Old 11-01-2001, 12:10 PM   #1
sti2_5rs
Member#: 1578
2000 Impreza 2.5RS
Default GC8 Morettes HID install problem! Need Help
Ok here's the list of questions!
1, For you all that have GC8 morettes with HID, how do you wire your system? Now, i only have the low(HID) and when i hit high or fog there is nothing.
Eventually, i want to do the wiring mod that my low(HID) will stay on when i hit the high. Perhaps, my fog will be on with the high too!
2, when I turn on the engine, and start to drive the HID came on itself. I can't turn it off, but if i stop my car (engine's running) i can turn it off.
So, what's the problem? Why can't i turn off the HID when i am driving?
Is it anything about the DRL?
3, How do you adjust your system? Is you bulbs come with a steel plate for better focus? I got flashed and some 18 wheelers tailgate me on the hwy last nite, scary:monkey:
4, I notice that my highbeam light on the dash was on even it wasn't.
The light on the fog button is gone, and the green light on the A/C is gone too, why?
Any suggestions or ideas will be greatly appreciated
Attn: TaiChic - if you are reading this, help me pls
I know you know this kind of stuff pretty well! BTW, have you figure out the HIGH stay on mod on the morettes yet?
THANKS ALL FOR READING THIS LONG POST AND SORRY FOR THE CAP
sti2_5rs is offline   Reply With Quote
Old 11-01-2001, 12:36 PM   #2
sanders
Member#: 187
Jade 05 b0x
Black Cherry Pearl
i installed/wired mine up according to North Ursalia's directions... then i put in the HIDs and everything is fine...
i adjusted mine by spinning the white notch behind the headlight...
i can keep the lows and highs on at the same time with the fog lights by positioning the lever halfway between highs and lows... [i did it on accident at first ] really bright btw! especially with the HIDs!
--chad--rs.t
www.jadecrew.com
sanders is offline   Reply With Quote
Old 11-01-2001, 05:46 PM   #3
sti2_5rs
Member#: 1578
2000 Impreza 2.5RS
ttt
Old 11-02-2001, 12:14 AM   #4
TaiChih
Member#: 3467
1998 Dinan3
Bleck
I have everything in my head, but won't be able to put it into practical application till I get my car back. Sanders, I'm trying to bypass that whole relay thing for the highs/lows, so you don't have to try to keep the stalk halfway.
TaiChih is offline   Reply With Quote
Old 11-02-2001, 12:38 AM   #5
sti2_5rs
Member#: 1578
2000 Impreza 2.5RS
But, how do you wire the high's? and do you have problem with your fog?
I don't have highs and fogs for now! my wiring must be wrong.
Old 11-02-2001, 04:01 PM   #6
sti2_5rs
Member#: 1578
2000 Impreza 2.5RS
bump bump!
Old 11-02-2001, 04:11 PM   #7
VanillaEps
Member#: 8271
2009 Si
Excuse my ignorance but are HID's the exact same or close to Xenons
VanillaEps is offline   Reply With Quote
Old 11-02-2001, 04:49 PM   #8
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Lightbulb FYI
DRL acts on the e-brake, so with e-brake down, your HID will come up. I would love to hack the DRL wiring so that it will drive the inner pair, but apparently it's complex enough that no one has messed with it.
kgb is offline   Reply With Quote
morette hid install pics help plz? XavierWRX Electrical & Lighting 0 03-28-2008 09:58 AM
HID installation problem, PLEASE HELP jcramer425 Electrical & Lighting 5 10-19-2007 07:11 PM
HID problem need help TeinSti Electrical & Lighting 4 10-26-2004 11:57 AM
morette HID install question bentshoe Interior & Exterior Modification 18 10-10-2002 04:32 PM
Coilover installation problem.. need help BlueWRX Brakes, Steering & Suspension 1 02-10-2002 06:16 PM
Message Board Statistics All times are GMT -4. The time now is 05:34 AM.
