Old 09-19-2006, 07:21 PM   #1
kn0bby8
Member#: 97644
2006 WRX
Default Cooling Mist LED
I have a yellow Coolingmist LED installed to my clog nozzle detector. On the web page it says that when methanol is flowing the led should blink and when there is a clog it will constantly be lit. For me it is constantly lit. How can I check if it is clogged? Is there anyway to make it spray without driving the car?
kn0bby8 is offline   Reply With Quote
Old 09-19-2006, 10:20 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
You could put pressure in the tube going to the controller with the ignition on and the car off. If you don't take the nozzle out of the intercooler(or whatever) while doing this, you might end up with a problem. From the way the light is describved, it would seem that the pressure in the tubing going to the sensor is not reaching the required amount for it to say that things are cool. There are settings on it though, and you might wanna try puting it on a lower setting to see if you're getting a lower amount of pressure. I'm not sure what the settings on it are though(different psi levels), or what yours is set to, but it shouldn't be set above 40psi unless your system never goes that low. The minimum pressure for good atomization is 40psi(from what I've heard), and that's why I say it should be set at 40 if possible.
peace
Old 09-20-2006, 01:47 AM   #3
PolarisSnT
Member#: 85905
2004 WRX
Bypass the controller and ground the system manually. Pull the TMIC or IC piping, depending on your setup, so that you can see the nozzle. Ground the system by touching it to say the strut top bolts and it should spray. Ignition has to be on for this.
PolarisSnT is offline   Reply With Quote
Old 09-20-2006, 05:05 PM   #4
kn0bby8
Member#: 97644
2006 WRX
I realized that the led was not wired correctly so I wired it right. I ran the line that sprays to the nozzle over my windsheild. When the meth sprayed the led would light like it is supposed to but all of a sudden it stopped working. I checked the led and it is still good. What could I do?
Old 09-21-2006, 02:15 PM   #5
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
chech the ground from the detector. That happened to me and the ground was the problem. FWIW, my CND is off all the time unless it is spraying (flowing above whatever the factory setting on the flow detector). When it is flowing, it is lit constantly. When not flowing, nothing. I don't know about flashing for a clogged nozzle. I would think that the detector doesn't "know" when there is a clog, only if it sees flow, or doesn't.
bcblues is offline   Reply With Quote
Old 09-21-2006, 05:48 PM   #6
kn0bby8
Member#: 97644
2006 WRX
Where is yours grounded? Is it grounded by itself or with other wires?
Old 09-21-2006, 07:05 PM   #7
KJR
Member#: 16879
since it's so close to the battery, I grounded mine there for good measure. Mine has worked flawlessly.
KJR is offline   Reply With Quote
Old 09-21-2006, 07:12 PM   #8
kn0bby8
Member#: 97644
2006 WRX
Mine is grounded on the manifold with another wire. Is their a reason why this is no good?
Old 09-22-2006, 01:56 PM   #9
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
You sure that isnt backward? I believe its on solid if its flowing, and blinks if theres a clog.
xrocket21 is offline   Reply With Quote
Old 09-22-2006, 06:00 PM   #10
kn0bby8
Member#: 97644
2006 WRX
Regardless the thing is notlighting up when the car is spraying.
Old 09-22-2006, 06:33 PM   #11
mrwrx2002
Member#: 59085
World Rally Blue Pearl
it is supposed to light constantly when there is flow, and im not sure when it clogs im pretty sure just as someone else said it just doesnt light up since there is no flow.
it is a very simple wiring job ... and yours was working correctly.
since it isn't now I would say check all your connections and double check their accuracy. also check the led to see if it works, connect a battery to it to see if it lights
mrwrx2002 is offline   Reply With Quote
Old 09-23-2006, 10:53 AM   #12
Rwu00313
Member#: 82153
2016 WRX
CWP
I just put my CND in yesterday and I'm sure everything is wired correctly but the LED only lights when I hit the max PSI spray. I have it set to min at 14psi and max is at 21psi but the light only comes on at 21lbs and not 14...whats that about?
Rwu00313 is offline   Reply With Quote
Old 09-23-2006, 01:46 PM   #13
Rwu00313
Member#: 82153
2016 WRX
CWP
anyone have any info on this?
Old 09-23-2006, 10:14 PM   #14
kn0bby8
Member#: 97644
2006 WRX
When mine was working that is how it was functioning.
Old 09-23-2006, 10:45 PM   #15
dibblejr
Member#: 94070
05 LGT
Best way i have found to check it is to disconnect the hose from the nozzle and route it to the windshield. Drive the car it should spray at your settings.
You can also watch your egt guage, the temp should fall when it is working.
Once you know that then you can tell if it is working with your LED flashing or constantly on. You may have it wired incorrectly.
Jay-R
dibblejr is offline   Reply With Quote
FS: WA state Vari-cool cooling mist trunkmount kit *complete wr-ecks Engine/Power/Exhaust 9 05-01-2009 11:48 PM
Cooling Mist vari-cool meth kit Jshoalin25 Private 'Wanted' Classifieds 2 04-28-2009 06:00 PM
FS: Cooling mist vari-cool jr4jc Engine/Power/Exhaust 0 03-09-2008 08:49 PM
Cooling mist kit for NA ? G.Subramaniam Water/Methanol Injection, Nitrous & Intercooler Cooling 19 05-26-2006 05:23 PM
Cooling Mist Dual Stage 3-600+hp Water/Alky Injection Kit! IMPORTIMAGE Vendor 'Group Buy' Classifieds 3 11-19-2005 02:36 PM
