Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 09-18-2006, 06:13 PM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Default Diary: Misfiring ej257 Hybrid
It's been almost two months since I have completed my hybrid. I have been experiencing misfires since day one. I have since done the following to help diagonosis the issue. I consistantly get the misfire on cylinders 2-4 but sometimes will get it on all four.
My idle is very erratic and rough, the stock ecu seems to have trouble controling fueling at idle. The afr is way out of wack constantly jumping around in the range of 14.6-15.4. I have also seen it go as low as 14.1 and as high as 16.1. Those readings are all at idle. During a cruise the afr is perfect at 14.7 and spot on my tuned 11.0 at WOT.
Compression test result yield 1-2-3-4 = 165-180-175-175
PressureTest result yield leak by turbo/inlet holes. Fixed leak.
Changed spark plugs to NGK Copper step colder.
I have also done an vacuum test.
---You can check out the video of the results here
http://forums.nasioc.com/forums/show....php?t=1075238
It seems like I might have a leaky valve to me but I do not think I do. I will perform a leak down test, if my other attempts listed below give me no results.
My next objective is to swap around the ignition coils. After I do this I will mod my stock injectors and have them cleaned and flow tested. I have a good feeling its the injectors causing my problem.
I will keep this thread updated as I embark on this journey of correcting the misfire issue.
If you guys have any suggestions, I am open to them.
NITROS is offline   Reply With Quote
Old 09-25-2006, 06:32 PM   #2
NITROS
Member#: 41561
04 GT3076 2.1
I have swaped the coils from one side to the other. The misfire did not follow. This indicates that the coils are good. I will be swaping around the fuel injectors this week.
If moving the injectors does not move the misfire to another cylinder, the only thing other conclusion that can be drawn is a mechanical problem.
This means I will have to pull the block out again, and pull the driver side head, inspect it.
-Walter
Old 10-06-2006, 01:39 PM   #3
subaruwrx420
Member#: 80939
My friend is having similar issues but on the pass side. The cylinders do not seem to be firing at all. Idle is horrible with the engine shaking violently back and forth.
The following has been done: swapped coil packs with another car, swapped spark plugs (all were black), swapped injectors with brand new ones, changed the map, the injectors and the spark plugs are getting electricity...we're all stumped.
The car has Helix cams & valve train upgrade...apparently, when we messed with the coilpacks and injectors the idle changes for a moment and gets much better but the very soon after goes back to crap. I thought it was the cams but someone in another post said probably not since by messing with the coilpacks and injectors we are influencing how the motors behaves, but it lasts less than a minute. The guy suggested that we check the ground on the intake and to check all the connections.
Good luck man.
subaruwrx420 is offline   Reply With Quote
Old 10-06-2006, 05:44 PM   #4
sumitomo
Member#: 125472
hey guys just to double check things on the coil connectors white front coils black rear coils/did any injectors get unpluged maybe plugged on a different injector?/check grounds I hope this might help.
sumitomo is offline   Reply With Quote
Old 10-10-2006, 12:19 AM   #5
NITROS
Member#: 41561
04 GT3076 2.1
I decided to redo my timing belt. I took it off and put it back on. That fixed my issue. I did not touch the injectors.
My idle afr stablabized it pretty constant now and not jumping around all over the place.
And holy **** does this thing have alot of power now. I thought it was powerful before now its just mind boggling.
The timing belt was very easy to do if you do it correctly and follow the instruction from the subaru manual.
FP Green or 20g here i come.
Old 10-10-2006, 09:35 AM   #6
sumitomo
Member#: 125472
glad to hear ya found the problem,sometimes that stuff will have ya pullin your hair out.
Misfire on hybrid engine Splinter Built Motor Discussion 0 08-11-2008 01:27 AM
EJ257 hybrid oil pump question sheikthin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-28-2005 03:03 PM
My EJ257 Hybrid MY98 RS wont start!!! turboed22 Service & Maintenance 1 08-11-2005 05:01 PM
ej257 hybrid question! scoobyimpreza Pre-2002 Factory Turbo Powertrain 19 02-07-2005 02:51 PM
EJ257 hybrid possible headgasket trouble john banks Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 86 03-25-2004 12:18 PM
