Old 11-02-2001, 12:43 AM   #1
impRSa01
Member#: 4411
2001 Impreza 2.5 RS
Default New spark plugs or keep old ones?
I am getting a stage 1 kit. The kit comes with a T25 BB turbo, specked out to flow more than a T3 but a little less than a T3/04. So I would say it's efficiency range is maybe 12-15psi. My kit is non-intercooled, and is going to be running 5psi.
Do you think I should upgrade my spark plugs to 2 stages colder or so. I want to prevent detonation, and I know since I am not benefiting from an intercooler, I should try and prevent it with 94 octane gas and colder plugs. So which plugs should I get?
The reason I am not getting an intercooler at this time is so I can have more gauges to monitor the engine. If i got the intercooler, I could only get EGT and boost. Without the intercooler, I would have plenty to spend on EGT, fuel pressure gauge, and a boost gauge. Which route is better? Keep in mind, I am taking my car through the winter right now, so hot outside temperatures are non-existent to induce detonation. I can always save up in the winter for an intercooler to go on in the summer.
Let me know what you guys think.
Kevin
impRSa01 is offline   Reply With Quote
Old 11-02-2001, 01:11 AM   #2
paulnose
Member#: 4348
2001 2.5RS
Silverthorn
My 2 cents is get the intercooler and you wont have to worry about the gauges, Running without an intercooler is okay, but I wouldn't consider it the best of all ideas, since we have high compression engines. The non-intercooled subies are mostly 8.5:1 from what i've seen, a big difference from 10:1
paulnose is offline   Reply With Quote
Old 11-02-2001, 02:10 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Definetly go with an IC. I'm one of the many casualties who said I'll hold off on the IC. And definetly get colder plugs. NGK 7's
Eric
Eric SS is offline   Reply With Quote
Old 11-02-2001, 02:51 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
i would definitely get an intercooler and run 2 stage colder plugs regardless. You don't want pinging.
Jeremy
Old 11-02-2001, 12:13 PM   #5
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
You not only should have colder plugs, but DEFINETLY get an IC. or run 3psi or under. Larry Ganz is in the process of developing and having produced great IC's. I will post pictures and a review when it is done. Look into Ludespeed, Forced Air technologies, Vishnu, KartBoy or others for an IC if you need it asap....
STiShawn is offline   Reply With Quote
Old 11-02-2001, 09:47 PM   #6
the Dabbler
Member#: 4540
MY00 2.5RS Sedan
Abnormally Aspirated
Not only are colder plugs a good idea, they're cheap, even for really good ones. If you're in there already, I figure, why not? It takes half an hour to do all four.
Re the intercooler: Personally, I'd want one. But then, if you're going with a base kit that uses an RRFPR to control fueling, then I'd want a fuel pressure gauge as well, since that would be your primary "tuning" mechanism. At least get a cheap mechanical fuel pressure gauge and tape it to the outside of your windshield during your initial testing. Maybe you could fit that into your budget and still get an IC?
the Dabbler is offline   Reply With Quote
Old 11-02-2001, 11:06 PM   #7
Avenger
Member#: 1234
Do you guys have the NGK number for the colder plugs for a 2000 2.5RS?
Avenger is offline   Reply With Quote
Old 11-03-2001, 11:50 AM   #8
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
NGK part number BKR7E-11 I believe
Eric
[FS] 4 spark plugs 3 miles old NGK BKR6EIX f1anatic MWSOC Private Classifieds 1 10-20-2009 03:56 PM
New spark plugs with old tune subaruNV Newbies & FAQs 7 09-05-2008 06:18 PM
FS: New Denso Iridium IK22 Spark Plugs (set of 4) - one step colder than stock scoobyhugh Private 'For Sale' Classifieds 6 02-05-2004 03:15 PM
Can a check engine light be caused by bad spark plugs or bad plug wires? pico Newbies & FAQs 7 06-27-2002 04:57 PM
New Spark Plugs = New Car, no hesitation WRSport Normally Aspirated Powertrain 9 06-20-2001 01:11 PM
