Old 02-06-2010, 02:04 PM   #126
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I have tried a few things this morning to see if I can make noise go away.
1. Re-tightened rear Kartboy diff. bushings.
2. Tire pressure of 35psi F and 32psi R
3. Installed drive shaft bushings (unrelated)
4. Checked rear diff. fluid level
Will report back later...
Old 02-06-2010, 05:11 PM   #127
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
No improvement made even after changing tire pressure as many have suggested.
Old 02-07-2010, 04:18 AM   #128
Tubbs540
Member#: 197216
2006 STI
06 Range Rover Sport SC
Originally Posted by Ryan314 View Post
^Good info... I hate my decel noise with a passion.
Originally Posted by REVNU View Post
I hear ya man. Some days mine is noisier than others. It sounds like a REALLY bad heatshield rattle most of the time and some days it sounds like rocks in the transmission. Good luck, I hope you get it fixed. I plan to do mine here in the very near future. For now I just turn up the radio louder and I don't hear it.
Yep all this sounds like mine.. I guess its just normal. I just dont decelerate in gear as much cause it sounds like crap some days haha. Others its alright. Found myself coasting a lot more lol
Tubbs540 is offline   Reply With Quote
Old 02-09-2010, 12:20 AM   #129
wirolla
Member#: 109725
2001 GM6
SRP
Ah I will join this club. I have an 01 RS with a streetlite flywheel and an exedy stage 1 clutch. It sounds like absolute hell!
wirolla is offline   Reply With Quote
Old 02-09-2010, 01:26 AM   #130
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
For those who are NOT having the problem with aftermarket clutch/flywheel, what kind of set up do you have and where did you get the clutch/flywheel replaced?
Old 02-10-2010, 12:58 AM   #131
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Would be nice if vendors like Andrewtech or DS1 can give their opinion about the problem a lot of people seem to be having.
Any fix out there aside from OEM parts?
Old 02-12-2010, 07:20 AM   #132
jalweber
Member#: 224809
I don't have aftermarket and I didn't even have the clutch/flywheel replaced... The noise just started one day... wasnt there when I got to work, was when I left... really weird.
I guess it could not be related to the driveline, I did find a crispy mouse on top of the motor.....
jalweber is offline   Reply With Quote
Old 02-12-2010, 07:53 AM   #133
Harthorn
Member#: 211429
2005 WRX
I have exactly the same noise, I have an NPC organic clutch and yes its done that from day one to over 1 year now. Its normal.
Harthorn is offline   Reply With Quote
Old 02-12-2010, 04:51 PM   #134
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Just received two plates where rear subframe mounts to (outrigger bushing goes there). Heard some people fixed the noise by either replacing or flattening them out. Mine was badly bent as you can see below:
Old 02-14-2010, 01:50 AM   #135
hatchd
Member#: 201307
2002 wrx
wrb
This is exactly what mine sounds like, esp. the heatshield rattle reference. Does yours do this only on decel or any other time? Mine will do it when shifting gears (only 1-3, 4-5 make no noise) and also it will randomly happen when I'm sitting in neutral as well. Annoying as hell, especially rolling in a parking lot when there's 20 people around looking at me expecting my car to fall apart.
As far as my set up, completely stock. No aftermarket anything. Tried the tire pressure thing and it seems to slow it down for a day or two and then it seems to pick up as bad as before.
hatchd is offline   Reply With Quote
Old 02-14-2010, 02:54 AM   #136
REVNU
Member#: 82147
2005 WRX Sedan
It's only on decel that I have the noise. As long as I have my foot on the throttle a little it won't make the noises.
I'm on an Exedy Stage 1 w/OEM flywheel. NEVER had this problem with the OEM setup, the day I put the Exedy in is the day all hell broke loose.
It sounds like you may have other issues if you're getting the noise between shifts and neutral. You actally may have a heatshield rattle or something else loose.
REVNU is offline   Reply With Quote
Old 02-14-2010, 08:47 AM   #137
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
I'm running an ACT SB4-HDSS clutch kit (organic street disc w/heavy duty pressure plate) and the 13.3lb Exedy flywheel for the STi (I did a 6spd swap). I installed it myself, and the deceleration noise, while noticable, is quiet. Occasionally I get it under slight throttle as well in 3rd or 4th around 2.5-3K RPM. When I get it then it sometimes sounds like a really loud rattley heat shield... Just for yucks I'm gonna check the up pipe and header heatshields when I helicoil my rear crossmember mount bolts.
ProdriveDreams is offline   Reply With Quote
Old 02-14-2010, 03:01 PM   #138
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
guys, plates I installed did not HELP eliminate/reduce grinding noise.
Old 02-15-2010, 12:21 PM   #139
REVNU
Member#: 82147
2005 WRX Sedan
That's surprising...
