Old 09-18-2006, 11:49 AM   #1
droccm
Member#: 124863
Default '02 Forester S stumbles/hesitates
I have 59,000 miles on my Forester.It started out as a slight hesitation when the car was cold and now it is more severe.It seems to be only in the low RPM range under 2000 rpm's and mostly when starting off from a stop.Runs good on the highway. When I step on the gas the car sputters and hesitates and if I pump the pedal a bit it seems to help.Also the idle seems a bit rough almost like a miss so that the engine shakes a little. I tried treating the gas,changed the air filter,plugs,wires,fuel filter and PCV valve and still no luck.I am not getting a check engine light.I am taking it to my local mechanic this week because I need an inspection done.Any ideas as to what could be the problem.Thanks.
droccm is offline   Reply With Quote
Old 09-18-2006, 12:37 PM   #2
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Sounds like a vacuum leak to me. Have you checked every hose for leaks/connections?
Old 09-18-2006, 01:25 PM   #3
droccm
Member#: 124863
All hoses appear to be in good condition and connected.
Old 09-18-2006, 08:24 PM   #4
soultron
Member#: 125843
1996 Legacy Outback
Maroon
That sounds similar to the problem in my 96 legacy. The old owner thinks it's the injectors, but I'm no sure about that.
soultron is offline   Reply With Quote
Old 09-27-2006, 05:23 PM   #5
droccm
Member#: 124863
In regards to my original post. I changed plug,wires,PCV valve and coil and still ran bad.First private mechanic changed the Idle air control valve but still no improvement so he put the old one back on and said he felt it was a tranny problem. I took it to a Subaru dealer and they changed both o2 sensors and reprogramed the ECU and it is running fine so far.Thanks for the input.
Stock 07 WRX Wagon Intermittent Bucking Stumbling/Hesitation/Bucking mikehoyer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 12-19-2009 10:08 PM
Stumbles/Hesitates when under any kind of boost. NITROS UTEC 3 08-16-2007 11:52 AM
98 OBS stumble/hesitation kheff46 Normally Aspirated Powertrain 0 12-03-2006 12:24 PM
Stumbling/hesitating on acceleration BruceC Service & Maintenance 9 02-09-2005 12:24 AM
