Welcome to the North American Subaru Impreza Owners Club Sunday January 25, 2015
Old 11-02-2001, 05:50 PM   #1
mikesoob7
Member#: 2500
Default Stalling
Hi,
I've got a '91 Legacy that stalls or just about stalls after the rpms fall by letting the clutch out. I've pulled all the vacuum hoses I can find, plugged the end and revved the engine to try and duplicate the effect, allways the same, it just about stalls. This happens in any temperature range. If it isn't air it's got to be fuel. Could a low pressure fuel pump do this only at low rpms?
Mike
mikesoob7 is offline   Reply With Quote
Old 11-02-2001, 07:33 PM   #2
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
It could be as simple as a dirty throttle bore. I hate to sound like a jerk, but if you don't know what you're doing, you're probably just going to cause yourself problems in the long run. Take it to a competent mechanic you trust and let them at least diagnose it for you. Then you can make an informed decision if you are capable of fixing it or not.
yamarocket630 is offline   Reply With Quote
Old 11-03-2001, 01:52 AM   #3
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
Post
could be a dirty throttle body, a toasted O2 sensor... have you done a tune up(plugs, wires, cap, rotor) recently/ever? it's probably just some basic maintence item...
SoobATV is offline   Reply With Quote
Old 11-03-2001, 03:31 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
IIRC scoobies have been DIS(Distributorless Ignition System) for a VERY long time. But yes there is a multitude of possible problems.
jeremy
Old 11-03-2001, 05:00 AM   #5
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Lightbulb Simple check...
Make sure all your vacuum lines are all connected properly, and that there are no vacuum leaks as well.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 11-17-2001, 12:20 AM   #6
mikesoob7
Member#: 2500
Default Solved
Found out it was the Idle Air Screw. Would have taken me years to figure that one out, thanks for all the replies though.
Mike
My car stalled today (note: not I stalled my car) scaryfastskier Mid West Subaru Owners Club Forum -- MWSOC 2 11-06-2002 04:57 PM
High stall torq convertor? KEVINL SVX Forum Archive 0 05-28-2001 01:53 AM
Stalling Outback Poseidon Normally Aspirated Powertrain 1 05-25-2001 01:31 AM
Small car parking stalls.... Penphoe Vancouver Impreza Club Forum -- VIC 13 01-29-2001 06:48 PM
No speedo, CE light and stalling - Help? BoomerRS New England Impreza Club Forum -- NESIC 20 12-06-2000 09:55 AM
