Welcome to the North American Subaru Impreza Owners Club Saturday August 30, 2014
Old 09-19-2006, 03:29 AM   #1
Carbon888
Member#: 65536
05 Impreza | STi
Simple.less is more.
Default Cons of P zeros or Toyo Proxes 4??
I have heard enough good things about these two tires So what's bad about these two? That will probably help me decide which one to get instead of reading all the great things about it.
Carbon888 is offline   Reply With Quote
Old 09-19-2006, 11:00 AM   #2
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
From what I can tell, the P Zero is a little bit better than the Proxex 4, but also costs more.
I bought the Toyos and I'm happy.
dbrier is offline   Reply With Quote
Old 09-19-2006, 12:00 PM   #3
rjundi
Member#: 123454
2004 WRX Wagon
They both are not great in winter conditions for an all-season. Basically sacrafice winter traction for excellence otherwise.
rjundi is offline   Reply With Quote
Old 09-19-2006, 12:13 PM   #4
Howl
Member#: 57830
1999 OBS
I had the Proxes4's so I can vouch that they're not great in snow. They also wore out quite quickly - I got about 30,000 miles on them before the tread got so low they started to hydroplane badly.
When they were new, and on pavement, they were a great tire.
Howl is offline   Reply With Quote
Old 09-19-2006, 05:56 PM   #5
blueteamno
Member#: 32089
2011 WRX
2012 Outback
i can say the exact same thing about the p zeros Howl said about the proxes, started out great but wore down super fast.
blueteamno is offline   Reply With Quote
Old 09-19-2006, 11:31 PM   #6
Carbon888
Member#: 65536
05 Impreza | STi
Why is Proxes 4 so much cheaper? Is it just the brand?
How's the cornering in wet ?
Old 09-20-2006, 12:46 AM   #7
Back Road Runner
Member#: 60082
2004 Forester STI
I run the Proxes 4. They're nice, performance all-season tires. They're competent and offer a good amount of comfort for a sport level tire. For the amount of tread on the road, I was suprised how well they felt and handled in the wet. There's a drop in grip, but it's not much. I've had mine on since last spring. I have a set of Nokian WRs for winter, so these will be coming off sometime near the end of October/early November.
Toyo Proxes 4
Pros:
-good dry grip and stable cornering, even into slip.
-wet grip was better than expected and feels confident even in a down pour.
-well-mannered carcass/sidewall that soaks up bumps without a lot of jolt or bounce.
-decently quiet, but a slight drone at speed, very livable but a hair quieter would be nice.
-handling feels good, not ultra crisp but responsive and taut.
-tread life seems decent enough so far, not outstanding at a passanger car tire level but good for a performance level tire. Seems to hold up well to agressive driving too; rubber doesn't seem to tear/chunk off like a standard all-season tire.
Cons:
-dry grip was slightly less than I'd expect for a high performance class tire(even an all-season one)
-slightly intrusive road noise, acceptable but silent is better
My tires basically came free with the wheels with only one summer of use, so I can't complain too much. Would I replace them again with Proxes 4 tires? If the price was right. However, for a summer only tire, I wouldn't mind a little more perfromance. No personal experience with the PZero Neros, but people tend to like them a lot and test has shown very good marks as well. If I were to guess, I'd say they're a step up from the Proxes 4 in most ways.
Would my next tire be a PZero Nero? Tough call. There's a lot of good tires out there. The Potenza RE-01R sparked my interest, but I don't know if I'd want to step that far towards the upper echelon of performance tires. Car & Driver's tire shootout also showed Goodyear's Eagle F1 GS-D3 and a very capable and well balanced tire, and TireRack's test results confirm their performance level to be competitive with the other high performance options.
It would come down to the overall mix of properties that make the tire as a whole what it is. My perfered mix is different than your perfered mix. In terms of Toyo and Perelli alone, I'd really have to run the PZero Neros for a while to get an idea of how they compare. I'm sure some minor traits between both would show up and potentially pass judgement on one tire over another. If only from word of mouth from others, I'd kinda lean towards the PZero Neros as the "best" of the two.
Old 09-23-2006, 03:15 PM   #8
Carbon888
Member#: 65536
05 Impreza | STi
Toyo Proxes 4
Pros:
Cons:
thanks for the write up!! that gave me a good idea of the toyo proxes 4, and take it into consideration
Old 09-24-2006, 02:24 PM   #9
saharakid03
Member#: 70490
2005 WRX
toyo tires gets down!! i still have them on my stockers!
saharakid03 is offline   Reply With Quote
Old 09-24-2006, 03:04 PM   #10
559to916
Member#: 120157
2007 BMW 335i
the sidewalls on the toyos are too soft. not too great for performance driving.
the pzero neros are good tires but like to make a lot of noise (screech) when making hard turns.
559to916 is offline   Reply With Quote
Old 09-24-2006, 04:23 PM   #11
wrxzboost
Member#: 86322
also love my toyo's...i have them on right now and they're a dream.
wrxzboost is offline   Reply With Quote
Old 09-25-2006, 11:10 AM   #12
aubsxc
Member#: 91476
2005 9-2x Aero
Don't think you could go wrong either way. I've never used the Toyos but I've been running the Pirellis for about 14,000 miles now and am very happy with them. Excellent grip in the dry and wet (enough for my needs anyway), and so far wear seems normal, and I figure I should get at least 30,000 miles (or more) out of this set. No negatives I can think of.
aubsxc is offline   Reply With Quote
Old 09-25-2006, 11:41 AM   #13
sanremo_russ
Member#: 56465
2004 WRX - VF34
SRR
I previously had Toyo Proxes FZ4's (old version of Proxes 4) and they were great initially, but worn down and got noisy quite fast.
I had the similar debate regarding the Proxes 4's and Pzero Nero M+S. I researched them to death and ended up buying the the Pzero's 2 days ago. These tires are extremely quite and comfortable. I am still breaking in the new tires and haven't pushed them yet so I can't say much about handling. Also, I haven't noticed the tramlining issue talked about in the Tirerack reviews. Here are a few things that made the decision for me:
-Was able to get the Pzero's at the same price as the Proxes 4's (Work discount). Pzero's are at least $20-$30 more per tire.
-Pzero treadwear is 400 vs Proxes 4's 300
-Pzero's have 2 ply sidewall - better handling
-Alot of positive feedback on Nasioc and Tirerack for the Pzero's.
Good luck!
sanremo_russ is offline   Reply With Quote
Old 09-25-2006, 11:55 AM   #14
BryanH
Member#: 993
I have run both and I found the Pirelli had a much stiffer sidewall and seem to give a bit better response until you air the Toyo's up a bit.
But the Pirelli's also seem to get VERY noisy as they wore down and I am anal about tire rotation. The Toyo's didn't get this noisy.
The toyo's had a better highway ride...probably because of the softer sidewall.
Both were exceptionally sticky for being all season tires.
BryanH is offline   Reply With Quote
General Exclaim UHP or Toyo Proxes 4? Brian Broz Tire & Wheel 4 04-26-2007 09:35 PM
Kumho ASX or Toyo Proxes 4?? Subydude81 Tire & Wheel 14 03-29-2007 09:15 AM
Pirelli PZero Neros or Toyo Proxes 4 jikhead Tire & Wheel 18 02-28-2006 12:40 PM
Pirelli Nero M+S or Toyo Proxes 4 (same price) Focus4 Tire & Wheel 11 06-01-2005 07:17 PM
Pics of an STi w/Toyo Proxes 4 jmaluso Tire & Wheel 0 06-30-2004 04:22 PM
