Welcome to the North American Subaru Impreza Owners Club Thursday September 2, 2010
Old 09-16-2006, 09:06 AM   #1
Element Tuning
Member#: 54918
Default Element Tuning Hydramist Official Q&A
The Element Hydramist was developed from the beginning to be the ultimate water/methanol injection with uncompromised performance, control, and safety. The Hydramist is a fully integrated water/methanol injection solution controlled via the Hydra EMS. This system allows full 3D mapping of water flow based on load and rpm, automatic map switching, and unparalleled protection never seen before in any water/methanol injection system. When we first set out to develop a water/methanol injection system we discovered very quickly the limitations of most universal systems in that they rarely offered precise control over the injection or the failsafe mechanisms were insufficient at protecting the engine when failure occurred. To help develop a superior system for the Hydra EMS Element Tuning worked with the industry leader in water/methanol injection systems, Aquamist.
I'll continued to add to this first post as time permits.
Here is the Hydramist Installation Guide:
http://www.elementtuning.com/Hydrami...amistguide.htm
Thanks,
Phil
Last edited by Element Tuning; 11-30-2006 at 02:14 PM. Reason: Edit installation guide link
Element Tuning is offline   Reply With Quote
Old 09-16-2006, 09:09 AM   #2
Element Tuning
Member#: 54918
Default Setting Up Your Element Hydra EMS for Hydramist Tuning
Assign 3D PWM Map 11 as your Hydramist HSV map. This map is load vs. RPM and the values denote duty cycle of the HSV for a given boost and rpm. The load and rpm sites are 0% to 100% and signify the minimum and maximum range in your fuel map. So if the greatest boost level in your fuel and spark maps are 31 PSI then the 100% load site = 31 psi. Element Tuning customers can be provided with this map.
Caution!
When a boost and rpm level is reached in this map and the HSV has a duty cycle higher than 10% this will automatically activate the Hydramist pump. If within 2 seconds the Hydramist Water Flow sensor does not register water flow on the Hydramist DDS3 gauge the system will automatically revert back to the regular fuel and spark maps in the Hydra EMS.
While the Hydramist is active fueling is controlled by the Fuel Auxiliary Trim Map. This map is a function of the main fuel map. At the desired boost and rpm point you will use this map to subtract fuel from your main fuel map. Element Tuning customers can be provided with this map.
Caution!
It's important to reduce fuel in this map only when water flow is realized. So if your Hydramist turns on at 10 psi do not remove fuel until after 10 psi. This map shows 2 degrees of timing added into the idle areas. This was used just for testing to ensure the map switching operation was functional.
While the Hydramist is active ignition timing is controlled by the Spark Auxiliary Trim Map. This map is a function of the main spark map. At the desired boost and rpm point you will use this map to add ignition timing to your main spark map. Element Tuning customers can be provided with this map.
Caution!
It's important to add ignition timing into this map only when water flow is realized. So if your Hydramist turns on at 10 psi do not add ignition timing until after 10 psi. This map shows 2 degrees of timing added into the idle areas. This was used just for testing to ensure the map switching operation was functional.
To activate your Hydramist system you must press (red) the "on" button. When "on" the Hydramist is active and your Auxiliary Maps are enabled. If within 2 seconds of your HSV injecting water flow is not realized then the Hydra will revert to the standard fuel and spark maps. When the Hydramist DDS3 Diplay Gauge is "off" the Hydra reverts to the standard fuel and spark maps.
W.Injection = Display's when system is on
Water Level = Illuminates when water level is low. Pump will be turned off
Flow = Shows flow from water flow sensor
B = Illuminates when Hydra Auxiliary Maps are enabled
SC = Adjusts the range of flow display
WL = Water flow low fault
WH = Water flow high fault
Thanks,
Phil
Old 09-16-2006, 09:32 AM   #3
ejh25
Member#: 65267
Phil,
I'm mounting my Jazz fuel cell in the upper passenger corner as high as possible. Should I hold it down with some straps? Anything else better suited?
The oultet of the pump has to be below the outlet of the water tank, correct?
Thanks,
Eric
ejh25 is offline   Reply With Quote
Old 09-16-2006, 09:51 AM   #4
Element Tuning
Member#: 54918
Yes you will need to secure that tank well because once it has a gallon of fluid it will be heavy. You should mount the pump below or inline with the tank's outlet for optimal performance and to reduce the chances of sucking air into the pump.
