Old 09-12-2006, 04:14 PM   #1
Carxpressions
Member#: 54641
04 Wrx Sti
Green
Default Need Urgent Help, Sti runs horribly
We have an 04 Sti that was built for Fuzion tire (yea, the ugly green one) and anyways, they dropped it off at my work and wanted us to put a new bodykit on it, a Stoptech Brake Upgrade, Sparcos and a bunch of other little stuff. They also wanted us to get the car running right, all in about a week and a half. Anyway, the car runs horrible and i have to ship it out tomorrow morning and am looking for some suggestions.
The car has a Turbo XS FMIC and a Turbo Back exhaust on it. It had a vent to atmosphere BOV on it and we initially thought that that was most of our problem. We replaced it with a recirculating one and changed the plugs and the car is running much better, but it still likes to die sometimes around idle.
The car also has gas in it that has probably been in it for 2 months or so.
What are you guys doing when installing a FMIC and Turbo Back Exhaust to make it run correctly, or should the ECU learn it and we have a bad gas problem?
Please help.
Thanks
Carxpressions is offline   Reply With Quote
Old 09-12-2006, 04:25 PM   #2
whitesti04
Member#: 69689
04 interceptor sti
[email protected] sz55 pump gas
sounds maybe like a boost leak, or the maf on the intake might be on backwards
whitesti04 is offline   Reply With Quote
Old 09-12-2006, 05:10 PM   #3
Carxpressions
Member#: 54641
04 Wrx Sti
Green
we just unplugged the MAF and the car started idling great. Where should i go from here?
Old 09-12-2006, 05:20 PM   #4
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
The car needs to be tuned. You changed the intake Tract with the FMIC and intake. Start by pulling the codes with a scan tool. But you need to have the ecu flashed for those mods for the car to have a chance of running right. unplugging the MAF put the car in limp mode.
Clark
AZScoobie is offline   Reply With Quote
Old 09-12-2006, 05:40 PM   #5
Carxpressions
Member#: 54641
04 Wrx Sti
Green
what kind of tune would you recommend?
Old 09-12-2006, 05:43 PM   #6
sigma69pi
Member#: 55287
05 STI
I would use Cobb and find a ProTuner near you.
http://cobbtuning.com/links.html#ProTUNER
sigma69pi is offline   Reply With Quote
Old 09-12-2006, 07:52 PM   #7
antigfk
Member#: 122242
2006 WRX LTD
Make an appointment tomorrow with someone who does ECUTEK reflashes. That would probably be the fastest tuning route unless you can find a Cobb Accessport locally.
antigfk is offline   Reply With Quote
Old 09-25-2006, 05:56 PM   #8
Carxpressions
Member#: 54641
04 Wrx Sti
Green
I think we have more problems. I think it has different injectors in it. The tops are yellow, i have heard they are normally pink from the factory, and the green bar that goes across the tops of them is gone
Old 09-25-2006, 06:03 PM   #9
Freon
Member#: 88322
2009 BMW 135i
STI injectors are yellow. They are sidefeed.
Freon is offline   Reply With Quote
Old 09-25-2006, 06:05 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...wrong-0.....usdm sti injectors are side feed yellow ones
Old 09-25-2006, 06:08 PM   #11
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
OMGHi2U you need to do your homework
the usdm sti have stock yellow side feed injectors.
you definitely need to get the car tuned properly.
how far are you from boxer4racing, north carolina
or knowledge performance, atlanta georiga or
topspeed also in atlanta.
but you should be aware that elevation makes a different
when tuning the car. do not get the car tuned at a shop
that is higher in elevation than you are.
you did not mention which engine management system
currently resides in the car besides the stock ecu.
Old 09-25-2006, 06:16 PM   #12
Zumble
Member#: 34860
2005 Forester CGM
Whoa! If you unplug the maf the car should sputter and throw a CEL!
Zumble is offline   Reply With Quote
Old 09-25-2006, 11:15 PM   #13
STI_2NR
Member#: 59840
2004 WRX STi
hmmmm i bet this is why justin was posting urgent subaru help needed on kysubaruclub.com. I would highly recomend a Cobb accessport with a protune from PDX.
STI_2NR is offline   Reply With Quote
Help car running horrible ctrent86 Open Source Reflashes 6 03-02-2008 01:20 AM
Need urgent help please: removing vent screen DanZ Interior & Exterior Modification 9 06-18-2004 05:52 PM
Milwaukee - Need URGENT help!!! UncleMeat Mid West Subaru Owners Club Forum -- MWSOC 4 05-28-2004 12:43 AM
Need urgent help with swaybar install Keiho Technical Forum Archive 9 10-03-2000 02:34 PM
Need urgent help with air filter purchase MMC Bay Area Impreza Club Forum -- BAIC 4 09-20-2000 11:42 PM
