#1 |
Member#: 61718
VIC
(1) The hawk pads I got last year are completly gone (squealing) they cost $400 and lasted 18 months & 50000km so I am really happy with them. The question, Is $400 a good price or have you guys found them for less locally?
(2) Another question is how do I pry the rotors off (the oem ones are too grooved to stay), The last time I did the pads I removed one front caliper but the rotor was still totally attached. The only thing I could see holding the rotor on would have been the big axle nut & I don't really want to have to remove it. I will if I have to but I have done brake work on all types of vehicles & the rotors usually just slide off once the caliper is removed what's up?. Maybe I just have to pry harder if not let me know. (3) One more, My clutch is on it's way out. I don't need to upgrade as I like the feel & performance of the oem one. Will I only need the disk or the whole unit pressure plate, disk & throw out bearing anything else?. Is this a diy job?, How many hours is a clutch job supposed to take?. I'm going to call rr & dd tomorrow. I should have done it last week it'll probaly hold up for the track day but it would be nice to have a fresh one in there. Thank's..........Justin.
#2 |
Member#: 477
Vehicle:GC4 -> GGA -> GM6 Yeah, that's about right. |
(2) 8mm bolt.
Search: Key Word(s): rotor, removal |
#3 |
Member#: 78967
VIC
Vehicle:2011 335i Black |
$400 for brake pads? is it the front and rear?
#4 |
Member#: 61718
VIC
#5 |
Moderatour
Moderator Member#: 113533
VIC
Vehicle:2013 Leafs Hatewagon |
I thought you could get Hawk pads from Lordco cheaper than that...maybe it's different for the Brembos though?
#6 |
Member#: 61255
VIC
Vehicle:2002 WRX dirty silver |
(3) At the very least, you will need a pressure plate, clutch disk and have your stock flywheel resurfaced. I'd replace the TO bearing while you're in there too - the one you have may be ok right now, but do you really want to tear the whole damn thing apart again over a $30 bearing? I think the OEM replacement comes with almost everything you need in one tidy package, but don't take my word, call up DD & RR and poke around on subarugenuineparts.com to make sure. As for the DIY part, I would suggest you have a look at the walkthroughs here an on scoobymods.com. If the work itself looks to be within your ability, then have a look at how much time it takes for other people to do it and triple it as a worst case scenario (remember, they may have done this before so they don't have to spend as much time figuring things out). If you can do without the car for that much time, I say go for it - it'll be a good learning experience for you.
As a reference, I have changed the clutch on my mustang a couple times and would have no problem doing it again, it's about a 10hr job for me with meal breaks and taking my time. However, even though I have all the tools to do it myself, it's pretty much a tossup for me whether I'd do the clutch on my WRX myself or pay someone else to install it. Last edited by Wylde Horses; 09-17-2006 at 10:05 PM. Reason: my engrish good sometime. |
#7 |
Member#: 55630
VIC
Vehicle:04 STi Stage 2 PSM |
I am using Hawk HPS on my STi, I paid for around $350 intalled, and yea they are more expensive for STi than WRX.
As for the clutch, I have a combo of Excedy stage 1 clutch with ACT streetlite flywheel sitting in my garage right now but figured I still got quite a bit of life left on the clutch so I might be selling it. I don't think the stock one will be any cheaper than something like Excedy stage 1. I got quoted from DD that it will be around $2500+ to replace my clutch and upgrade to the 05 flywheel. |
#8 |
Member#: 78967
VIC
why what's the difference between 04 and the 05 flywheel? @chop2x
#9 |
Member#: 61040
Vehicle:2002 WRX dead sexy blue! |
That's about right chopchop.. I got hawks fro my wrx at lordco.. f/r for 155. Install 180.
400 for pads sounds really really expensive. unless they are the ceramic ones. |
#10 |
Member#: 80482
VIC
Vehicle:2004 PSM WRX -- RIP 2006 Aspen white WRX |
ghostfoot7, $150 and another $180 for installation = $330?
or $180 f/r pad included installation? |
#11 |
Member#: 22742
VIC
Hawk Pads for the Sti are more expensive than for the wrx. Also it depends on which hawk pads you get.
