM
Quick question and I need a quick reply imprezive General Community 6 12-04-2001 08:44 AM
Help, need quick answer to quick question about ezpass munkis General Forum Archive 2 09-29-2000 03:45 PM
