Old 09-15-2006, 02:24 PM   #1
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
Default Do I NEED to have the wheels aligned?
I just had the fuel tank pressure sensor replaced. CEL said P0457 (gas cap) but the cap was fine.
It looks like the rear sub-frame had to be dropped to get at the sensor on the tank. Do I need to have the wheels aligned again?
Columbo is offline   Reply With Quote
Old 09-15-2006, 03:22 PM   #2
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I noticed the other day that pep-boys will check the alignment for free. Do that at least.
jamal is offline   Reply With Quote
Old 09-15-2006, 03:44 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
It really depends - did the shop mark the toe bolts if they detached them from the rear subframe. Also, did they get the rear subframe back in the exact same spot? Since the rear subframe is a "floating" type that part can be a bit difficult, and will affect alignment a bit. In fact, it's been known to float so much that alignment can dynamically change up to a couple of degrees in the rear during heavy loading like at an autocross. This is why whiteline has the subframe lock bolts - they keep the rear subframe from floating.
In the end, if you can get it checked for cheap (or free as in the post above) then it certainly can't hurt.
Old 09-15-2006, 04:21 PM   #4
WRX11
Member#: 26638
Is this on all Subaru models or just the Impreza chassis?
WRX11 is offline   Reply With Quote
Old 09-15-2006, 05:34 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
I know on the imprezas and the foresters. I know the STi, and the FXT, plus maybe (I need confirmation) 06 have metal bushings for the subframe. i'm not sure on the legacy. I'd need to check.
What do I need to get 18x9 wheels to fit on an 05 wagon? ever12 Newbies & FAQs 18 04-15-2009 08:14 AM
do i need to have my fenders rolled? Cusson Tire & Wheel 1 12-21-2005 07:03 PM
Do we need to have enemies? mr_disco Off-Topic 8 10-09-2003 04:52 PM
Do I need to have flywheel machined when new clutch is installed ? il96 Transmission (AT/MT) & Driveline 9 09-26-2002 05:23 PM
Accident!!Do I need to take the turbo off before taking the car to the repair shop? Andrew Bay Area Impreza Club Forum -- BAIC 37 08-01-2001 05:20 PM
