Old 09-21-2006, 05:30 PM   #1
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
Default Need help wiring Hella 500's
I have been trying to figure out why my new hella 500's aren't working. I know the relay is good because it's clicking, and i switched it out the relay with the other hellas i have and they work. I tried taking the ground away from the relay and it didn't work so i know it has a good ground. I know the lights have a good ground because I applied the black wired to a positive source (battery)
I have:
30: Positive
87: to the lights
86: is ground
85: is the yellow wire (switched)
Now, when i wire it up, the relay does click but the lights won't come on, i tried with the other relay and same thing. But both the relays work on the other set.
On the lights, the blue is the ground and the braided white is the hot.
I'm not a noob with electrical i know what I'm doing, but i can't figure this out!!
mike_b49431 is offline   Reply With Quote
Old 09-21-2006, 08:09 PM   #2
IIdiceII
Member#: 90438
did u ground the light bulbs properly? iirc, you have to take apart the lamp and install the bulbs completely. like ground them etc.
IIdiceII is offline   Reply With Quote
Old 09-22-2006, 10:00 PM   #3
mike_b49431
Member#: 101240
2005 Impreza RS
Crystal Grey
Well I figured out what was wrong. I tried replacing the fust even though it didn't look blown. Low and behold thats what it was. I knew the grounds on the lights where fine because i placed direct 12v power to the black wires that run off the relay and they turned on so.
Need help wireing hella driving subaru0276 Electrical & Lighting 7 12-30-2008 03:50 PM
Need help wiring Hella Horns, Pic inside jonluude Electrical & Lighting 2 01-18-2008 04:19 PM
Wiring Hella 500's? ubshtoopid Electrical & Lighting 13 08-30-2004 12:33 PM
Help wiring Hella 500's skyliner33v General Forum Archive 2 01-14-2001 06:47 PM
HELP! Wiring Hella 500's STORER Interior & Exterior Modification 5 11-12-2000 10:40 AM
