Old 09-17-2006, 06:28 AM   #1
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Default Injector Phasing
I'm interested in what others have found for the optimal injector phasing/end angles.
I have an Autronic ECU, which allows you to adjust injector end angle in crankshaft degrees based upon load and RPM. Currently my map is set to 380 degrees in low load, low RPM sites, and then transitions to 281 degrees in medium/high load, mid RPM sites and finally to 222 degrees in medium/high load, high RPM sites.
I have read that for best idle, injector end angles should be 300 degrees or less. For best power however I have read that they should be around 580 degrees or so. I'm not sure whether this only applies to normally aspirated cars or also to forced induction cars. Somebody once told be reducing the injector angle was the right thing to do as it gives more time for the fuel to vaporize as RPMs increase...
Any thoughts?
STI8U is offline   Reply With Quote
Old 10-05-2006, 07:04 AM   #2
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Bump...
Old 10-05-2006, 05:01 PM   #3
kay95
Member#: 45494
95 impreza L awd
green
Ah I hate to tell you that injector timing is for idel, emissions and slightly more power at low -3000 rpms. The only thing that really changes is emissions and maybe a slightly better idel but thats it.
I wouldnt bother messing with it. You will not make any more power playing with it because where you are making power the pw is so large you will be squirting against a closed valve. This is because as RPM goes up the valve open time is decreased and injector time open is increased. If you are running 75% dc at 5k more you are going to hit a closed valve and there is nothing you can do.
kay95 is offline   Reply With Quote
Old 10-06-2006, 12:16 AM   #4
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Huge power gains and response will be had by adjusting the phasing. You must use a dyno however. Once the timing is set the AFR can be leaned out across the board. While adjusting this perform the adjustments from 2000 rpm WOT to 4000 or so. Past that in Higher idc it will not have near the effect. Also set the correct Injector dead time settings.
Clark
AZScoobie is offline   Reply With Quote
Old 10-07-2006, 05:52 PM   #5
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Clark
Cool thanks...
Old 10-07-2006, 09:17 PM   #6
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
Clark,
Any tips about calculating the injector phasing ?
How can i know that if i have the right settings ?
WhiteKnight is offline   Reply With Quote
Old 10-08-2006, 05:28 AM   #7
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Another query - can you modify injector phasing using ECUTEK/Cobb/OpenECU in the factory ECU?
WhiteKnight - check out this program from the Autronic website, very useful for visualizing injector phasing.
Old 10-08-2006, 06:24 AM   #8
WhiteKnight
Member#: 56133
2004 Euro spec Sti
STI8U,
Thanks for the program,
I have got Hydra ECU and it has only from 0 to 255 degrees for injector phasing.
I have my camshafts detailed spec sheet, if i send you that sheet can you tell me correct settings for my injector phasing map ?
Thanks
Old 10-09-2006, 06:27 AM   #9
STI8U
Member#: 54052
2005 Spec C Type RA
WRC Blue
Originally Posted by WhiteKnight View Post
STI8U,
Thanks
I'm a noob to injector phasing tuning
I can tell you my map is 380 at idle and low load sites/low RPM sites, 281 at medium/high load and low RPM sites and then 222 at high load sites/high RPM sites (4000RPM+).
You'd need to ask Hydra how they do injector phasing - 0 to 255 degrees might be offset or something. Autronic just does it in crankshaft degrees with no offset and you can set the end angle anywhere from 0 to 720
Injector Phasing WhiteKnight Other Engine Management 1 05-05-2006 02:23 AM
sti injectors, phase 2 2.5 heads tjmatta Rocky Mountains Impreza Club Forum -- RMIC 3 07-19-2005 03:50 PM
sti injectors, phase 2 2.5 heads tjmatta Private 'For Sale' Classifieds 0 07-16-2005 07:12 PM
sti injectors, phase 2 2.5 heads tjmatta Private 'For Sale' Classifieds 1 07-15-2005 11:12 PM
sti injectors, phase 2 2.5 heads tjmatta Private Vehicle 'For Sale' Classifieds 2 07-15-2005 04:47 PM
