Old 09-22-2006, 02:08 AM   #1
shaolin_racer
Member#: 85858
2004 STi
Default Methanol Injection + AVC-R
Sorry if this is a noob question. But long story short, I used and AVC-R to control boost creep in my 04 WRX + VF34 and it worked very well. I now have The same set up from my WRX on my 04 STi.
I was wondering if any one has considered the possibility of using the scramble boost feature on the AVC-R along with methanol injection. Does seem like a good idea? I can't think of any cons at this time, but I am still learning alot about this car. Any info would be greatly appreciated.
Thanks in advance.
shaolin_racer is offline   Reply With Quote
Old 09-22-2006, 05:37 AM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Boost controllers don't control boost creep. That's the whole idea behind boost creep. It's a mechanical problem that can't be solved with a boost controller.
Does the avcr control boost dependent on rpm? I know it's not really a big deal, but being able to control the boost via rpm(and throttle position) can help you put your turbo run in the efficiency range you want at a given rpm. Not that the avcr isn't a good boost controller, and I'm sure it would work fine. Your setup just might run more efficiently,and you might get a lot more power in certain rpm ranges if you have the ability to change the boost based on rpm.
peace
Old 09-22-2006, 08:36 AM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Yes you can configure boost control via engine RPM with the AVCR; but no TPS based boost control (which is my biggest gripe with the product). Also, the AVCR system includes a fantastic “blocker-style” solenoid valve which greatly outperforms the stock bleeder system. That said, it does/can help to resolve the common problems associated with boost control over the OEM system such as creep, redline taper, and helps to speed spool-up.
That said however, the AVCR is an entirely standalone system which isn’t communicating with your EM platform. So attempting to use the “scramble” feature could be neat, by increasing boost pressure and potentially enabling a meth injection system for a given period of time, but there would be no way to tune for the occurrence of the meth injection as your EM wouldn’t know when the “scramble” switch was in use.
<-AVC-R + Ethanol Injection user
xcntrk75 is offline   Reply With Quote
Old 09-23-2006, 05:36 AM   #4
benw
Member#: 103320
1998 swapped
Forester L
Not always.
http://www.kineticmotive.com/node/16
benw is offline   Reply With Quote
Old 09-23-2006, 05:08 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
Notice how it says perceived.....<edit>
peace
Old 09-23-2006, 06:20 PM   #6
flycaster
Member#: 60142
2011 WRX
Grey
Not really. Assuming you have been properly tuned for the injection, what you really need are two separate boost maps, one with and one without methanol.
An actual map, that has been tuned specifically for the application, is much safer than using "scramble boost." All SB does is to momentarily turn up the global duty cycle percentages by whatever factor you enter in. In this regard, it is identical to Start Duty, except it is not gear dependant. Turn it up just a little too much, and you will seriously overboost in the taller gears. Baaad.
flycaster is offline   Reply With Quote
Old 09-24-2006, 02:39 AM   #7
benw
Member#: 103320
1998 swapped
Forester L
peace
uh yeah. perceived as in people thinking it's a mechanical condition. did you read the article? it's from a rather credible source.
Old 09-24-2006, 05:38 AM   #8
hippy
Member#: 36528
2002 Impreza Wrx
It doesn't matter if I read the article, just the title, or neither(no offense). I was talking about boost creep, the article was not.
peace
93 oct, E85, +Methanol injection, Race fuel, Straight methanol -What's the hierarchy? SharpByCoop Proven Power Bragging 74 04-10-2010 11:32 AM
Fuel injection at TB vs. methanol injection swerv_on Water/Methanol Injection, Nitrous & Intercooler Cooling 2 02-04-2010 10:37 PM
Water/Methanol Injection or Race Fuel or Both ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2005 06:35 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-01-2004 05:52 PM
Derek Devises Water/Methanol Injection mistaboosta Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-01-2004 04:51 PM
