Old 09-25-2006, 12:24 AM   #1
slingshot
Member#: 44668
'07 M5
Default weird idle issue...not average idle stuff
After a long drive (10+ hours) I started having this problem.
When rolling to a stop at low speed, car in gear/clutch disengaged, the idle will climb.
When I take the car out of gear, clutch still disengaged, the revs drop to normal idle.
Or, if I come to a complete stop with the clutch still in, car in gear, the revs will drop back to normal idle.
CLUTCH IN, CAR IN GEAR, ROLLING AT LOW SPEED-------IDLE CLIMBS
CLUTCH IN, CAR PUT IN NEUTRAL, ROLLING AT LOW SPEED----IDLE DROPS
CLUTCH IN, CAR IN GEAR, CAR COMES TO A STOP-----IDLE DROPS
This has happened once before, also after a long drive on the highway. But the last time it only happened for a few hours. This time it has gone on for weeks, only this drive was much longer. I believe it may be something to do with the cruise control since that is the only common factor I can think of between the two times this has happened.
my powertrain mods are:
TBE
Stage-2 Access Port
AEM CAI (first time problem happened I didn't have the CAI)
slingshot is offline   Reply With Quote
Old 09-25-2006, 12:57 AM   #2
RP31
Member#: 123574
2005 stuck-in-garage
CGM STi
This sounds like normal operation for the brake booster... Are you sure this was never happening before? My car does it all the time.
RP31 is offline   Reply With Quote
Old 09-25-2006, 01:50 AM   #3
umscooby
Member#: 50902
05 STi
i agree, this sounds normal
umscooby is offline   Reply With Quote
Old 09-25-2006, 02:18 AM   #4
NewSTI
Member#: 104420
05 GarageTuningSTI
BLK/Gold [email protected]
10 hours driving ?!?!?! sounds like out of gas !!! JK
NewSTI is offline   Reply With Quote
Old 09-25-2006, 10:29 AM   #5
wichitalegacy
Member#: 116194
My legacygt does this too but it also runs like crap .
wichitalegacy is offline   Reply With Quote
Old 09-25-2006, 05:24 PM   #6
slingshot
Member#: 44668
'07 M5
I'm not talking about a little vacuum related 200rpm rise, I mean it climbs and climbs, 1500...2000...2500rpm until I take it out of gear or come to a complete stop. This is definitely not normal operation.
1999 2.5RS- Idle issue - O2 sensor weirdness ?? w chapman Normally Aspirated Powertrain 2 03-20-2009 06:37 PM
weird car issues, maybe not related jma_1000 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-23-2008 12:52 AM
weird idle issues. kimira Other Engine Management 13 10-09-2008 01:53 PM
Weird fueling issue. Not enough fuel, add a pump now insanely rich???A/F weirdness. Defiant Autospeed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 11-19-2007 05:30 AM
Weird idling issues help! ImPrEzZzZZA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-01-2005 02:48 AM
