Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 09-24-2006, 01:50 PM   #1
Magda
Member#: 126971
Question Fuel
Hey guys,
I am planning on getting the Tribeca, however I am debating because it appears (after I've done some research) that premium fuel is preferred. Can you tell me what fuel is everyone using?
Magda is offline   Reply With Quote
Old 09-24-2006, 04:40 PM   #2
only1agam
Member#: 56183
well working at a subaru dealership subaru recommends premium for best performance.. if you dont want the best performance just use regular no biggie.. price wise i believe i had calculated it out.. paying .20 cents more per gallon at the end of a year going about 15000 miles a year it was less than $200 a year extra.. not too bad at all
only1agam is offline   Reply With Quote
Old 09-24-2006, 05:43 PM   #3
nycb9
Member#: 110054
My Tribeca runs fine on regular, but mileage and performance are better when using premium...just like any other vehicle. Remember that Subaru recommends, not requires, premium fuel for the Tribeca.
Don't let this stop you from purchasing an excellent vehicle!
Regards...Joe
nycb9 is offline   Reply With Quote
Old 09-25-2006, 02:00 AM   #4
kooldak
Member#: 119565
2007 Trib 7P LTD, SE
Harvest Gold
I use Premium. Like only1agam, I don't see that it is that significant a difference in cost over a years time.
kooldak is offline   Reply With Quote
Old 09-25-2006, 09:50 AM   #5
RallyKid
Member#: 2215
I think you should get it too. I belive it will pull a rally car behind it as well
RallyKid is offline   Reply With Quote
Old 09-25-2006, 11:15 AM   #6
kooldak
Member#: 119565
Harvest Gold
3500 lbs with the full towing package, 2000 lbs without.
Old 09-25-2006, 12:06 PM   #7
RallyKid
Member#: 2215
does the towing package include a class 1 or 2 receiver?
Old 09-27-2006, 10:34 AM   #8
kooldak
Member#: 119565
Harvest Gold
Class 2 w/transmission oil cooler
Old 10-01-2006, 10:31 PM   #9
Magda
Member#: 126971
Thank you all for your replies
Old 10-02-2006, 09:02 PM   #10
HB_Dad
Member#: 45190
2014 Impreza Sport L
A full tank of premium will only set you back about a buck a tank over mid and maybe $1.50 over regular. I think you can splurge a little bit. If not, don't supersize next time you hit the McDonalds and you'll break even.
HB_Dad is offline   Reply With Quote
Old 10-15-2006, 11:42 PM   #11
legandrex
Member#: 52232
05's GT-Sedan and B9
Atl.Blue-B9 Silver-sedan
I have noticed ours runs better on premium. Maybe some of it is in my head, but I figure it's not that much $ over the course of a year.
legandrex is offline   Reply With Quote
FS : 52mm glowshift air/fuel ratio gauge cheap!! 04wrxGreg Exterior/Styling 4 06-13-2010 09:09 PM
stock fuel injecters/450hp VS more better fuel injecters/450hp FuJi K Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 03-25-2001 12:29 AM
Oil and fuel starvation in tight turns? Are there baffled oil pans and fuel tanks? Digital_Boy Normally Aspirated Powertrain 6 01-17-2001 08:01 PM
Removing fuel tank & Fuel cell foam dbrown Technical Forum Archive 3 08-13-2000 08:16 AM
Fuel Injectors / Fuel system JC SPORTS Technical Forum Archive 75 07-14-2000 08:51 PM
