View Poll Results: Which gear oil?
Redline MT-90 75W90 GL-4 3 30.00%
Redline 75W90NS GL-5 7 70.00%
Voters: 10. You may not vote on this poll
Old 09-19-2006, 02:46 AM   #1
-AliasMunky3-
Member#: 57407
1983 02WRX & 14BRZ
WRB & DGM
Question 02 WRX Redline MT90 vs. Redline 75W90NS?
Car: 2002 WRX 60,000 miles
Current Gear Oil: Motul Synthetic 75W90 GL-5
Have waiting: Redline Synthetic MT90 75W90 GL-4
I ordered 4 quarts of Redline 75W90NS and I was accidentally sent Redline MT90 75W90. I have read the sticky by Rallispec mentioning that the GL-4 is actually better for the synchros, however I have read the other sticky mentioning that the 75W90NS is being run by more people with somewhat mixed results. Coming from a synthetic GL-5 to a synthetic GL-4, would there be any problems? The MT90 can be sent back for the 75W90NS without a problem, but I'm wondering if I should just stay with the MT90.
Your thoughts.
-Al
-AliasMunky3- is offline   Reply With Quote
Old 09-19-2006, 08:26 AM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Subaru specifies a GL-5 rated lubricant - I would be reluctant to put 100% GL-4 in there... maybe a mixture, but not all GL-4.
Old 09-19-2006, 01:43 PM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Even though Subaru specs GL5, check with Andrew @ AndrewTechAutomotive (I think I spelled that right). Last I had seen, Andrew recommends straight Redline Lightweight Shockproof, a GL-4. Says that has the best results.
I run a mix of Redline 75W90NS and Lightweight Shockproof, more or less 50/50. I like it better than straight 75W90NS but I haven't tried straight Lightweight Shockproof.
I find shifting smoother w/the 50/50 mix as opposed to straight 75W90NS.
Samurai Jack is offline   Reply With Quote
Old 09-19-2006, 02:47 PM   #4
RayO
Member#: 42329
2002 WRX sedan
At my first change, I put in MT 90 because that was what was recommended on Cobb's site. I was worried about the GL-4 rating, so after ~30,000, I switched to 75W90NS, as recommended by Redline.
Frankly, I was happy with the performance of both products. Shifting was better, especially cold, than with the stock lube. Getting into 1st gear at a roll was/is not possible, though.
After a months' long quest, I now have the ingredients for Uncle Scotty's cocktail, which goes in next.
My 2002 has 92,000 miles on it.
RayO is offline   Reply With Quote
Old 09-19-2006, 02:58 PM   #5
-AliasMunky3-
Member#: 57407
1983 02WRX & 14BRZ
WRB & DGM
Thanks RayO, I just saw that on the Cobb site.
02 WRX Stock Turbo vs 06 WRX Stock Turbo djosrs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-07-2013 05:16 PM
Anywhere local to buy Redline MT90? Snowphun New England Impreza Club Forum -- NESIC 10 03-27-2010 10:45 AM
Redline Mt90 schuey_1 Transmission (AT/MT) & Driveline 3 11-02-2005 08:15 AM
02 WRX, 5w-30 vs. 0w-40 mobil1? overdose Service & Maintenance 1 11-18-2003 10:26 AM
('93-'01) Neo VS Redline VS AmsOil harrydog Impreza Forum 1 06-06-2001 01:09 AM
