Old 09-17-2006, 07:22 AM   #1
xolosis
Member#: 103373
Default MAF Scaling
I replaced my old panel filter with a K&N Unit. While I was installing into the stock box I noticed the first tuner didn't put the lid on the stock box properly. The Turbo Inlet Pipe was slightly too long and one edge of the box was left with a opening. Trimmed back the Turbo Inlet and made sure the box fitted perfectly on all edges nice and tight.
Went for a drive while logging and now A/F Learning is quite out and the car seems to be running lean. I had to compensate by going a richer in my fuel maps. The car definitly pulls harder especially up top as the old filter was filthy.
How can I fix this issue as I thought about re-scaling the injectors but that's not the right way to do it. Don't I need to compensate with re-scaling the MAF Scaling Maps? Here's a 3rd gear pull...
1=Engine Speed (RPM) 2=Air/Fuel Learning #1 (%) 3=Air/Fuel Correction #1 (%)
*1* *2* *3*
1710 -4.69 0
1780 -4.69 0
1884 -5.47 0
1974 -5.47 0
2064 -5.47 0
2152 -5.47 0
2256 -5.47 0
2356 -5.47 0
2450 -5.47 0
2575 -5.47 0
2689 -5.47 0
2801 -5.47 0
2952 -5.47 0
3089 -5.47 0
3260 -5.47 0
3423 -5.47 0
3621 -5.47 0
3786 -5.47 0
4028 -5.47 0
4226 -5.47 0
4403 -5.47 0
4595 -5.47 0
4786 -5.47 0
4992 -5.47 0
5180 -5.47 0
5331 -5.47 0
5546 -5.47 0
5705 -5.47 0
5878 -5.47 0
6039 -5.47 0
6167 -5.47 0
6251 -5.47 0
xolosis is offline   Reply With Quote
Old 09-19-2006, 06:56 AM   #2
xolosis
Member#: 103373
Can anyone comment?
Old 09-19-2006, 02:04 PM   #3
3barboost
Member#: 73609
2002 wrx
nothing to add
subsribing and a free bump for you - i want to know as well
3barboost is offline   Reply With Quote
Old 09-19-2006, 03:22 PM   #4
Freon
Member#: 88322
2009 BMW 135i
I suggest logging what you have, plus MAF g/s, MAF voltage, IAT, front O2 lambda or air-fuel ratio, aftermarket wideband air-fuel ratio, and throttle position.
What you've posted isn't useful at all. Looks like it is full throttle, or at least open loop.
Freon is offline   Reply With Quote
Old 09-19-2006, 04:59 PM   #5
Zumble
Member#: 34860
2005 Forester CGM
According to what you posted your car is actually running rich and the car is pulling back fuel.
Zumble is offline   Reply With Quote
Old 09-20-2006, 05:47 AM   #6
xolosis
Member#: 103373
Thanks guys,
Yeah its a full WOT pull so do I need to log those parameters that Freon said at idle or at cruise only?
Previously at WOT pulls A/F Learning would be dead on 0.
Anyone have the maf scaling values for an Perrin Big MAF. Stock WRX injectors NITROS Open Source Reflashes 1 02-05-2008 07:57 PM
probably elementary questions - maf scaling, afr targets, UTEC wg control gpatmac UTEC 36 04-05-2006 06:11 PM
UTEC MAF Scaling? Ski Man Engine Management & Tuning 1 10-10-2005 09:48 AM
a/f learning and maf scaling deluxsti Engine Management & Tuning 2 06-06-2005 05:22 PM
what is MAF scaling? erggy Engine Management & Tuning 0 11-29-2004 12:36 PM
