Old 03-26-2009, 04:53 PM   #51
kwan_1104
Member#: 127781
^^^ I asked ACT about that and they said their pressure plates weigh about the same as stock
kwan_1104 is offline   Reply With Quote
Old 03-26-2009, 05:06 PM   #52
ragejed
Member#: 76817
2005 WRX
Weird, what the hell would be causing the noise then?
ragejed is offline   Reply With Quote
Old 04-07-2009, 11:57 PM   #53
kh15
Member#: 132400
im about to replace the stage 1 clutch a just put in with ANOTHER brand new flywheel and brand new OEM clutch! If i still get this noise im going to go nuts! I just dont understand for the life of me how this can possibly happen if you replace a worn clutch and flywheel with a brand new clutch and flywheel of the same make, model, everything!
This may be a dumb question but i dont care...Is their any chance that if the noise was coming from stress for some reason, that it would cause engine damage?
kh15 is offline   Reply With Quote
Old 04-08-2009, 03:01 AM   #54
caterpill
Member#: 27136
I'm not sure if you guys know.. but the noise.. is NORMAL.
Live with it!
caterpill is offline   Reply With Quote
Old 04-08-2009, 09:32 AM   #55
unclemat
Member#: 114530
2005 LGT 6MT wagon
Maybe normal, but what exactly creates the noise? Gears that suddenly are not damped by the new clutch?
FWIW, my setup quieted significantly over 2k miles. It's there, but doesn't bother me anymore.
unclemat is offline   Reply With Quote
Old 04-08-2009, 12:47 PM   #56
chapstien
Member#: 68284
1988 Corolla SR5
0-points
I have been told it is from the flywheel being thinner, and it vibrates easier. Sort of acting like a speaker.
chapstien is offline   Reply With Quote
Old 04-10-2009, 07:21 PM   #57
kh15
Member#: 132400
not if you replace the flywheel with a brand new oem wheel
Old 04-14-2009, 09:36 PM   #58
Supafast
Member#: 68441
2005 WRX
I find mine is inconsistent, some days it's louder than others and I get the shudder coming back every once in a while.
Supafast is offline   Reply With Quote
Old 04-18-2009, 05:41 PM   #59
kh15
Member#: 132400
brand new oem flywheel and clutch going in this Tuesday hopefully that will stop this noise! ....such a PITA!
Old 04-18-2009, 06:56 PM   #60
kwan_1104
Member#: 127781
^^ Keep us posted!
Old 04-18-2009, 10:58 PM   #61
kh15
Member#: 132400
^^ Keep us posted!
ya i will! while my wallet shrivels up
Old 04-22-2009, 10:19 PM   #62
kh15
Member#: 132400
had it installed yesterday and the noise is GONE! !!!!!!!!!!!!!
Old 04-22-2009, 10:34 PM   #63
kwan_1104
Member#: 127781
good for you man....
did you have brand new oem flywheel the first time or did you just resurface the stock one at that time?
cause in your case, it seems like its the clutch thats causing the noise?
Old 04-24-2009, 07:20 PM   #64
kh15
Member#: 132400
yep new flywheel both times,
the noise was the clutch, very strange though since the stage 1 clutch looked perfectly fine when we took it off..
Old 04-24-2009, 08:22 PM   #65
unclemat
Member#: 114530
2005 LGT 6MT wagon
Did you install same brand/type of clutch this time?
EDIT: I just noticed you mentioned you put OEM this time
Old 04-26-2009, 03:00 AM   #66
kh15
Member#: 132400
my oem clutch was slipping so i had the a...
new oem flywheel, exedy stage 1 clutch
that sounded like my tranny was going to fall out of my car so i bought and had installed...
new oem flywheel, new oem clutch
the noise is now gone but i miss the pedal feel of that stage 1 clutch. Im hoping the ss clutch line and superblue i ordered will take car of that though
Old 06-12-2009, 04:13 PM   #67
ogboot
Member#: 170906
psm
just had the exedy stage 1 put in, reputable mechanic said oem flywheel looked ok. getting decel noise, just gonna live with it.
ogboot is offline   Reply With Quote
Old 06-19-2009, 02:24 AM   #68
Wes_FSTGDB
Member#: 59400
2013 335XI MSport
2008 BMW 335XI Space Grey
I have a 2004 WRX STi with an upgraded ACT HD Street Clutch and Gruppe-S light weight flywheel (basically same exact thing as the ACT one) and I have the same exact noise, yours seemed a little more harsh in the video though. To top it off I have the Cusco motor mounts and Cusco tranny mount. It's been about 8,000 miles and the car is doing fine.
I guess I don't have to freak out anymore, it appears the noise is normal and just part of the lightweight flywheel.
I love Nasioc, all my answers are right in front of me
-Wes
Wes_FSTGDB is offline   Reply With Quote
Old 06-19-2009, 06:01 AM   #69
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
ACT streetlight FW & Exedy Stage 1 clutch. Group-N, Kartboy & TiC driveline mounts/bushings from stem to stern.
"Quiet" under accel (staying out of the EWG), but sounds like a dumptruck's Jake brake when you're off the gas.
Kungkungkungkungkungkungkung!
Spenk is offline   Reply With Quote
Old 06-19-2009, 08:00 AM   #70
ragejed
Member#: 76817
2005 WRX
-Wes
You should try the beatrush mounts, holly hell are those solid! makes my car sound like something is blowing up when i let off the gas!
Old 06-23-2009, 12:06 AM   #71
kwan_1104
Member#: 127781
A lil update:
BRAND NEW OEM CLUTCH
BRAND NEW OEM FLYWHEEL
NOISE GONE!!!!!
Old 06-23-2009, 01:25 PM   #72
ragejed
Member#: 76817
2005 WRX
A lil update:
NOISE GONE!!!!!
Who installed it?
If it was you, how did you line up those lil marks of balance on the PP and flywheel? opposite or together?
Old 07-01-2009, 02:37 PM   #73
hipnotik978
Member#: 134450
2013 BMW 335i
I seem to be having the same problem as you guys. Only difference is say I'm getting off an offramp push in the clutch take it out of gear it is still clunking. Best way I can describe the noise is putting a baseball card in the spokes of bicycle tire. Do you think I should get this checked out or is this normal?
03 WRX
OEM Flywheel & Clutch replaced about 25k ago (noise just started happening 3k miles ago)
hipnotik978 is offline   Reply With Quote
Old 07-01-2009, 02:38 PM   #74
hipnotik978
Member#: 134450
2013 BMW 335i
dbl post
Old 07-09-2009, 12:08 PM   #75
my05legacy
Member#: 106873
2013 sti hatch
cbs
add me to club.... oem clutch and flywheel
my05legacy is offline   Reply With Quote
Noise from Clutch/Flywheel, and weird short shifter problem MYfirst00 Transmission (AT/MT) & Driveline 1 05-28-2009 09:45 PM
Advice: Clutch + Flywheel installed before tune, or after tune? A difference? rhinotech Transmission (AT/MT) & Driveline 7 06-20-2007 01:26 PM
Seeking Input: Bad noise after clutch install mx_9 Transmission (AT/MT) & Driveline 3 06-04-2007 02:13 PM
strong vibrations at low rpms after clutch/flywheel install happasaiyan Transmission (AT/MT) & Driveline 5 05-02-2006 06:54 PM
Help! Noisy idle after Exedy Clutch/Flywheel install Hedge Transmission (AT/MT) & Driveline 4 11-11-2002 03:53 PM
