Old 09-21-2006, 03:52 PM   #1
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
Default Rotating tires on an AWD car...
Is the frequence of the rotation required any lower than on a FWD or RWD?
Paraskass is offline   Reply With Quote
Old 09-21-2006, 03:54 PM   #2
WRB_in_my_veins
Member#: 66540
2004 WRX Sedan
2005 Legacy GT wagon
No. Read your manual.
WRB_in_my_veins is offline   Reply With Quote
Old 09-21-2006, 04:03 PM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
IIRC, I believe the manual states every 7,500 miles.
Hank3 is offline   Reply With Quote
Old 09-21-2006, 04:08 PM   #4
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
My dealership says 15k miles.
Old 09-21-2006, 04:26 PM   #5
4wdrift
Member#: 1403
99 RBP GC8 Impreza
Your dealer should look at his manual.
4wdrift is offline   Reply With Quote
Old 09-21-2006, 04:34 PM   #6
Back Road Runner
Member#: 60082
2004 Forester STI
I don't but I'm lazy. So far, wear has been quite even. Our cars put power down pretty evenly, so the only excess of wear would be the front from on-power + steering. Well, that and the front end is slightly heavier. Unless you take different routes to and from work, wear should be similar on both sides. If you were just doing all left turns, then you'd expect more wear on one side.
Wear is just lot less of an issue with awd than it is with fwd or rwd where all the power is going to a single set of tires.
As well, rotating may depend on how you buy tires. On a fwd car, you could get away with running through 2 or maybe even 3 sets of tires on the front before you ever wore down the rear tires. It could be similar with a high powered rwd car. You could rotate and eventually buy 4 tires or just replace the two high wear ones every so often with no rotation.
Old 09-21-2006, 04:37 PM   #7
02darkRS
Member#: 80918
02-7 MBP RS/i hybrid
now w/ AVLS!
i thought it was 4,000? oh well, i rotate/balance mine every oil change.
02darkRS is offline   Reply With Quote
Old 09-21-2006, 06:13 PM   #8
dedgley
Member#: 80631
2016 WRX Premium 6MT
Ice Silver
My practice is to rotate tires and change oil every 5k miles. Nice even wear on all four tires.
dedgley is offline   Reply With Quote
How bad is it really, to have 2 different sets of tires on an AWD car? WhiteFox Tire & Wheel 12 03-19-2008 03:22 PM
rally racers, how does one get an AWD car to rotate? steve Vancouver Impreza Club Forum -- VIC 57 01-14-2007 03:53 AM
Has anyone gone from a rwd car to an awd car? BlackoutWRX General Community 40 11-23-2005 11:43 AM
okay so its bad to tow an AWD car with 2 wheels on the ground jasona Normally Aspirated Powertrain 15 12-11-2002 02:04 AM
Slicks on an AWD car? ScoobieSnacks Bay Area Impreza Club Forum -- BAIC 4 02-15-2002 10:57 AM
