Old 09-21-2006, 12:02 AM   #1
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Default Anyone know how to aim the headlights on the '06?
I havent found the aiming guide for an '06 yet. I searched, but they were all for 04-05. My headlights are wayyyyy too low.
cucamelsmd15 is offline   Reply With Quote
Old 09-21-2006, 09:33 AM   #2
xmystikx
Member#: 112253
14 wrx
revlis
There's a little 8mm or 10mm nut screw in the back that you can turn with a socket wrench. It'll make the headlight go up or down. It's right around the rear of the bulb, and it's fairly hard to miss.
xmystikx is offline   Reply With Quote
Old 09-21-2006, 11:36 AM   #3
cucamelsmd15
Member#: 122980
The silver one? I think I found it
Old 09-22-2006, 12:12 AM   #4
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
I should probably do that, unless the left light is supposed to be lower than the right...
Counterfit is offline   Reply With Quote
Old 09-22-2006, 01:14 AM   #5
benw
Member#: 103320
1998 swapped
Forester L
yep, it is supposed to be like that, so you don't blind drivers coming at you.
benw is offline   Reply With Quote
Old 09-22-2006, 02:02 AM   #6
Counterfit
Member#: 124254
"The Scoobinator"
Well, that makes sense, and I had thought about that, but the difference between the two isn't very large, and I'm pretty sure the right side isn't high enough to blind anyone. Of course, most people around here drive SUVs and minivans anyway.
Old 09-29-2006, 04:28 PM   #7
BNut
Member#: 12675
2002 330Ci/2006 STI
14.6 @ 95mph-330Ci
There is a spot right behind each head light that lets you stick a phillips head screw driver into a set of gear teeth. If you twist the screw driver one direction it tilts the lights up and the other direction tilts the lights down. If you look on the plastic housing for the headlight they have instructions that show you which way to turn it. If you can't find it, let me know and I can take a picture to show you exactly where it is. (I don't know if the STI is different from the WRX though)
Take care,
Brian
BNut is offline   Reply With Quote
Does anyone know how to remove album artwork on iTunes? Castor Troy Off-Topic 2 12-05-2005 10:39 PM
Does anyone know how to change shift knob for the legacy? EJ20(GDB) Legacy Forum 10 07-26-2005 12:37 PM
Anyone knows how to adjust the headlight of MY98-01 to aim it more downwards? V6 Electrical & Lighting 4 10-24-2004 08:01 AM
Anyone know how to (DIY) clear lense on the new 04 models ImpreziveRS415 Electrical & Lighting 2 05-03-2004 11:45 PM
Anyone know how to wire sidemarkers so they come on with the headlights? kAn9ArOo General Forum Archive 6 09-07-2000 12:29 AM
