Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 09-21-2006, 10:49 PM   #1
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Default Sample EcuTek boost map for EBCS please.
Problem: My 2.5 hybrid automatic with td06h-18g has issues with compressor stall during PTFB (impossible to drive around the issue). I'm running an EWG with a 1.3bar spring and an MBC. I'll be going back to the EBCS and the 1bar spring. My tuner says we could try to get my car to run WG pressure at anything below 80% TP, and then under ~WOT we could have it boost up to it's usual ~1.7bar (meth injection).
I'd really like to make sure the WG stays slammed shut during WOT until the 1.7 is reached - kinda like how it works with the MBC - can someone give me an example of how this is done so I can relay it to my tuner? Thanks.
PeteDucati is offline   Reply With Quote
Old 09-22-2006, 05:35 PM   #2
Ben-EcuTeK
Member#: 57867
1999 Volvo
Well, can I suggest getting a 3 ports Wg solenoid and a remap?
You should not have ANY issue and would be a lot safer to leave it to the ECU to decide to cut the boost if any issue occurs.
Ben-EcuTeK is offline   Reply With Quote
Old 09-22-2006, 06:40 PM   #3
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
That goes without saying.. this is the issue I was originally having with the 1bar and the 3 port solenoid after the car was EcuTek'd.
Originally the car was tuned with the EBCS, 1bar spring, and a 20g. The WG would begin creeping open at 1bar - full boost was 1.4bar. This is more for my tuner, in the event he has any problems tuning it the way I'd like, i.e., tooling around town, 1 bar, mash the throttle - 1.7bar 'till redline.
I know the 3 port solenoid is capable of keeping the EWG shut 'till 1.7bar, even while running a 1bar spring. I'm just looking for an example to help the tuner when the re-tune happens.. 'cause the last tune with the EBCS didn't work that way.
Old 09-22-2006, 06:43 PM   #4
Ben-EcuTeK
Member#: 57867
1999 Volvo
well, the easiest way is for him to contact me and I can supply with example file.
Perrin EBCS & Boost Map TurbojonLS UTEC 4 04-19-2006 03:44 PM
FS: ECUTEK mapped for Turbo Back-02 5sp rexkat Bay Area Impreza Club Forum -- BAIC 1 09-14-2004 05:36 PM
FS: 02 Vishnu Ecutek mapped for TBE uppipe rexkat Bay Area Impreza Club Forum -- BAIC 4 09-07-2004 07:07 PM
Progressive Boost Map for Newb UTEC Tuners - ver 4.2 OLF only Blennophobic Engine Management & Tuning 6 04-17-2004 08:10 PM
Timing and boost maps for Sti 2dmnfst Engine Management & Tuning 0 02-10-2004 02:56 PM
