Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-24-2006, 05:38 PM   #1
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Default Fuel blending to racegas (91 to 100 octane)
Can anyone post the formula to blend fuel. I mean let say 2 gl of 91 to 100 octane. Since roughly 2 gl is in our reserve tank when the fuel light turn on. How much 101, 103, 105 or even 109 unleaded do I need to make 100 octane. Thanks
ix8vii is offline   Reply With Quote
Old 09-24-2006, 06:34 PM   #2
dibblejr
Member#: 94070
05 LGT
Try sunoco.com, they have mixture charts last I looked.
dibblejr is offline   Reply With Quote
Old 09-24-2006, 11:52 PM   #3
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
does anyone know the difference between pump and motor octane?
Old 09-25-2006, 12:02 AM   #4
hotrod
Member#: 14141
2002 Impreza WRX
Pump octane is properly refered to as R+M/2 ----- that means it is the average of the Research octane and the Motor octane number. Research and Motor octane numbers are based on different testing protocols. The Motor octane is the most important number for a turbocharged highperformance engine.
Most everyone advertises the Research octane number because it is always higher than the Motor Octane by about 6 numbers.
If the advertised octane numbers seem too good to be true they are probably Research Octane numbers. If it is posted on the pump is should be the R+M/2 average octane. If you get the fuel literature from the fuel company they will frequently list both Research and Motor octanes.
The difference between the Research and Motor octane is typically about 6 numbers, so a fuel with a Research octane of 110 will usually have a Motor octane near 94.
Larry
hotrod is offline   Reply With Quote
Old 09-25-2006, 03:26 PM   #5
ix8vii
Member#: 77623
0508 STi OBP
0008 Forester S/LLB
Thanks hotrod, I think I'll be able to do some blending now. VP has 109 but in reality it's 105 R+M/2 to compare on 91 pump. I also found an excel file that would do the blending. Just make sure it's the same octane number on R+M/2.
Tuning on a winter fuel blend? dntouch Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-08-2010 06:10 PM
2008 STI: Turboback and tune - 91 and 100 octane AQ Motorsports Proven Power Bragging 60 01-14-2008 01:11 AM
Norcal: 04 Accesport V1 unmarried with 2 customs maps,GST motorsports 91 oct,100 oct Delta22 Engine/Power/Exhaust 5 04-29-2007 12:32 PM
91 vs. 100 oct map? mrbalwrx UTEC 0 04-09-2007 07:09 PM
Mixing 91 with 100 octane, does anyone have the chart? Shaved Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 04-04-2005 03:40 AM
