Old 11-03-2001, 01:42 AM   #1
DanMan
Member#: 5009
Default Turbo on its way out?
My turbo is screaming any time it sees boost... I mean a horrid hissing sound thats as loud as a crappy civic exhaust (echoes through the neighborhood)
I'm pretty sure I'm over-reacting, but I have quite an odd problem. I changed back to my stock boost-controller from an MBC tonight. I felt like the car was pulling back timing to much, so I wanted to try stock to remind myself of what it felt like.
When I went out for a drive, the turbo started shreiking as described above. I am sure its the turbo making the shreiking noise.
I observed the amount of boost boost (Greddy tapped off of BPV) and noticed sound occurs only at 0bar or above. It starts right at 0bar and gets progressively louder all the way to the 1 bar peak (bost stock and MBC). One would think it was a leak, but the car is not running ANY LOWER boost than before. Spool also appears to be unaffected.
The same exact noise occurs with either the MBC (which worked fine before) and the stock solenoid. I have no idea what to think other than something is mechanically wrong with the turbo. It's just so odd that no other parameters seem to be affected. The car runs fine as well.
I also have an uppipe installed on the car. I believe it has been leaking slightly at the manifold/uppipe connection. I can hear the gasket flaping around between the flanges (I reussed the stock gasket... bad idea). However, it has always been hardly audible. And I don't see how a on-boost only noise could be caused by any part of the exhaust.
Anybody... please
Dan
DanMan is offline   Reply With Quote
Old 11-03-2001, 02:07 AM   #2
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
sounds like the turbo death whine
Old 11-03-2001, 04:03 PM   #3
DanMan
Member#: 5009
B to the U to the M to the P!
Old 11-03-2001, 05:52 PM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
are you sure your boost gauge hasn't developed a leak?
nhluhr is offline   Reply With Quote
Old 11-03-2001, 06:22 PM   #5
bottlefedwrx
Member#: 9119
12.88 @ 105 mph
Sounds like what my car was going through last month. I thought it was a small vacuum leak, but it turned out that my turbo blades were bent and scraping the side. You should really get that checked out.
bottlefedwrx is offline   Reply With Quote
Old 11-03-2001, 10:18 PM   #6
DanMan
Member#: 5009
ok, its getting much much worse. I have to stop driving the car.
PE1818, injectors, and unichip here I come.
Dan
Old 11-03-2001, 10:52 PM   #7
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Dan
get the 1820 - - -1818 is weak!
alfriedesq is offline   Reply With Quote
Old 11-03-2001, 11:02 PM   #8
DanMan
Member#: 5009
Says who?!?!
I thought it was the same damn thing essentially... just different A/R.
Dan
Old 11-04-2001, 12:23 AM   #9
Twelvz
Member#: 11302
11 GT-R
10.x @130+
I shouldn't have read this post, you guys get me paranoid !
My car hiss' a lot when approaching 15psi, I took the silencer out, that may have something to do with it, but I don't think my turbo is going out (better not b/c its a IHI VF22).
This loud hissing seems normal to me, I have no leaks and I have yet to install my up-pipe.
Twelvz is offline   Reply With Quote
Old 11-04-2001, 12:29 AM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
hissing is different from the whine of death it sounds like a owl screaching almost.
Old 11-04-2001, 12:30 AM   #11
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Says who?!?!
Dan
Take my word,, I know - - - 1818 is weak over 5,000 and just spools a tad quicker
Old 11-04-2001, 12:36 AM   #12
Twelvz
Member#: 11302
11 GT-R
10.x @130+
Good...
Its definitly just a hiss... whine
I'm like a hypocondrac (sp?) when it somes to my cars !
Rob
Old 03-28-2002, 10:22 AM   #13
Motorush
Member#: 15415
Silver, KB SS, M2 Up.
Default more on hissing
what if the hissing sound became louder and irregular at full boost, almost like if the hissing was also flapping. I also hear my turbo spinning at steady highway speeds much luder than before this "irregular hissing" started. my wrx has spent 3 days at the dealer, and nothing, the sound is still there, not to mention the fact that I strongly believe I'm loosing power.
thanks.
Motorush is offline   Reply With Quote
Old 03-28-2002, 01:07 PM   #14
Evaider
Member#: 12896
02 Impreza WRX
Platinum Silver
Default Re: more on hissing
thanks.
Are you loosing power... or just getting use to the power you have? Hehe.. when I first got my WRX i was like woah this is so fast... now im like eh.. its ok. hehe. I want faster! faster! more power! sigh.. but I have no money.
