#1 |
Member#: 124744
Vehicle:2002 FOZ 5MT Blue |
#2 |
Member#: 120473
Vehicle:2006 Baja Sport Atlantic Blue Pearl |
Nice...How did you do that?
#3 |
Member#: 124744
the grill is rain gutter cover from home depot (zinc coated) and using fiberglass-resin secured plastic-ege molding to the back of the grill and then after predrilling i used wood screws. i'll post pics of the back soon...tim
#4 |
Member#: 106056
Vehicle:2005 Baja Sport Obsidian over Onyx |
Looks intriguing -- could you take a few (smaller size would be great!) pix from further away... it's kinda hard to tell what the end result would actually look like.
#5 |
Member#: 98395
yes, +1 for pics from further away. i like what i see so far though!
#6 |
Member#: 121071
SWIC
Vehicle:2004 Baja STi TeamJDMFresh.com/CSJ |
that grill is crazy well done and it makes me happy that other people enjoy there bajas as much as i do...
#7 |
Member#: 73808
Vehicle:2003 Baja Silver |
Thats great that you did that. I was thinking of something along those lines myself. I never considered rain gutter screens. Good call.
#8 |
Member#: 124744
here are more pics of the mod. took about 90 minutes...and i love my baja...tim
#9 |
Member#: 120473
I was wondering what you stuck onto the bottom of the grill to put the screws in. I also noticed that there are screws in the center. What are they attaching to?
I tried to put plastic gutter grill on mine today but couldn't get the grill off. After removing all the bolts, it felt like it was catching on something. I didn't want to pull any harder because it felt like something was going to crack if I did. Is there a trick to removing it? So I ended up just duct taping around the back of the grill after trimming it. It looks good from up front. Just like in your pic, just all black. It's just temporary until I figure out how to put it on in a more permanent way. Oh well, at least it'll keep bugs and rocks out of my radiator. |
#10 |
Member#: 120473
Oops, I meant to ask how did you attach the corner molding to the grill? Did you glue it? I couldn't see any screws or bolts in the pic.
#11 |
Member#: 124744
While trying to remove the grill the studs will rub against the inside edges of the holes, sounding like it’s going to brake. It will not, just wiggle and pry at the same time, it will come off (it may suddenly release so be careful not to drop it).
The material I used all came from Home Depot. The zinc coated rain gutter screen and the plastic angle (designed to protect interior wall corners) I trimmed one leg of the plastic angles making an “L” (leave enough of a leg for screws to grab) I used fiberglass resin (be sure the resin is cured before trying to attach grill halves).and after drilling 1/4” holes for the resin to ooze through I prepared both surfaces to be joined with a small grinder (resin will not hold smooth plastic). I applied the plastic “L” to both the bottom and the middle section of the factory grill (that is what the screws in the center are holding on to). I trimmed the screen with tin snips and bent the screen into an “L” at the top, about ¾” to keep it rigid. I attached the gill using #10 x 1 ¼” wood screws, but almost anything will work. While holding the grill in place pre-drill a 1/8” holes so the plastic does not crack and tighten the screws only enough to secure the grill (over tightening will cause the grill to distort). I’ve included pics and a link to a grill I did for a friend. www.legacygt.com/forums/showthread.php?t=42973 ![]() ![]() ![]() ![]() ![]() ![]() My wife's grill is next ![]() |
#12 |
Member#: 4835
Vehicle:2003 Baja 5MT Yellow w/ 220,000 miles |
That is so ghetto 1991. Heh.
#13 |
Member#: 120473
Thanks! Now I'll plan that to be my weekend project.
#14 |
Member#: 124744
post pics.
| Thread Tools | |
| Display Modes | |
| wtb: 06 wrx headlights with brackets and 06 wrx grill | parichay | Private 'Wanted' Classifieds | 4 | 10-01-2008 04:16 PM |
| Odd Baja Grill on Ebay | pcmdude | Baja Forum | 14 | 04-02-2008 05:29 PM |
| Looking to buy an 06 Baja | mustangsmoker | Southern California Impreza Club Forum -- SCIC | 12 | 12-20-2006 06:43 PM |
| New 06 Baja Turbo | woettinger | Baja Forum | 16 | 10-16-2006 01:07 PM |
| Do the 06 Sedan grills fit an 06 Wagon? | Alaskan_awd | Interior & Exterior Modification | 6 | 08-06-2006 05:57 PM |
