Old 09-17-2006, 06:58 PM   #1
BlowDro
Member#: 112116
2006 WRX
Default car just lowered, do i really need an alignment?
i have a 06 wrx with just over 6000 miles. this weekend i lowered it on cobb springs. how important is it that i get an alignment? what settings should i ask for? i will be only doing sprited street driving.
BlowDro is offline   Reply With Quote
Old 09-17-2006, 07:03 PM   #2
06wrxkiid
Member#: 117112
i just wanna see some pics of your car on cobb's..
06wrxkiid is offline   Reply With Quote
Old 09-17-2006, 07:15 PM   #3
BIGSKYWRX
Member#: 7958
09 GH B+
yes you absolutely need an alignment
I've got a alignment sticky here:
www.clubwrx.net
There are also lots of alignment threads floating around
Old 09-17-2006, 08:44 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
.....lesse how long yer struts last
Old 09-17-2006, 10:27 PM   #5
Mykl
Member#: 14311
2010 GTI
I would recommend that you get an alignment. Your toe is probably a bit wacky right now. I would also recommend that you replace the OEM dampers with something that can take those springs.
Mykl is offline   Reply With Quote
Old 09-17-2006, 11:10 PM   #6
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
+1 for alignment.
+1 for new struts.
[really, we're being serious here]
Old 09-17-2006, 11:34 PM   #7
macdarwin
Member#: 80228
2007 Camry 330i TSX
GT PITA Black.
you guys saying that if I drop my car with any aftermarket springs I would need to change my Strut cause the OEM one wont be able to handle it?
geeez more money for my pocket
macdarwin is offline   Reply With Quote
Old 09-17-2006, 11:36 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Originally Posted by macdarwin View Post
you guys saying that if I slam my car with too low junk aftermarket springs I would need to change my Strut cause the OEM one wont be able to handle it?
Old 09-18-2006, 10:19 AM   #9
BlowDro
Member#: 112116
2006 WRX
i read thru the alingment thread and am still confused about what settings i want. can anyone give me there settings?
Old 09-18-2006, 10:49 AM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
"spirited" street driving- front camber have them bump the neg camber up to -1.0ish- a little more won't hurt if they can get it. Cross camber as close to 0 as they can get. Rear camber is non adj- unless something is really wrong in the rear, leave it as is.
Caster is non adj. Toe have them set toe 0 front/rear- again emphasising the importance of a near 0 cross.
Old 09-18-2006, 03:38 PM   #11
wrxty
Member#: 121996
If I'm not mistaken, cobb springs are designed to work with your oem struts.
wrxty is offline   Reply With Quote
Old 09-18-2006, 03:42 PM   #12
Mykl
Member#: 14311
2010 GTI
I know they'll work fine with STi struts, but I thought it was recommended that you upgrade base WRX struts?
Old 09-18-2006, 03:52 PM   #13
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Most shops that actually agree to do alignments outside the factory specs are also able to slot your struts to give you a little more camber adjustment. I had that done in the rear to pull camber back out from the -2 deg it was at when I initially installed a set of springs.
I was rather happy with -1.5 front, -1.0 rear, zero toe on a daily driver.
And to emphasize the importance of an alignment...adding negative camber in the front creates toe-out. My friend lowered his car and corded the inside of a brand new set of Azenis RT-615's in 5000 miles. Get an alignment or you may be buying tires before you want to.
Scooby921 is offline   Reply With Quote
Old 09-18-2006, 04:23 PM   #14
Mykl
Member#: 14311
2010 GTI
How much longer are they supposed to last?
If that's only street driving I suppose that is pretty bad. I got about 7000 miles out of my last set of RT-615's, but that's with four autocrosses and four hours of open track driving.
Old 09-18-2006, 04:23 PM   #15
boostpower
Member#: 116550
2006 WRX
Crystal Gray Metallic
A good alignment really isn't that expensive.
boostpower is offline   Reply With Quote
Old 09-18-2006, 06:43 PM   #16
equipment junkie
Member#: 97607
2006 wrx
wrx blue
+ 1 on the alignment. My stock struts lasted for 10k - 12k and were still working fine when I replaced them with coilovers 5 weeks ago or so.
Another member is now running my stock struts with the same springs. He's having no problems.
equipment junkie is offline   Reply With Quote
Old 09-19-2006, 02:19 AM   #17
BlowDro
Member#: 112116
2006 WRX
iv heard a lot of people with cobbs and even teins for 40+ with no problems, i think it has a lot to do with the roads.
i will be going tomorow and will ask for -1.0, cross camber and toe at 0. i will be getting bigger wheels and tires eventually, probly gonna be 255's. will i need to get realigned do add more camber?
Old 09-19-2006, 05:17 PM   #18
BlowDro
Member#: 112116
2006 WRX
bump, anyone know the answer to the previous question?
Old 09-19-2006, 05:26 PM   #19
littleRedcar
Member#: 122058
1990 Miata
Classic Red
Everyone freaks out about this, and I'm not trying to be a smartbutt here, but it's common sense. Just keep an eye out on the treadwear IMO. If it looks like there is abnormal wear, then schedule for an alignment. If you drive easy on the corners, then there is a good chance that a slight change in ride height will affect your treadwear. Drive aggressive around the turns, good chance you can get away with it. If your daily commute is a 20 mile long highway straight, then your done . A good alignment tech is key here. If he's on the same page as you are, and understands your driving style, then good things happen. I'm lucky, and spoiled with having a good tech who can set it up correctly, and just charge me a measly price of $70 out the door.
littleRedcar is offline   Reply With Quote
Old 09-19-2006, 07:09 PM   #20
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Wrong. By the time you see noticeable wear patterns, it's too late and you've severely compromised your tires.
Get the alignment NOW. Yes, you definitely need it.
nhluhr is offline   Reply With Quote
Old 09-19-2006, 10:21 PM   #21
BlowDro
Member#: 112116
2006 WRX
after i get this alinment, will i need another one to add more rear camber to fit bigger tires, 245s or 255?
Do I really NEED an STi? Padge Mid Atlantic Impreza Club -- MAIC 23 03-29-2009 03:09 PM
Do I really need an O2 socket for my uppipe? WRXislander Newbies & FAQs 27 09-28-2007 01:40 AM
Do I really need an EGT and oil pressure gauge? hella_sti Interior & Exterior Modification 12 04-09-2007 11:18 PM
Do I really need an 8" wheel? scoobtothenoog Tire & Wheel 35 09-18-2005 02:59 AM
Changing springs... do i really need an impact wrench? leocookie Brakes, Steering & Suspension 3 09-16-2004 11:51 PM
