Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 11-01-2001, 07:28 AM   #1
OBSS
Member#: 1421
1997 OBSuperSport
Arcadia Green
Default High pitched squeek, frnt drv side, only when turning right?
High pitched squeek, front drivers side, only when turning right?
Even when shimmying the wheel quickly back and forth. Again, only when moving the car to the right.
Stops when applying the brakes, not just touching the brakes, but returns when a slow speed is reached.
Anybody...........Anybody..............Garrett?... ............ McDade?................
Adam < crosses fingers and prays for brakes
MY97OBSS
OBSS is offline   Reply With Quote
Old 11-01-2001, 07:33 AM   #2
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Did you check your lugnuts?
Could be your brakes.... could be your *gasp* wheel bearing...
LUME is offline   Reply With Quote
Old 11-01-2001, 07:41 AM   #3
akuhner
Member#: 462
2000 Impreza 2.5 RS
SCCA Rally Cross Car
Adam - Please get in touch with me ASAP! Your email isn't working!
Alex
akuhner is offline   Reply With Quote
Old 11-01-2001, 08:00 AM   #4
DonA
Member#: 355
08' VW Touareg II
Alaska Grey
Sounds like the worn brake indicators check brakes. It may just be worn pads. I just replaced the pads on my RS and found extremly uneven wear. one side of the pad was only half worn the other side was down to the metal
DonA is offline   Reply With Quote
Old 11-01-2001, 08:09 AM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
Either that or a rock stuck against the rotor..
sidewayz is offline   Reply With Quote
Old 11-01-2001, 08:46 AM   #6
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Your trunkmonkey has escaped and is hiding inside your wheel!
Samirr76 is offline   Reply With Quote
Old 11-01-2001, 10:06 AM   #7
WRC 3X1
Member#: 340
2006 Charger SRT-8
Inferno Red
wheel bearing?
WRC 3X1 is offline   Reply With Quote
Old 11-01-2001, 08:53 PM   #8
Booster
Member#: 8565
2006 Legacy H-6
Subaru#4 yrs 88,93,02,06
Sidewayz I had that problem too.
OBSS check the splash guards that protect the rotor, I got a rock with tar on it stuck to that shield and it made a noise sometimes.
Take the wheel off if you can and check that area, thats most likely the problem.
Garrett
Booster is offline   Reply With Quote
Old 11-01-2001, 09:25 PM   #9
Silverscooby27
Member#: 9124
2014 335i xDrive
I had that problem once, it was a rock between the rotor and the shield. I was in the middle of nowhere with no tools, so a little aggressive driving did the trick, but my car sounded like a friggin hooptie for about 20 minutes.
Silverscooby27 is offline   Reply With Quote
Old 11-02-2001, 07:24 PM   #10
Booster
Member#: 8565
2006 Legacy H-6
OBSS's car is a friggin hooptie anyway so he dont got to worrie.
Garrett
Old 11-02-2001, 07:35 PM   #11
OBSS
Member#: 1421
1997 OBSuperSport
Arcadia Green
It's double friggin' hooptieQUA!
The good ole volume knob really cuts down on the noise
Thanks for all of the tips, tried them all except replace the brake pads.
Took off the wheel, no rocks/debris in the brake sheild.
Lugs nuts tight, not them.
I did a search on wheel bearings, they make a hum, not a squeek.
Anybody ever get a squeal/squeek from needing wheel bearings?
It's gotta be the brakes!
Adam
MY97OBSS
Old 11-02-2001, 07:41 PM   #12
Booster
Member#: 8565
2006 Legacy H-6
When I get brakes that squeak, I remove the caliper and pads and remove the slides that the pads move on, clean them with a
wire brush and put some special lube on them then put it all back together. Might not work for you. Stop by my job we can check it out.
Garrett
Old 11-02-2001, 10:02 PM   #13
SubyObsessive
Member#: 8905
13 WRX
wheel alignment, eh?
your tires may have worn unevenly, my dad's RS had the same problem on his rear right tire. He had the RE-92's then put on new tires and got an alignment and the sound went away...
it was odd though, he would turn left and the sound would go away when there was no pressure on the wheel
SubyObsessive is offline   Reply With Quote
high pitched squeek nhmtns Brakes, Steering & Suspension 1 07-31-2007 05:15 PM
When turning left, rear right grings, when turning right, rear left grinds!! IIdiceII Brakes, Steering & Suspension 6 10-24-2006 04:33 PM
Rear noise when turning right. reznob Brakes, Steering & Suspension 3 12-05-2004 11:05 AM
cracking/shhhhing from front of car when turning right and brakes are disengaged. knertified Service & Maintenance 2 09-04-2004 01:51 AM
AT Fluid Temp CEL only when turning on headlights MY99 2.5GT Service & Maintenance 1 04-14-2003 10:54 AM
