Old 11-01-2001, 07:25 AM   #1
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Default ECU reset w/o taking the battery out.
Does anyone know how to reset the ECU without taking the - terminal out? I noticed a fuse that says "Unit Backup" in the fuse box next to the engine. If I pull that fuse, would it do the ECU reset? This is for a MY01 RS.
Thanks.
tmat3 is offline   Reply With Quote
Old 11-01-2001, 07:53 AM   #2
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
There is a way to do it. Somebody posted how a LONG time ago. There are some jumper wires somewhere under the dash that reset the ECU......
--Roy
LUME is offline   Reply With Quote
Old 11-01-2001, 10:01 AM   #3
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
you dont NEED to reset the battery of a 2001.
the 00's and newer have a learning ECU...
but if it makes you more comfortable...
just disconnect the battery, no need to remove it entirely...
let it sit for a 1/2 hour or so...
reconnect, restart car...
let it idle to temp, do not touch the throttle.
that's basically it...
j.
www.subiegal.com
Old 11-01-2001, 10:10 AM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
The reason for the reset is because I get a CE light every once a while. So, I need to clear the code somehow. Everytime I disconnect the battery, I have to set the clock, radio presets and settings etc etc. I guess the only way to do this effectively is to disconnect the battery?
Old 11-01-2001, 10:20 AM   #5
Jademonkey
Member#: 9213
2000 RS
Red
Take your ride into the dealership...maybe you have a bad o2 sensor (there was a recall on our cars)
-JM
Jademonkey is offline   Reply With Quote
Old 11-01-2001, 10:57 AM   #6
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
actually... you could probably just pop the harness off the ECU for a bit... that'd clear the memory of the ECU, but the radio and all should still be in tact... never tried it tho
mrbell is offline   Reply With Quote
Old 11-01-2001, 12:15 PM   #7
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I know the exact cause of the CE light. It's PO 0420, catalyst isn't working efficient enough, appearently the exhaust temp is too low for the catalytic converter. I've been getting this same CE code for past 2 months. CE light comes back a few days later or about 500 miles later. Today, I think I fixed the problem by replacing an old exhaust gasket with a new one because the old one was leaking and about to break apart. Hopefully, the CE light won't come back.
I thought about taking the harness out of the ECU. But, when I have to reconnect the harness, I am kind of of scared about the voltage surge that may get created at the harness, and the surge may go straight to the ECU.
I guess I just have to do the old fashioned way, cut the main source.
Old 11-01-2001, 01:14 PM   #8
RacerinLSL
Member#: 1174
2011 Subaru WRX
tmat,
Your CE light WILL NOT keep coming on if you fix the problem. You don't have to clear the code to keep it from coming back. Once the problem is fixed, you shouldn't get a CE light any more. If there is still a problem, resetting the ecu isn't going to do anything for you except erase the code, but you'll still throw ce lights.
Chad
RacerinLSL is offline   Reply With Quote
Old 11-01-2001, 09:22 PM   #9
Silverscooby27
Member#: 9124
2014 335i xDrive
So how about us poor MAF MY99 owners? Is there a fuse we can pull to reset the ECU instead of pulling the negative terminal? Thanks!!
Silverscooby27 is offline   Reply With Quote
Old 11-02-2001, 04:24 PM   #10
Daveish
Member#: 8935
2001 Impreza 2.5RS
On my old 99' Legacy outback, I used to be able to pull SBF #2 (the 2nd green fuse in the box), which would cut power to the ECU.
At least I think it was #2 It's been awhile since I've had the outback. I miss that car
Dave
Daveish is offline   Reply With Quote
how the f to take the axles out? 05 sti xxscaxx Transmission (AT/MT) & Driveline 6 09-24-2008 10:41 AM
you can take the boy out of the gettho but can't take the gettho out of the boy VSM EXtasy Off-Topic 12 06-26-2004 03:19 PM
ECU reset, doesnt start on the first try? moogooob Normally Aspirated Powertrain 4 08-21-2002 01:45 AM
Taking the tranny out nekard Transmission (AT/MT) & Driveline 7 06-14-2002 03:26 AM
('93-'01) If I do an ECU reset will it erase the datalogging? aarneson Impreza Forum 7 06-26-2001 10:47 PM
