Old 09-16-2006, 11:22 AM   #1
Jim Payne
Member#: 44036
2004 STI
Default EcuTEK reflash problems
Has anyone experienced an ECU failure after an EcuTEK reflash? I first had an erratic output of the 5v source to several engine functions including the electric throttle body [ECU connector B136 pin 16] and finally the pin went completely dead.
Jim Payne is offline   Reply With Quote
Old 09-16-2006, 01:24 PM   #2
Gethin
Member#: 2998
Sounds like a bad ECU and nothing to do with the reflash. I have reflashed many cars and have never experienced / seen a flash do that. Make sure it's the correct ROM file for the ECU version though (but the ECUTEK software will warn you 'sometimes' that the file isn't compatible anyway if it's not for that ECU). The wrong ROM file for the ECU version will cause problems.
Gethin is offline   Reply With Quote
Can you run a "blank" UTEC map over an EcuTek reflash, in which the reflash controls? scooterforever Engine Management & Tuning 42 05-04-2005 11:27 PM
vf34/Vishnu Ecutek Reflash Problem Tuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-19-2004 02:48 AM
problems with ecutek reflash Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-28-2004 10:35 PM
Yay! TurboXS/Ecutek reflash! silvercharged Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-20-2002 07:48 AM
ecutek reflashing at renick subaru in fullerton showcasewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-20-2002 05:29 AM