Evaider is offline   Reply With Quote
Old 03-28-2002, 01:21 PM   #15
kurichan
Member#: 8282
2002 WRX Sedan
Check for leaks! It sounds like this happened when you removed your MBC. I'll bet a hose is loose.
kurichan is offline   Reply With Quote
Old 03-28-2002, 01:27 PM   #16
krave
Member#: 13908
2002 WRX Sedan
296 whp
Sounds like a good incentive for upgrdades
krave is offline   Reply With Quote
Old 03-28-2002, 01:38 PM   #17
Motorush
Member#: 15415
Default Re: Re: more on hissing
I know what you mean evaider, I really wish is was that but unfortunately I don't think this is the case. - thanks for the note though, it helps lighten-up the suffering.
kurichan, I'll keep doing that, thanks.
In a nutshell and thanks to all the input I've gathered from members of the i-club, this is what I'm going back to the dealer with:
PROBLEM DESCRIPTION
- Abnormal hissing noise (irregular and louder) under full boost (includes flapping sound).
- Experiencing less power overall, almost seems like wrx is now more engine, less turbo.
- Steady and now pronounced turbo whine at steady highway (70mph) speeds.
PROBABLE CAUSES
- Loose colector to up-pipe bolts.
- Bad EGT Sensor under turbo.
- Loose Ceramics in pre-turbo Cat.
- Compression loss.
- Air Intake System leakage.
- Hoses, connections, or manifold.
- Turbo blades bent, scraping the sides.
- Wastegate Valve problems.
- Solenoid problems.
- Gasket in the up-pipe to manifold flange leaking.
- Up-pipe catalist.
Let's see how this goes. Remember that my WRX is reading 1600 miles and is completely stock except for the kartboy sshifter and cusco bushings.
Thanks.
Old 03-28-2002, 03:28 PM   #18
nicktckhoo
Member#: 5836
2002 fake STi
silver and pink
loose uppipe dude.
I had the same problem. It is sorta a rattling like noise. Turbo whine doesn't sound bad. This sounds bad.
B4 you conclude turbo problems, I would just get underneath the car and check the uppipe. Don't dread it , just do it.
Cheers
Nick
nicktckhoo is offline   Reply With Quote
Old 03-28-2002, 11:01 PM   #19
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Default Double check your uppipe!
An uppipe leak can sound like the screach of a bad turbo. It's worth a second look. Check for signs of carbon build up around the center of the joint.
We have experienced this first hand while doing custom tunes.
Good luck and I hope it's your uppipe!
Phil
TurboXS
motoxphil is offline   Reply With Quote
Old 03-29-2002, 12:08 AM   #20
Sauceboy01
Member#: 13107
check your EGT probe on the up-pipe.. i'm experienceing that problems right now.. i looked at the pipe and the prope wasn't even there anymore.. (just hanging)
Sauceboy01 is offline   Reply With Quote
Old 03-29-2002, 09:22 AM   #21
WizardBlackWRX
Member#: 14979
I would say it is a loose uppipe. Think of it this way
flapping hiss: the leaking joint with a gasket oscillating like a reed on an instrument.
more engine than turbo: you are losing your air to the turbo to spool it and getting less overall.
steady and pronounced turbo whine: you have a leak close to the turbo to let more turbo sound escape to the environment.
WizardBlackWRX is offline   Reply With Quote
Old 03-29-2002, 10:04 AM   #22
Motorush
Member#: 15415
Default thank you
excellent feedback, thank you.
Old 04-04-2002, 09:01 PM   #23
Motorush
Member#: 15415
Thumbs up My WRX is Back!
Thanks to all for that feedback and special thanks to TAV Racing in Miami, FL. They did an awesome job! Got the Boost back! the flapping is gone! and an excellent cusco bushing (lock-tight and all) installation to boot.
Leaking gasket in the Uppipe-to-Manifold area , a couple of loose connectors.
To all in the South Florida area, keep this guys in mind, after 5 days and two Subaru Dealers, I can guarantee no one will take care of your WRX like these folks. A+ TAV Racing Website
Gabriel.
Old 04-05-2002, 03:10 PM   #24
WizardBlackWRX
Member#: 14979
Hey, just got my PC up and going again. Glad to hear it worked out with minimal $.
Happy Boosting
stock 07 sti - rear 02 sensor on its way out? Turbo9000 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-02-2009 05:45 PM
Tranny on its way out? Noise in first 04 WRX (NJ) Transmission (AT/MT) & Driveline 0 05-22-2009 01:21 AM
Suspension on its way out? Ekeenan86 Newbies & FAQs 5 04-09-2009 07:54 AM
Bad Detonation Still- Is my engine on its way out? JeffrWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-04-2006 01:29 PM
power steering on its way out? AJ711 Service & Maintenance 3 03-03-2005 05:23 PM
