Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 09-13-2006, 11:36 AM   #1
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Default Thinking of ditching the STi fuel filter
Okay, I'm finally getting around to installing my Walbro this week. I was going to do it tonight but I was concerned over the fuel filter since my car is getting up there in miles.
After doing some searching, it appears Subaru only wants to sell you the complete fuel pump assembly for $550 and won't sell just the filter part! I don't think so.
I came across a guy that took out the filter part in the large brass/plastic thing.
Looks like this on the left:
http://i73.photobucket.com/albums/i2...4/DSC02644.jpg
And installed an 02-03 WRX filter and bracket in the engine bay.
http://forums.nasioc.com/forums/showthread.php?t=949082
Originally Posted by KEVINL
I just converted mine over to a wrx fuel filter
I removed the fuelfilter from the cartridge put it back togehter then I removed tha magnet from the pressure line and stuck the stock wrx fuel filter in its place
I dont have the part numbers but all you need is a 02-03 WRX fuel filter and the bracket.
you go from this http://www.thehaltermans.com/fuelfilter1.jpg
To this http://www.scoobymods.com/forums/att...achmentid=1151
http://www.scoobymods.com/forums/att...achmentid=2582
All you do is unsrew the fuel filter cartridge on the fuel pump assy and remove the filter element and put it back together.
this will walk you through the fuel filter for the most part.
http://www.scoobymods.com/forums/showthread.php?t=3645
Has anyone here tried this yet? Seams more logical to have a fuel filter where you can get to it. The only thing I'm worried about is finding a new fuel sock for the bottom of the fuel pump. Any ideas that would be close to the stock fuel sock?
R0DENT is offline   Reply With Quote
Old 09-13-2006, 12:41 PM   #2
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
Subscribed because I am interested as well... E85 will severely cut into the lifespan of my fuel pump/filter.
RP31 is offline   Reply With Quote
Old 09-13-2006, 12:50 PM   #3
x99percent
Member#: 27108
2004 STi
2004 A4
What's wrong with the stock one?
x99percent is offline   Reply With Quote
Old 09-13-2006, 12:52 PM   #4
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Nothing, just dirty I assume. I suppose I can clean it with carb cleaner or something and re-use it.
I just called another local dealer for the stock filter. They told me I never have to change the filter if its in the tank. And I said "So I can drive 200,000 and never have to change the filter?" and they said yes! LOL!
Old 09-13-2006, 12:59 PM   #5
x99percent
Member#: 27108
2004 STi
2004 A4
If you get a Walbro and they include the unnecessary "install kit", the kit should contain a new sock. The stocker *appears* to be nicer, though.
If the sock looks OK, I'd just re-use it.
Wow.
Old 09-13-2006, 01:09 PM   #6
Doctor Subie
Member#: 115994
2015 991 GTS
the filter in the walbro 'supposedly' doesn't filter as well as the stock.. There were a couple of posts on it before, either here or on IWSTI. I'd consider re-using the stocker, but I can't imagine Subaru doesn't sell a replacement one alone!
Doctor Subie is offline   Reply With Quote
Old 09-13-2006, 02:15 PM   #7
SinistiR
Member#: 58733
2004 STi
I removed my stock filter along time ago and just run an resuable inline filter up front. I kept the housing for the fuel filter, just pulled the element out. I kept the housing inline as an extra pulse damper, not that you need to though.
SinistiR is offline   Reply With Quote
Old 09-13-2006, 02:44 PM   #8
flycaster
Member#: 60142
2011 WRX
Grey
That's a much better solution, imo, although I'd use a replaceable unit.
flycaster is offline   Reply With Quote
Old 09-13-2006, 02:50 PM   #9
socalLGT
Member#: 89752
08 STI
I have an 05 LGT and I need to add an inline filter as well. I'm not sure if the color coding is the same, but which underhood fuel line in the feed line, and which on is the return line? On my car, there is a blue hose, a black hose and a gray hose. I know the blue one is the evap line, but between the gray one and the black one, which is the feed and which is the return? TIA.
socalLGT is offline   Reply With Quote
Old 09-13-2006, 03:12 PM   #10
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
FXT Forester fuel filter is the same as the STI. Its listed as a separate item
Part #4207FE020
Wombat North is offline   Reply With Quote
Old 09-13-2006, 03:17 PM   #11
SinistiR
Member#: 58733
2004 STi
The black hose is the feed to the fuel rails.
