Old 09-17-2006, 03:58 PM   #1
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Default Uh so... Where is the Hella 500 foglight ground connection???
Well Im trying to wire up my Hella 500's right now... I'm using the wiring kit that came with the lights because my '95 does not have any stock foglight wiring and im a poor bastard so i'm not buying OEM stuff for it.
Anyway, I have the switch mounted fine, and the foglights mounted fine, now I'm doing the wiring... And I need major help since I'm a wiring n00b (most complicated wiring ive done was a ABS switch)
In every write up i've read, people say there is a ground for the Foglights... However there is only one wiring coming out of the foglights???
Also, does anyone have a simple explaination of what wire goes where for this kit WITHOUT doing the whole OEM wiring thing??? I know the red wire goes to power, but after that it gets confusing... I have them hooked up to the Hella relay as per instructions, so its just a matter of which wire goes where now.
Also, what about the switch? Where do I plug the OTHER two connects for the switch into? I know one is a ground, and one goes to a 12v source (whatever that means) but after that im just confused.
Oh and I dont want a Wiring 101 lecture, just how to install this kit so I can go to work tommorow with functioning foglights...
Old 09-17-2006, 04:11 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Old 09-17-2006, 05:16 PM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Originally Posted by Uncle Scotty View Post
That doesnt help at all man...
Old 09-17-2006, 07:06 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
um, it should. that is everything you need. it shows all the grounds you need.
here, maybe this helps.
PARANOID56 is offline   Reply With Quote
Old 09-17-2006, 07:08 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Wiring diagrms + me = useless
Anyway, I have it all hooked up minus the switch... I cant figure out which wire to tap for the "lowbeams" and should I use a vampire connector for the switch ground or just ground it somewhere?
http://www.rs25.com/forums/showthrea...811#post917811
Old 09-17-2006, 07:17 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
...man....if i lived within 100 miles of ya(mebbe even a bit more ) id pop 'round and make like a 'lectrical elf fer ya on that one....
kinda hard ta 'tell' ya what to do without bein there ta see it.....
Old 09-17-2006, 07:39 PM   #7
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Ok, I found the headlight stalk wires... Theres two white wires, a green wire, a red wire, a clear wire and a black wire... Which one is which?
Old 09-17-2006, 07:44 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
....I'd NOT use the stalk wires....I'd tap one near the light
Old 09-17-2006, 07:51 PM   #9
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The stalk wires do look kind of small... But I have to use something under the dash. Where does the headlight wire go?
Old 09-17-2006, 08:50 PM   #10
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Well my first try... Got nothing. Lights didnt go on, switch did not illuminate, nothing.
Old 09-17-2006, 09:15 PM   #11
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I tested it out, its the switch causing the problem... i still need that 12v source
Old 09-17-2006, 09:22 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
....man....if I had the fsm/wiring diagram fer that car....the stalk wires go to the factory solenoid which switches the lights on/off so ya don't have hi current wiring in the cabin
typically.....the wire that powers the lowbeam is tapped to switch the solenoid for the fogs---power to the lowbeam light turns the fogs on....which are usually grounded through the body of the light and the mounting bolt of the light to the body.......and subaru uses a funky switched ground that can make ya crazy if ya not used to 'thinking' that way
I really can't do too much from here for ya ....
Old 09-17-2006, 10:23 PM   #13
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Well I finally gave up and ran the switch all the way to the driver side headlight red wire...
And now it all works
Thanks for the help
So where is the best place in NE to get an STI? SAABARU_92x New England Impreza Club Forum -- NESIC 7 03-01-2008 11:50 AM
so where is the rest of the news from naias? Jaxx News & Rumors 23 01-13-2005 08:48 PM
so where is the sunday meet spot? sigma pi Southern California Impreza Club Forum -- SCIC 29 03-01-2004 03:08 PM
So where is the new meet on fri nites?? VSM EXtasy Mid Atlantic Impreza Club -- MAIC 2 03-14-2002 11:26 AM
