Old 09-24-2006, 12:25 PM   #1
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
Default Ecuktek - is this a good price
would an ecu trade and $250 be a good deal for a ecutek ecu road-tuned by Bill from I-Speed for a stage 2 (uppipe/downpipe, exhaust, intake) setup?
what do you think?
arco is offline   Reply With Quote
Old 09-24-2006, 01:12 PM   #2
arco
Member#: 57156
2007 V.8 207 STi
bump. need help
Old 09-24-2006, 08:12 PM   #3
Freon
Member#: 88322
2009 BMW 135i
I wouldn't run someone else's specific tune on your car. But its a good deal for the Ecutek license, since they're $600 new.
Freon is offline   Reply With Quote
Old 09-25-2006, 02:44 AM   #4
arco
Member#: 57156
2007 V.8 207 STi
it fits my car perfectly except for the intake which i may be getting soon. it wont matter though
Old 09-25-2006, 10:56 AM   #5
Tea cups
Member#: 103136
Doesn't matter even if you have identical mods. Each car reacts differently to a tune. That is why there are good gains to be had from a custom tune. So, just because car "A" has good numbers and results with a custom tune, doesn't mean you can place that tune on car "B" which has identical mods and it will be just as powerful and detonation-free. In fact, it's possible that car "B" could have a whole lot of problems with that tune depending on how aggressive it was.
Tea cups is offline   Reply With Quote
Old 09-25-2006, 11:07 AM   #6
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Yeah, not a good idea at all. It would be good if you were planning to have it tuned at your local ECUTek dealer, but not so good if your not planning on having it tuned for your car.
But hey its your car do what you want to.
ShaggyGT is offline   Reply With Quote
Old 09-25-2006, 11:43 AM   #7
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
as mentioned, get the tune redone at your local ecutek dealer....
jigga is offline   Reply With Quote
Old 09-25-2006, 02:05 PM   #8
arco
Member#: 57156
2007 V.8 207 STi
so what would you say would be the better way to go as far as EM?
Old 09-25-2006, 02:08 PM   #9
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
enginuity
illmatic is offline   Reply With Quote
Old 09-25-2006, 02:22 PM   #10
ShaggyGT
Member#: 19221
If your not planning to have it tuned then stick with your stock ECU. But if you want the full potential from your car get ECUTek tuned at your local ECUTek dealer. There is nothing wrong with ECUTek, but it is stupid to try and run someone elses tuned map and it is a waste to run a basemap when you can get a ton more power from having a custom tune to your car.
I typically see a 40-60+ft/lb torque gain from me tuning with ECUTek.
-Matt
Old 09-25-2006, 02:25 PM   #11
ShaggyGT
Member#: 19221
Here are some before and after results from me tuning with ECUTek:
'04 STi w/ TBE and ARC Air Box:
'06 STi w/ TXS TBE and K&N Short Ram Intake:
The before on both graphs were on the stock ECU with no reflash. Both cars were tuned on 18psi tapering at redline on 93 octane pump gas. Both flatline at 11.5:1 A/F. The '06 graph is actually the first pull after loading in one of my tuned base maps. I will grab the final graph off the dyno tommorow and post it up as it doesnt fall off up top. I finished up with that one at 315ft/lbs torque and 28x whp.
-Matt
Is this a good price on this cpu/mobo combo? Wraith Off-Topic 3 02-25-2006 11:35 PM
Is this a good price for a WRX??? NASDAQ Newbies & FAQs 23 11-27-2001 11:53 AM
Is this a good Price for Light pulleys? LttLDGN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-16-2001 04:52 PM
('93-'01) is this a good price? phatroksek Impreza Forum 2 10-13-2001 09:05 AM
Is this a good price for a Japan EJ20T with turbo? ImprezedRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-03-2001 01:06 PM