Thanks,
Phil
Old 09-16-2006, 12:05 PM   #5
keaniegenie
Member#: 94494
2005 Element 92x
How big is the gauge that comes with this kit?
keaniegenie is offline   Reply With Quote
Old 09-16-2006, 12:30 PM   #6
THE-95-STi
Member#: 113734
05Le gacy, RHD sold!
PSM-04-STi 500+AWHP Sold!
Originally Posted by Element Tuning View Post
The gauge is a standard 52 mm.
Thanks,
Phil
here ya go
also phil what kind of #'s are you seeing with your almost stock 06 STi+hydra+hydramist??
THE-95-STi is offline   Reply With Quote
Old 09-16-2006, 04:34 PM   #7
ejh25
Member#: 65267
With regards to the fuel level sensor, the hole that needs to be drilled is 22mm, correct?
Will a 7/8" hole saw be sufficient for that or do I need a 22mm bit?
Thanks,
Eric
Old 09-16-2006, 05:10 PM   #8
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
The hole size should 22mm +/- 0.5mm.
3/4"(19.05mm) is a bit on the small side. You can however use a taped reamer to enlarge it. Suggest using a hand reamer or a machine reamer at a slow speed.
Please ensure finished hole is burred free.
Aquamist is offline   Reply With Quote
Old 09-17-2006, 09:28 AM   #9
ejh25
Member#: 65267
Richard,
Thanks....I will ensure that the hole is burr free. I could use a dremel as a reamer, correct?
Your saying 3/4" is too small but I could ream it out?
Is a 7/8" hole too big?
7/8" = .875"
22mm = .866"
22.5mm = .886"
Shouldn't the 7/8" hole work? Should I use a drill bit instead of a hole saw?
Thanks,
Eric
Old 09-17-2006, 09:32 AM   #10
ejh25
Member#: 65267
Thanks,
Phil
Phil or Richard,
How did you secure your tank Jazz fuel cell on your previous car?
I was thinnking that I would create a base for the fuel cell to elevate it off the floor of the trunk by about 4 inches so that it is slightly above the outlet of the pump. Then I was going to use straps to secure it in place. I am waiting on a GT-Spec trunk cage....that will make it easier to strap it down.
One Q on the pump mounting (and this may be in the instructions but I want to clarify):
Should the outlet side of the pump be facing upwards or downwards when mounted on its side to the passenger rear fender well?
Thanks for the help!
- Eric
Old 09-17-2006, 12:07 PM   #11
Element Tuning
Member#: 54918
I thought I had pictures but I cannot locate them. The fuel cell can be mounted with 2 aluminum straps. We used approx 3mm thick aluminum strap bent around the fuel cell but left extra on both ends so they joined together creating a tab. We drilled through these tabs and ran bolts through the sheet metal in the trunk. Remove the carpeting behind the fender well and it will make sense. You will also need to secure the bottom of the tank for extra support.
looks like this from top. The tab will be drilled and bolted to the sheet metal.
____l
____l
On the pump question it is in the instructions but always put the inlet at the bottom, therefore the outlet on top when mounting horizontally. If mounting veritcally both will be at the bottom.
Thanks,
Phil
Old 09-17-2006, 03:16 PM   #12
ejh25
Member#: 65267
____l
____l
Where did you find the aluminum straps. The people at Home Depot had no idea what I was talking about. I bought a roll of 6"x10' aluminum which is roughly 3mm thick. I can cut it into strips. Will that work? I also have gigantic zip ties that could secure it.
Thanks,
Eric
Old 09-17-2006, 05:47 PM   #13
Element Tuning
Member#: 54918
Eric,
I have seen the aluminum strapping at both Home Depot and Lowes. It's usually with the C channels, steel threaded rods, aluminum rods, steel strips, etc. If it's flexible enough to be in a roll that's not going to even hold a quart. LOL! The aluminum isthick and tough to bend. It's just like the bracket your Hydra comes with.
Go back to Lowes.
Thanks,
Phil
Old 09-17-2006, 09:14 PM   #14
ejh25
Member#: 65267
Eric,
Go back to Lowes.
Thanks,
Phil
Phil,
Some pics would be fantastic...
Help me explain exactly what I'm looking for to someone at Home Depot or Lowes.
I saw aluminum bars that were 4' long, flat and maybe a few mils thick. They seemed like they would be extremely difficult to bend but if that's what I'm looking for then I can handle that.
Thanks,
Eric
Old 09-17-2006, 09:26 PM   #15
ejh25
Member#: 65267
Richard,
I ended up using a 3/4" drill bit. That was actually plenty big. I used a dremel to smooth things out and then some coarse sandpaper and then some fine sandpaper to ensure that there were no burrs.
