Old 04-11-2013, 11:00 PM   #14501
Froseph
Member#: 351026
2008 2.5i Hatchback
Dark Gray Metallic
Default will it work?
[quote=Himynameisgreg;36151548]that's a pretty good modlist. i would like one of those treble racing rear spoilers, but i can't bring myself to buy one yet.
Suspension/Brakes:
--- Stoptech Stainless Steel Brake Lines F&R
I wanted to put these on my 2.5i model that has F&R disk brakes. would you know if the ones you used were the wrx model brake lines? I can't seem to find one specifically for the 2.5i so I figured that the wrx ones should fit without a problem.
Froseph is offline   Reply With Quote
Old 04-11-2013, 11:01 PM   #14502
Froseph
Member#: 351026
2008 2.5i Hatchback
Dark Gray Metallic
Suspension/Brakes:
--- BC Racing BR Coilovers
--- Rallitek 19mm Rear Sway Bar
--- Rallitek 22mm Front Sway Bar
--- Kartboy Solid Front Endlinks
--- WRX Front Calipers
--- Hawk HP+ Rear Brake Pads
--- Hawk HP+ Front Brake Pads
--- DBA 4000 WRX Slotted Front Rotors
--- Powerslot Slotted Rear Rotors
--- Amsoil Brake Fluid
Old 04-11-2013, 11:02 PM   #14503
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Here's my latest addition..
Tuned to the stage 1 - 87 octane map with stock intake.
Power is now immediate and smooth. Starts to really pull at 4k. I'm also noticing an increase in gas mileage. I will be tuning to 91 octane after this tank.
I know the AP dyno isn't 100% accurate but I thought it would be fun to do a few pulls in 3rd gear. My starting RPM was 2,000 and ending at 5,000. Results are definitely taken with a grain of salt, but they aren't too far off from other dynos done. The engine is now more 'alive' feeling. When you hit 3k it doesn't feel like it has to shift or that you are hurting it.
This> http://www.rs25.com/forums/f5/t71821...ned-today.html
This> http://www.efilogics.com/dyno/graph....rgb1=000000255
Here's my AP results. All of my test runs were all in the same ballpark within 5hp/tq of eachother.
fancyfootwork15 is offline   Reply With Quote
Old 04-11-2013, 11:17 PM   #14504
Trustkevin13
Member#: 259184
2008 Subaru WRX
^^^^ AP on a non-turbo! thats so wicked! I never knew that! I was iffy when getting mine cause I wasn't sure how good it was with an Auto, never looked back since.
Trustkevin13 is offline   Reply With Quote
Old 04-11-2013, 11:31 PM   #14505
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
For sure! These cars are slow but a tune makes a world of a difference! Should probably get an AP for my girls 04 WRX next.
Old 04-12-2013, 09:41 AM   #14506
Digital Dillon
Member#: 288727
2008 WRX premium
Obsidian Black Pearl
Originally Posted by Froseph
Suspension/Brakes:
What year 2.5i do you have? 08+ has the same calipers as the WRX. Everything will "work" though.
Digital Dillon is offline   Reply With Quote
Old 04-12-2013, 10:24 AM   #14507
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Originally Posted by Froseph View Post
Suspension/Brakes:
Looks good. Minus the BCs. I'd advise against the BC coilovers. I also think the DBA rotors may be overkill. Powerslots front and rear should get you stopped pretty good.
Good point. The calipers/pads are the same. But the 2.5i rotors are smaller. WRX rotors won't fit unless you get WRX caliper brackets.
JourdanWithaU is online now   Reply With Quote
Old 04-12-2013, 12:00 PM   #14508
bdoyle87
Member#: 292978
2011 Impreza 2.5i HB
Marine Blue Pearl
Well, after a year and a half of owning my car, I've finally made it look less homely. Sparco Assetto Gara wheels in bronze, 35% tint up front, 18% tint in the back, and a muffler delete. Not the best pics, just some quick shots after washing.
bdoyle87 is offline   Reply With Quote
Old 04-12-2013, 12:24 PM   #14509
scubie_craig
Member#: 282209
2007 Impreza 2.5i
UGM
Fancyfootwork, where did you find your Accessport? I'm assuming you purchased it used from somebody? They don't make them anymore, do they?
scubie_craig is offline   Reply With Quote
Old 04-12-2013, 01:47 PM   #14510
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
Used, they are discontinued.