Old 09-14-2006, 01:46 AM   #12
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Part #4207FE020
Great info! Funny how they list it for that car but not the STi...
I'll have to call the dealer just to see how much they want for it.
I just took the filter out completely and used some FI hose. Works great! No cutting!
I just didn't see the need for that filter bulb if there's no filter inside.
Installing WRX or aftermarket filter in the front tomorrow.
Old 09-14-2006, 11:00 AM   #13
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Part #4207FE020
Its actually 42072 FE020. Dealer wanted $88! Think I'll stick with the $15 2002 WRX filter.
Old 01-25-2007, 11:18 PM   #14
dan2304k
Member#: 36943
Here's the STI fuel filter part number 42072FE020
Last edited by dan2304k; 01-26-2007 at 02:43 PM. Reason: Fixed the part number because i'm an idiot.
dan2304k is offline   Reply With Quote
Old 01-26-2007, 11:37 AM   #15
R4ND0M_AX3
Member#: 67483
2005 WRX STi
fixed
R4ND0M_AX3 is offline   Reply With Quote
Old 02-27-2009, 07:53 PM   #16
C89ZX7R
Member#: 119154
2004 White
STi
Any updates to this? Yes I know its a old thread, but does anyone know the flow difference between the wrx and sti filter?
C89ZX7R is offline   Reply With Quote
Old 02-27-2009, 08:04 PM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
irrelevant
Old 02-28-2009, 11:53 AM   #18
2001stook
Member#: 44366
'04 STi
JBP
I am doing this mod to my STi in the next week or two. Just waiting on the arrival of a WRX fuel filter mount. Any impact to running both the WRX filter in the engine bay at the same time as I am running the STi in-tank filter. I have quite a bit of work to be done on the car prior to my tune and just trying to knock off some of the low hanging fruit since I will need to get tuned right after the walbro install (I think). If there is any concern on this one, I will just do the engine bay filter right after the Walbro fuel pump install. The only issue I could foresee is a fuel pressure reduction from having the extra flow restriction in the fuel line from a second filter. Any opinions one way or the other?
2001stook is offline   Reply With Quote
Old 09-17-2009, 11:27 AM   #19
Daluv
Member#: 159325
anyone running the wrx fuel filter? I am thinking of ditching that damm intank fuel filter as well...
Daluv is offline   Reply With Quote
Old 09-18-2009, 06:50 PM   #20
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
When they quoted for $550, was that for the fuel level sensor also? and they do sell it separately because i just got one a few months ago
Boxer112 is offline   Reply With Quote
Old 09-18-2009, 06:59 PM   #21
oman350
Member#: 180886
2006 Sti
06 Stage 2 SGM STi
oman350 is offline   Reply With Quote
Old 07-24-2010, 09:51 AM   #22
vapore0n
Member#: 21356
2017 Toyota Corolla
Limited, LBP, ABP, TTD, I
Bump. Anyone tried this yet?
Isn't there going to be consequences to moving the filter to the engine bay? I'm thinking lower pressure after the filter, or the pump working harder to keep the pressure.
But them in not a ME.
vapore0n is offline   Reply With Quote
Old 07-24-2010, 01:01 PM   #23
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
I had no prob going to my local dealer and get just the filter from Subaru. Don't know what you guys are talking about. I have an extra sti filter if u want to buy it?
BlackFighter is offline   Reply With Quote
Old 07-24-2010, 01:25 PM   #24
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
go to this website--APEUSA.COM--they are one of the largest walbro dealers in the country and you can buy anything for installation separately from them including the special hose for in tank setups,different size socks,etc.etc..
john 1badSTI is offline   Reply With Quote
Old 07-25-2010, 01:57 PM   #25
vapore0n
Member#: 21356
2017 Toyota Corolla
I got it online. Just was curious. It would be very convenient to have it up in the engine bay too.
thinking of trading the STi for a Spec B kanye Legacy Forum 14 11-19-2009 04:26 PM
Thinking of joining the STi club. Panda Lover Newbies & FAQs 18 08-25-2009 05:50 AM
Thinking of buying the STi License Plate Delete Dragonbreak Interior & Exterior Modification 5 01-17-2008 12:49 AM
Thinking of trading the STi for an Evo Dynasty336 General Community 125 11-16-2006 03:29 PM
Any input/suggestions - Tooling with the idea of ditching the Saab for an 05/06 STi Goldie Tri-State Area Forum 8 11-21-2005 02:01 PM