Thanks,
Eric
Old 09-18-2006, 05:22 AM   #16
Aquamist
NASIOC Manufacturer
Member#: 110029
Very concise tank installation images. I see that you have put a great deal of effort to do things properly. Great post.
I don't know what the final hole size is, it looked a well-fit set up. I can see some burrs on the inside edge of the hole, if this can be cleared, it will help. Without a flat surface the rubber seal will not seal properly.
I can see the outside seal restes on burr-free surface. Iwoudl be nice if both seal is work at its best.
More importantly, rotate the sensor until the moulded arrow points unwards. See picture below:
Old 09-18-2006, 05:26 AM   #17
Aquamist
NASIOC Manufacturer
Member#: 110029
For those who intend to do a great of track racing, some form of foam (alcohol/water resistance) inside the tank would be very useful to prevent surge.
Ensure the leaving a cavity for the level sensor.
Old 09-18-2006, 08:38 AM   #18
ejh25
Member#: 65267
Richard,
I will take care of the burrs on the inside as well as rotating the sensor so that it works properly.
Thanks,
Eric
Old 09-18-2006, 08:46 AM   #19
ejh25
Member#: 65267
I have Q about the wiring to the relay in the trunk:
I have a 4 gauge wire running to my amp that is fused near the battery in the engine compartment. I have a distribution block which has a 4 gauge inlet and 4 8 gauge outlets.
When I split the 8 gauge to the Hydramist should I fuse it again? Won't the fuse in the relay and the fuse on near the battery be sufficient?
Should I then connect the 8 gauge to a 16 gauge wire and then attach the spade to the 16 gauge wire to hookup to the Hydramist relay?
Thanks,
Eric
Old 09-18-2006, 08:59 AM   #20
Richard L
Member#: 85153
How far is the fuse box away from the hydramist relay?
If it is shirter than 3 ft, just use a 16 gauge wire to the relay. The maximum guage wire the spade terminal can accomdate for the relay is 14 gauge.
There is already a 15A inline fuse betwen the relay and the pump. No harm in putting in another fuse link in the distribution block, if it is not too difficult.
Richard
Richard L is offline   Reply With Quote
Old 09-18-2006, 09:05 AM   #21
ejh25
Member#: 65267
Richard
The distribution block is about 2 feet from the relay. I have some spare 14 gauge lying around, so I will use that. I'll look into finding another fuse.
Thanks,
Eric
Old 09-18-2006, 09:15 AM   #22
Element Tuning
Member#: 54918
Originally Posted by ejh25 View Post
Phil,
Thanks,
Eric
Sorry I don't have any pics at this time. That sounds like the correct material. You will need at least a vice to bend it properly at 90 degree angles. Honestly it's very simple and took me all of 10 minutes to cut and bend up two brackets.
Adding an extra fuse would be overkill just stick with the two you already have.
Thanks,
Phil
Old 09-18-2006, 09:31 AM   #23
ejh25
Member#: 65267
Thanks,
Phil
Phil,
Thanks for the tip....hopefully one night this week I can get the straps taken care of and take some pics!
- Eric
Old 09-18-2006, 10:52 AM   #24
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
The float sensor ends in a two wire connector. I don't see a male version of that connector in the kit, so should I clip the end and run the wires to the junction box that way?
offset
offset is offline   Reply With Quote
Old 09-18-2006, 11:05 AM   #25
ejh25
Member#: 65267
offset
Offset,
The male version is on the relay.
- Eric
Bookmarks
Element Tuning Pro Comp Engine, Hydra EMS, Hydramist, GT75 Kit, 709 WHP, Q16/Methonal Element Tuning Proven Power Bragging 47 05-10-2010 11:17 AM
Element Tuning Pro Comp 2.5 STi Engine, Hydra EMS, GT75, Hydramist 602 WHP Element Tuning Proven Power Bragging 9 11-16-2009 06:43 PM
Aquamist HFS-5 system: Official Q&A... Aquamist Water/Methanol Injection, Nitrous & Intercooler Cooling 92 06-27-2009 05:40 AM
Andrewtech and Element GT52 Hydramist 110 Leaded ejh25 Proven Power Bragging 42 10-28-2007 02:40 PM
7/17-7/24 Phil From Element Tuning Time Schedule!!!! OFFICIAL. WorldOne NWIC Vendor Classifieds 18 07-19-2006 02:09 PM
Message Board Statistics All times are GMT -4. The time now is 12:36 PM.
