Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 11-01-2001, 01:52 PM   #1
Member#: 5476
2007 WRX UGM
2010 FXT
Default Belt Squeak
When my car is cold and I backout of my parking spot, the belts (I assume the power steering belt) squeaks really loud, and will continue to make noise for about 30 secs even after i have straightened out the wheel. How do I fix it?! I tried tightening the belts up so they don't even wiggle at all, that didn't work. The I tired making them fairly loose, and that didn't work, so I kinda set them back to where they should be with just a tiny bit of play. Didn't work. I have a smaller UD pulley, but I don't think that should make a difference. BTW, the belts squeaked since the day I installed them (Gates). I would just slap on new belts, but I have NO money, and I don't think belts are the problem. Any ideas would behelpful..thank you!
RallyImprezive is offline   Reply With Quote
Old 11-01-2001, 02:28 PM   #2
Member#: 857
Don't over-tighten the belt! Your belt is probably glazed and needs to be replaced. But first try some belt dressing to stop the slipping. A spray can of belt dressing should be less than $2.
Silver2000RS is offline   Reply With Quote
Old 11-01-2001, 04:17 PM   #3
Member#: 4348
2001 2.5RS
My gates belts made some noise too after they started stretching. I tightened them and it went away. Then came back after a couple of months. Then I put the stock belt and pulley back in to accomodate the turbo and haven't had any squeak since. I'd try a brand other than gates when you have the 15$ to replace them
paulnose is offline   Reply With Quote
belt squeak sound after hard shift stlb5 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 01-27-2016 07:29 PM
Fixing Timing belt and or Accessory belt squeak Gel Mibson Newbies & FAQs 0 04-06-2010 08:43 PM
belt squeaking silversurfer307 Service & Maintenance 7 05-31-2008 11:56 PM
Cold start up: belt squeak? WRBlueRex04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-06-2007 02:08 PM
AC belt squeaking? sgrigg Service & Maintenance 4 08-07-2006 12:52 AM