Old 04-12-2013, 02:20 PM   #14511
scubie_craig
Member#: 282209
2007 Impreza 2.5i
UGM
That's what I thought. Good find then!
Old 04-12-2013, 11:28 PM   #14512
Chuckls
Member#: 280696
2005 WRX
Picked this up for my beastly offroading 2.5
Chuckls is offline   Reply With Quote
Old 04-13-2013, 02:57 AM   #14513
Vertignasse
Member#: 329445
2011 2.5i Hatch
I think this store still sells a similar device:
http://www.lachuteperformance.com/Index.php?lang=en
From the "Products" section, you can search for parts by brand and model. The staff is usually very helpful, and they should be able to answer your questions in English, even though French is their first language.
Vertignasse is offline   Reply With Quote
Old 04-13-2013, 03:45 AM   #14514
code_hat
Member#: 90896
CO RallyX'er
circuitmotorsports.net
[quote=Froseph;39570784]
Suspension/Brakes:
Yes, the WRX model fits your car.
code_hat is offline   Reply With Quote
Old 04-13-2013, 05:49 PM   #14515
amuri1990
Member#: 346009
2009 Impreza 2.5i
Newport Blue Pearl
Just mounted 4 LED flood lights on my roof rack, driving at night is completely different! They act as awesome worklights too if I need to light an area im working in. Hope the HDR isn't too overbearing, just having some fun :P
amuri1990 is offline   Reply With Quote
Old 04-13-2013, 11:56 PM   #14516
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Specs on the lights?
KartRacer3 is offline   Reply With Quote
Old 04-14-2013, 08:59 AM   #14517
will_kwok
Member#: 327439
2009 Impreza RS
lazy Sunday
will_kwok is offline   Reply With Quote
Old 04-14-2013, 03:21 PM   #14518
fancyfootwork15
Member#: 262503
2008 Impreza 2.5i
$10 shipped for a custom plate relocation kit if anyone wants it
Old 04-14-2013, 03:38 PM   #14519
Platinlord
Member#: 336281
2003 Peanut Wagon
Classic Blue - 23W
Pics? Pn maybe?
Platinlord is offline   Reply With Quote
Old 04-14-2013, 07:01 PM   #14520
amuri1990
Member#: 346009
2009 Impreza 2.5i
Newport Blue Pearl
They're made by Tuff LED Lights, each is 1550 lumens so a whopping 6200 lumens all together. I custom mounted them and wired them to my roof rack to two rocker switches on my center console. I wouldn't dare flash anyone at night with these unless they REALLY were being a jerk cause they're far too bright. But I'd totally suggest setting up a rack for your self! If anyones interested in the full steps I can explain further what I did.
Old 04-14-2013, 09:30 PM   #14521
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Awesome, thanks!
Old 04-14-2013, 10:32 PM   #14522
Slow Scoobie
Member#: 320464
2005 Legacy GT
ABP
Got any pictures of them on at night?
@will_kwok ...your car is sex.
Slow Scoobie is online now   Reply With Quote
Old 04-15-2013, 12:24 PM   #14523
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
Im assuming you tested this first, but wouldn't your sunroof hit the bottom of those when you tilted it up?
Imprezzedwitsubies is offline   Reply With Quote
Old 04-15-2013, 12:46 PM   #14524
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
My 2009 2.5i Newport Blue Pearl
well here's the link to my cardomain since pics wont post for some reason
http://www.cardomain.com/gallery/16167239/
Last edited by Imprezzedwitsubies; 04-15-2013 at 12:55 PM. Reason: Added link to cardomain since pics won't show up
Old 04-15-2013, 04:02 PM   #14525
subbyxinxdistress
Member#: 351304
2006 impreza 2.5i
steel gray metalic
my 06 SGM 2.5i
had to test out the awd lol
subbyxinxdistress is offline   Reply With Quote
What's the widest tire that can be put on the 2.5i? SubieSubie Impreza Forum 20 11-20-2015 10:27 AM
Will the STi Front and Rear Bumper will fit on the 2.5i? GD6Noob Interior & Exterior Modification 7 04-30-2012 09:33 PM
Wheels that fit the 2.5i and the best offset. VIsubi Tire & Wheel 2 06-23-2010 10:19 PM
Test Drove the 2.5i Legacy at SoD maclif Texas Impreza Club Forum -- TXIC 8 06-02-2004 09:42 PM