Old 02-15-2010, 01:29 PM   #140
Ryan314
Member#: 82989
Hybrid EJ257
Got my hopes up for a second...
Ryan314 is offline   Reply With Quote
Old 02-15-2010, 02:11 PM   #141
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
same here... spent ~$40 on a nice shiny plates that I did not need, but car looks nicer with them installed.
Old 02-15-2010, 07:34 PM   #142
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I actually noticed both of mine /\ were bent towards the subframe on the edges so I straightened them out. They weren't as rusty as yours though. That was a while back though and it didn't work for my noise. I've been under the car many times with it on the lift at work and my noise is coming from inside the tansmission somewhere. It could be in the clutch basket and I will be pulling the entire engine and installing it into a fwd L I just bought. I'm wondering if the fingers might be resonating and smacking the release bearing. Or possibly the springs in the clutch disc are worn and letting the input shaft spin back and forth too much. Maybe I'll find something loose or rubbing in the clutch somewhere. I also plan on a new release bearing just in case.
2slofouru is offline   Reply With Quote
Old 02-20-2010, 07:47 AM   #143
53WRX
Member#: 161014
I have this decel grinding noise immediately after exedy pink racing clutch and billet steel LWFW were installed. Pissed at the noise I found this thread. Swinging between living with it and going back to OEM, but tbh if the noise isn't something horrible breaking I would just feel better ! Interestingly enough EVO's, Nissans etc etc with exedy or uprated clutch and LWFW's get the exact same noise.....but then again not all...hence the going round in circles !!!!!!!!!!!!!!!
53WRX is offline   Reply With Quote
Old 02-20-2010, 09:02 AM   #144
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Not surprising IMO, my noise is 100% clutch related as it only started after putting in the Exedy OE kit.
Snowphun is offline   Reply With Quote
Old 02-21-2010, 02:25 PM   #145
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
/\ Yep, those two vids sound very similar to mine. Probably the same cause. I'm gong to check the condition of my clutch when I swap my engine into the other impreza. I'll be running fwd temporarily though so I'll have to buy an exedy oem clutch to fit that transmission. Probably won't have any noise because I won't be running my exedy lw flywheel.
Old 02-22-2010, 01:10 AM   #146
REVNU
Member#: 82147
2005 WRX Sedan
I wouldn't count on it. A lot of people still get the noise even with the OEM flywheel, myself included. It's the CLUTCH assembly that is the problem, the LW Flywheel just amplifies the "problem".
If you don't get any noise consider yourself very lucky.
Old 02-22-2010, 08:37 AM   #147
Ryan314
Member#: 82989
Hybrid EJ257
^So if I was to leave my 14 lb ACT flywheel in, and swap out the Exedy Stg 1 clutch for OEM, the noise would go away?
Old 02-22-2010, 12:31 PM   #148
REVNU
Member#: 82147
2005 WRX Sedan
I doubt it. You would probably encounter other issues from the LW flywheel. Like chatter and more gear whine on decel. The only real way to find out is try it yourself. There have been a few lucky people I'm sure that have upgraded/swapped their clutch and/or flywheel that have minimal or no noticeable noises.
I'm not sure why people think when they start lightening and changing out drivetrain components that their car is going to retain that factory oem quietness. I can understand the annoyance with the Exedy OEM Clutch, but that has been discussed about why it (probably) makes the noises it does.
Again, if you want that OEM quietness/smoothness, then your only option is to go back to all OEM parts in the drivetrain. That still isn't a 100% guarantee that will remedy the problem. It's known that our cars make lots of weird noises even in stock form; you either live with it, spend 100's or even 1000's of dollars trying to remedy it, or go buy a different car.
Old 02-22-2010, 10:13 PM   #149
mack519
Member#: 230440
2006 WRX TR
Same thing on my 06 WRX, previous owner was a cheap ass and used aftermarket clutch! Oh well more incentive to swap in 6 speed!
mack519 is offline   Reply With Quote
Old 04-23-2010, 10:29 PM   #150
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Anyone has found a fix for this problem yet?
Noise from Clutch/Flywheel, and weird short shifter problem MYfirst00 Transmission (AT/MT) & Driveline 1 05-28-2009 09:45 PM
Advice: Clutch + Flywheel installed before tune, or after tune? A difference? rhinotech Transmission (AT/MT) & Driveline 7 06-20-2007 01:26 PM
Seeking Input: Bad noise after clutch install mx_9 Transmission (AT/MT) & Driveline 3 06-04-2007 02:13 PM
strong vibrations at low rpms after clutch/flywheel install happasaiyan Transmission (AT/MT) & Driveline 5 05-02-2006 06:54 PM
Help! Noisy idle after Exedy Clutch/Flywheel install Hedge Transmission (AT/MT) & Driveline 4 11-11-2002 03:53 PM
