Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 11-03-2001, 06:02 AM   #1
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
Default will the mrt turbo headers fit on my01 rs?
they are built for an ej20 motor i suppose....just curious if they would bolt right up to my ej25......i already did a search and no luck....so dont tell me to do a search
-akcel
ps heres a pic of the headers
akcel is offline   Reply With Quote
Old 11-03-2001, 06:07 AM   #2
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
You'll need a new crossmember for them to clear. Your cheapest option is a Legacy Turbo crossmember, then it should bolt right on.
Ben
bsquare is offline   Reply With Quote
Old 11-03-2001, 11:12 AM   #3
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
You'll also need to change the water pump. The thermostat on the RS hangs down too low to clear the turbo headers.
Impreza Rider is offline   Reply With Quote
Old 11-03-2001, 03:03 PM   #4
akcel
Member#: 10268
gc8 I ride ride 24s
thanks....where would i go to get those?? subaruparts.com?
-akcel
Old 11-03-2001, 04:05 PM   #5
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Yeah, I'm sure you could get a water pump for a turbo Legacy from subaruparts. Just beware that you should know what you're doing if you try to install the water pump yourself...it requires removing the timing belt/chain (whatever the Impreza has).
Old 11-03-2001, 04:33 PM   #6
akcel
Member#: 10268
gc8 I ride ride 24s
know of anyone who has done this??? and you said the cheapest way was to get a legacy crossmember....what would be the more expensive?? wrx?.....would it outperform the legacy?
-akcel
Old 11-03-2001, 05:07 PM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
adamsrs has a Legacy crossmember (as well as most of the Legacy turbo gear) in his Impreza.
Outperform a Legacy? Are you confused about what a crossmember is? Performance will depend on the turbo you run, how much boost, state of tune, etc., but not the crossmember, which is just a big hunk of metal to which the engine and suspension bolt.
Ben
Old 11-03-2001, 05:18 PM   #8
akcel
Member#: 10268
gc8 I ride ride 24s
Ben [/b]
gotcha....but he said "the cheaper way to go would be a legacy cross member" usually cheaper is ok....if u are being cheap about your setup or what not......just curious as to the other uncheap option. not saying that a legacy is cheap just saying what he said...lol something.......any hoot
-akcel
Old 11-03-2001, 07:31 PM   #9
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
legacy would work find and be cheep. better would be getting one made which would be very expensive. do keep in mind doing this would be very hard and not something that can be done in your garage. unless u have an engine life and air wrench
Old 11-03-2001, 10:17 PM   #10
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
blaster88 also has it done. That's how I know how much of a pain in the ass it is. You can do it without an engine lift, and without a garage either. PM blaster88 if you're really interested.
Old 11-03-2001, 11:21 PM   #11
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
You might also have problems with the upipe part of the header clearing the EJ25 block. There is different clearance on an EJ20.
Also you can go to http://www.nothingserious.net to find out more about the Legacy turbo setup. I am in the process of doing a Legacy turbo setup and am almost done.
scootr
scootr is offline   Reply With Quote
Old 11-04-2001, 04:19 AM   #12
bsquare
Member#: 1911
2000 Impreza 2.5RS
The Legacy part is cheaper than getting a WRX crossmember. Having a custom one made seems excessive. The crossmember is not exactly a high-performance part, it just sits there so other parts have a place to attach.
Could someone who has actually done this comment on the up-pipe clearance? I haven't heard of this problem before, and Cobb Tuning dropped an EJ25 block into a WRX, never mentioning piping clearance problems.
Ben
Old 11-04-2001, 04:41 AM   #13
bsquare
Member#: 1911
2000 Impreza 2.5RS
From Blaster88s site:
Spacer between the header and up-pipe (does not clear SOHC head otherwise)
So, you don't actually need to a modified up-pipe, just a spacer (dimensions of the spacer and info on hos the spacer relocated the turbo attach point would be useful).
[edit: spacer thickness is .75"...but why is a custom downpipe needed?]
Ben
Old 11-04-2001, 05:05 AM   #14
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
Yes, you just have to put a spacer there, but I am going to have one made because mine was broken. Also I was saying how those MRT headers were all one piece so the uppipe would be connected with no room to put a spacer.
Old 11-04-2001, 05:17 AM   #15
bsquare
Member#: 1911
2000 Impreza 2.5RS
Unless you have DOHC heads...finally, an advantage for the MY98 RS owners
Ben
Old 11-04-2001, 05:28 AM   #16
akcel
Member#: 10268
gc8 I ride ride 24s
so umm...for the my01's those headers wouldnt work out all that well since lack of spacer for the uppipe?
-akcel
Old 11-04-2001, 08:57 AM   #17
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Actually, Imprezer is the guy to ask on this - the geometry on this header is somewhat different than on the stock turbo header and up-pipe combo. He had this header on his GC8 which was, IIRC, a 99, which was a SOHC engine. Since this is one piece, there is no way to put a spacer between header and up-pipe. Also, it may not require the waterpump change the same way the stock one does. Alex didn't mention it, but I do recal he said he had to take a dremel tool to his head to grind off some interference.
You would have to get the Legacy turbo x-member, you'll have to hunt one down somewhere on here (I think shtboxracing on the club has one, too.) They are EXTREMELY hard to find right now. There were only 700 turbo Legacies in the US, a fair number of those are on the road, the wrecked ones are likely to break hte front end, including x-member. Try www.copartfinder.com (use requires registration now) and look for 91-94 Legacies.
blaster88 is offline   Reply With Quote
Will an EJ20 turbo header fit onto an EJ25? WRC1 Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-06-2004 03:48 PM
Will the WRX turbo back fit on a GC8 motor swap? suberboy Normally Aspirated with bolt-on Forced Induction Powertrain 13 04-20-2002 11:23 AM
Will the black bumper cover fit on a MY01 RS? jay25RS Interior & Exterior Modification 0 03-01-2002 06:37 AM
WIll a GC8 turbo kit fit on a 2002 RS? STiShawn Normally Aspirated with bolt-on Forced Induction Powertrain 8 12-14-2001 09:53 PM
Will the twin turbo EJ20 fit 91-94 Legacy turbo? jwooman Legacy Forum 5 05-02-2001 12:26 AM