#12 |
Member#: 86314
VIC
Vehicle:2003 Impreza WRX WRB & Black Stockers |
http://videos.hspn.com/?videoid=44&catid=1
Watch this video. Its easy on a WRX and seems alot easier on a STI. |
#13 | |
Member#: 61255
VIC
that's insane! I just did my brakes (Hawk HPS, btw ) and it's easy-peasy. You just have to pull out two bolts from each caliper and it's out - swap the pads, push the piston back a little to fit the caliper back over the disk and bolt it all back up. I spent ~3 hours on it just bacause it was my first time, but now that I know how it's done, I think I could easily do it in 2 hrs, maybe 1.5... Hell, $90 is waaaaaay better then what I make at my regular job, maybe I should get into doing brakes? ![]() |
#14 |
Moderatour
VIC
^^ Good video Ernie!
I just learned how to do the stainless lines, and bleed fluid as well ![]() |
#15 | |
Member#: 55630
VIC
![]() As for the Hawk pads, yeah the ones for STi are definitely more expensive, I believe it costed me around $260 for front and rear. It was the HPS that I got, not the HPS+ which is more expensive. ghostfoot7, the price for the pads seems about right but $180 for installation is crazy!! I paid around $70 or so for the installation, it was done in an hour or so too. Nothing that requires hours of work from what I saw, I guess the hardest part is just removing that pin? I don't know the stuff but it didn't seem that difficult. Last edited by chopchop; 09-18-2006 at 02:40 AM. |
#16 | |
Member#: 61718
VIC
Hey chopchop how much did your clutch & flywheel cost you? or how much might you sell it for?. |
#17 |
Member#: 30784
Vehicle:2007 Honda Fit Silver |
Some ppl use stock pressure plate & sports clutch disc on their Honda & VW as far as I know. I don't know if u wanna give it a try. It MIGHT end up cheaper than getting the whole OEM assy from Subaru. OEM bearings is a MUST though.
Try to get some Ferodo DS2500 pads if u can. I've experience on Project Mu BESTOP/Endless NAS/Hawk HPS&HP+/Ferodo DS2500 myself. And I gotta say the DS2500 is the best I had so far. They didn't even squeak ONCE after I used it on & off the road course. Braking performance & pedal feel are both the best compare with all the others above..... |
#18 |
Member#: 80482
VIC
^^^^ Thanks for the video Sp00lin
It LOOKS like a easy job...but i scared I will do something wrong and end up with can't stop my car................................ lol |
#19 | |
Member#: 55630
VIC
PM sent ![]() |
#20 |
Member#: 53455
Vehicle:2004 Forester XTI-RR dark |
Justin,
I have an 95 STI clutch and flywheel in my car. When my clutch started slipping I grabbed a couple hundred buck six puck disk from rocket rally and ..... well you know how my clutch works. This is two rallies later. and I really like my D905M pads from lordco. 50$ front. 50$ rear. Bling. Bling. Last edited by andys; 09-19-2006 at 11:38 AM. |
| Thread Tools | |
| Display Modes | |
| STOP!! The AMS Brake Thread! Lightweight, Big Brakes, Pads, Rotors, SS Lines + More! | AMS | Suspension/Brakes/Handling | 3 | 04-07-2010 05:41 PM |
| PFC Brake Pads-Rotors-Brake Kits | KNS Brakes | Vendor 'Group Buy' Classifieds | 127 | 12-18-2009 12:32 PM |
| Need help with Brake pad/rotor issue? | Jasno999 | Mid Atlantic Impreza Club -- MAIC | 11 | 04-30-2002 09:57 PM |
| TS (L) pads, rotors = RS Brake pads, rotors? | youthanasia | Brakes, Steering & Suspension | 2 | 02-02-2001 10:08 PM |
