Old 11-01-2001, 08:51 AM   #1
AltF8
Member#: 9376
2002 WRX Sedan 5MT
World Rally Blue Pearl
Default Turbo Timer + Security System = Problems?
I did a search and found no topics on this.
Has anyone had any experiences (good or bad) with using a turbo timer on a car with the SOA security system?
The reason I ask is that we all know the H4 idle is a bit...rough. I'm wondering if anyone knows if I'll have problems with the idle setting off the alarm, or if I'll even be able to arm the system while the car is idling.
AltF8 is offline   Reply With Quote
Old 11-01-2001, 09:41 AM   #2
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Ryan Cavalier from irvine subaru/SPI motorsports is selling harnesses to work with any TT and the factory alarm...look in Vendor Classifieds...otherwise you could do the wire snip method..try a search
STiShawn is offline   Reply With Quote
Old 11-01-2001, 10:00 AM   #3
AltF8
Member#: 9376
2002 WRX Sedan 5MT
So...the $25 wiring harness I ordered will not work with the factory alarm?
Old 11-01-2001, 12:03 PM   #4
Jewbaru
Member#: 1994
2013 Impreza WRX
Also check the FACTORY FORCED INDUCTION forum, the was posted there, and there is a "fix".
Jewbaru is offline   Reply With Quote
Old 11-01-2001, 12:11 PM   #5
AltF8
Member#: 9376
2002 WRX Sedan 5MT
Aww...crap. I didn't realize I was in the wrong forum.
Old 11-01-2001, 12:33 PM   #6
Jewbaru
Member#: 1994
2013 Impreza WRX
No sweat
Old 11-01-2001, 12:36 PM   #7
AltF8
Member#: 9376
2002 WRX Sedan 5MT
I did find a few of those posts, but they don't really answer the problem of the car's idle possibly setting off the alarm.
Oh well...guess I'll find out!
Old 11-01-2001, 01:14 PM   #8
Jewbaru
Member#: 1994
2013 Impreza WRX
lol... the Shock sensor works by "feeling" vibration against the chassis. Vibrations that aren't "thumping" the chassis shouldn't set it off. If it does, turn the shock sensor down. You could also wire up a relay that will disable the shock sensor untill the car turns off.
Subaru Australia Recalling 2002-2005 WRX and STI For Security System Problems Jon [in CT] News & Rumors 0 06-09-2006 03:39 PM
Security System Problem macblazer Car Audio, Video & Security 3 08-23-2005 10:28 PM
security system problem. flabele Car Audio, Video & Security 4 08-13-2005 11:17 AM
alarm/security system problems! parklax Legacy Forum 0 05-26-2003 04:08 PM
