Old 09-17-2006, 10:48 PM   #1
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
desert sand metallic
Default V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads?
As the title says: I plan on swapping blocks in my 05 wagon. Is the V2 JDM STI block better for high RPM apps than the 2.5 USDM?
Will this block bolt-on to the USDM WRX heads?
I will add cams/valves, etc eventually, but want to run a high RPM Type RA STi block.
Is this doable????
Thanks!
SOTC
saab-on-the-cobb is offline   Reply With Quote
Old 09-18-2006, 01:06 PM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The bore/stroke is better suited for higher revvs than the 2.5L. You'll need a built 2.5L to run efficient in the higher revvs(lighter pistons).
There shouldn't be a problem bolting it up together. We have guys putting in EJ257 with 2.5L NA DOHC/SOHC heads. I put my '99 2.2L heads on my EJ22T shortblock.
FuJi K is online now   Reply With Quote
Old 09-18-2006, 01:14 PM   #3
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
Thanks!
Will the V2 cams/valves fit my heads?
SOTC
Old 09-18-2006, 01:21 PM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
If those are the STi Ver 2 stuff...from the 1st generation Impreza, those cams will not fit your heads due to different castings. You would need cams made for the NEWER style heads; possibly STi Ver 7 and up. The STi version 1-4 are same but version 5/6+ possibly share the same head casting for the cams, not too sure.
Old 09-18-2006, 04:24 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no... nono
ver 2 are only good for ver 2 ..v.1....3/4 and 5/6... v.7(2.0)-v.9 all differnt
the usdm block has FAR FAR more power potential .. yes the v.2 will spin faster .. but that won't make up for the displacemnt
ex
v.2 make 300 hp at 8000 rpm
usdm make 350hp at 7000 rpm
Old 09-18-2006, 06:13 PM   #6
saab-on-the-cobb
Member#: 116330
2005 Saabaru 9-2x
Originally Posted by Jaxx View Post
no... nono
ex
WOW! Member # 177!
Tanks fer the heads-up!
SOTC
Old 09-18-2006, 07:03 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Jaxx,
You're old skool...
2.5 USDM STi master engine gasket Part ID list 2phless Built Motor Discussion 79 04-03-2016 06:06 PM
2.5 USDM STi short block KZ_Scoob Private 'Wanted' Classifieds 7 10-03-2015 04:32 PM
2.0 RA JDM vs 2.5 USDM Shortblock [email protected] Built Motor Discussion 45 06-15-2006 07:30 PM
Pros/Cons of 2.0 JDM STI vs. 2.5 USDM STI engines TooSlow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 61 01-24-2005 12:14 AM
2.5 USDM STI Motor is strong! Race Tested! WorldOne Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 102 06-23-2004 12:42 PM
