Old 11-01-2001, 06:21 AM   #1
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
Default Convert 99 to 00?
I found a 2000 RS wrecked at a local yard. Beyond repair, but I could get the LSD and axels, MAP and ECU. I know the LSD would work, but what about the ECU and MAP? Sounds logical to me.
If anyone knows, you could really help me out. I can take my search from just the 00 and newer RS's, to any with the Phase II. I'm trying to have some $$ left over to do some mods, and still not loose my arse when I trade it in on the STi.
Streetman is offline   Reply With Quote
Old 11-01-2001, 09:38 AM   #2
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
These would work. Don't how easy/hard it'd be to install set-up the MAP.. ECU pinouts are different too so don't know if wiring would be a direct swap.. I doubt it.
Jon
omahasubaru is offline   Reply With Quote
Old 11-01-2001, 11:35 AM   #3
bensonwrx
Member#: 6904
AWD R35, XE30, V37
BO, AS, MW
Lucky you How much did you pay for the Axles and LSD? Hmmm, if you see another set be sure to lemme know :P
-Alan (Another MY98 Owner)
bensonwrx is offline   Reply With Quote
Old 11-01-2001, 06:49 PM   #4
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
Haven't bought anything yet. I know the axels will work. I'll let you know how much they want for them.
Does anyone know if the MAP and ECU will work, even if I have to splice a few wires?
Old 11-01-2001, 07:02 PM   #5
Iowannaski
Member#: 8268
00 GM67
BRP me ASAP
Yes - if you're willing to be flexible about the meaning of "a few"
Iowannaski is offline   Reply With Quote
Old 11-01-2001, 07:13 PM   #6
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
No problem. Is there a scamatic (sp?) somewhere that shows both? Or, is there an easier way to accomplish this?
Josh
Old 11-01-2001, 10:10 PM   #7
fabulous12
Member#: 6831
98 impreza 2.5RS
black
hmm interesting idea about switching from the MAF to a MAP... anyone know how much it would be to buy an MAP and install it?
fabulous12 is offline   Reply With Quote
Old 11-01-2001, 10:39 PM   #8
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
I had planned on swapping parts witht the junkyard, as they would probably have more of a market for a MAF (as they blow all the time), than the MAP. I don't think the 99 ECU would work with the MAP though. It'd be sweet as hell if it did, but it's highly unlikely.
Old 11-02-2001, 01:46 AM   #9
BG5
Member#: 695
The MY00 has a AF sensor instead of a front oxygen sensor in previous years so the ECU won't be a direct plugin
BG5 is offline   Reply With Quote
converting WRX to 99.9% ethanol fuel subypal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-25-2010 11:00 AM
Exhaust pop, 98-99 vs 00 and up Reciprocity Normally Aspirated Powertrain 20 07-25-2002 12:55 AM
Difference Tween 99 & 00-01 Rs slowme Normally Aspirated Powertrain 8 12-15-2001 01:35 AM
99 or 00 RS's for sale in the mid-west? Frey Bone Mid West Subaru Owners Club Forum -- MWSOC 3 06-13-2001 06:25 PM
99 vs. 00 John2.5RS Normally Aspirated Powertrain 10 01-16-2001 11:10 PM
