Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 09-25-2006, 11:33 PM   #1
L80Killa87
Member#: 111910
02 WRX
Default Flashing cel with cel disabled.
I disabled my cel through the utec. I know the utec will flash the cel if somethin big happens. So I just got done with the fmic install today. Having trouble hitting target boost. Cranked on the aux boost controller but still having trouble. So I'm getting on a side road, open her up in second, shift into third still WOT, and then I get the flashing cel. Can anybody shed light on this subject?
L80Killa87 is offline   Reply With Quote
Old 09-25-2006, 11:41 PM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
That is knock.
2phless is offline   Reply With Quote
Old 09-25-2006, 11:48 PM   #3
L80Killa87
Member#: 111910
02 WRX
Eeeeeeeek! What should I do? Any clue why it happened?
Old 09-26-2006, 08:10 AM   #4
gpatmac
Member#: 18446
2002 WRX wagon
psm
Octane is too low.* Richen up your fuel or reduce timing. Reduce boost while you're at it and then when you've worked out your leanness issues, you can retune boost.
The CEL (when disabled) is now your 'knock light'. It'll flash when you knock. When you're tuning, immediately get off the gas when it flashes then open up your laptop and find in your log where you had instances of knock, locate that area in your fuel or timing maps and make those values less aggressive.
*I'm not saying you're not using high enough octane. What I'm saying is at that point where you're knocking, the octane didn't prevent the knock and so you have to manually reduce timing or increase the amount of gasoline in your mixture.
gpatmac is offline   Reply With Quote
Old 09-26-2006, 08:45 AM   #5
L80Killa87
Member#: 111910
02 WRX
Hmmmm interesting. Yeah cuz I'm using 93, unless I got a bad batch or something. Alright I'll give it a shot, thanks a bunch!
Old 09-26-2006, 10:36 AM   #6
gpatmac
Member#: 18446
2002 WRX wagon
psm
Just to clarify. Your gasoline octane is most likely ok. It's not, though, at that point on the rpm band/engine load where you happened to knock. In other words, gas ok, air to fuel ratio is not.
Old 09-26-2006, 01:01 PM   #7
L80Killa87
Member#: 111910
02 WRX
Ah ok. Well aem uego should be here in like a week. So once I get that i'll install her and run uteclogger and get the afr where they need to be.
Old 09-27-2006, 05:55 PM   #8
AREA1320
Member#: 112508
check your plugs as well.. we have been seeing instances of knock with crappy old plugs.
AREA1320 is offline   Reply With Quote
Old 09-27-2006, 06:11 PM   #9
L80Killa87
Member#: 111910
02 WRX
I'm running stock heat range iridium ix plugs that are only a few months old. Since I've been bumping up the horsepower lately and I see a 20g in my future I might upgrade to the colder heat range. Think this will help at all being a colder heat range?
Old 09-27-2006, 06:16 PM   #10
L80Killa87
Member#: 111910
02 WRX
Oh, for what its worth, it only started to do this AFTER the fmic install. And to add to the problems, it can't hold stable boost, i turned up the aux boost controller for the utec to compensate for more pressure loss. It won't hold stable boost now. maybe my solenoid is maxed out?
Old 09-27-2006, 08:30 PM   #11
hippy
Member#: 36528
2002 Impreza Wrx
maybe your bov is openning?
Old 09-27-2006, 10:15 PM   #12
L80Killa87
Member#: 111910
02 WRX
Its always worked fine before, its a modded stocker too, so it should work real good. ALSO, another added note. Getting on the car in first in second, yields no flashing cel (knock), but when I shift into 3rd and the boost builds up BINGO theres my knock. Any reason why this is?
Old 09-28-2006, 05:16 AM   #13
hippy
Member#: 36528
2002 Impreza Wrx
post a log
Old 09-28-2006, 08:41 AM   #14
L80Killa87
Member#: 111910
02 WRX
alright, you want a log of like first through third?
Old 09-28-2006, 05:42 PM   #15
hippy
Member#: 36528
2002 Impreza Wrx
Any log showing the fluctuating boost, and possibly the knock. A full gear pull would be good, and 3 gears would be better. Don't reck your car trying to recreate the problem though. I just figured you might have a log laying around.
peace
Old 09-28-2006, 06:39 PM   #16
L80Killa87
Member#: 111910
02 WRX
Nah, I can do a 1-3 or at least 2-3 log tonight, I'm gonna lift when I hit knock in 3rd though.
Help! CEL with CEL fix electricpork Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-31-2004 03:56 PM
CEL with flashing cruise light help needed Wombat North STi Forum Archive 3 07-05-2003 01:10 PM
flashing CEL with unichip OneArmedScissor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-09-2003 12:01 PM
flashing cel with utec, what could be causing it? datdudedennis Engine Management & Tuning 7 04-07-2003 05:16 PM
Flashing cel with Unichip TurismoLou Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-09-2002 12:08 PM
