Old 11-03-2001, 10:47 AM   #1
tonytiger
Member#: 3844
1993 Legacy 1.8
Question Installing turbo? Need advice
I have an opportunity to buy an older EJ18's turbo and heads and other parts form an older ej18 engine. I'm wondering if the packet is going to fit to my present engine.
My car, Legacy 1.8, is 1993 model with no turbo (as you might guess). The engine i'm plannign to get the parts is from Leone 1989. So is it possible to fit the engine together?
Any information about the problems what I might encounter with the project?
Does ECU and ECM handle this.
Engine space problems?
What do I need for this project excluding the parts I can rip off from the old engine?
What about the emissions, does they increase a lot and what on what areas are they increasing e.g. CO2?
Finally - any guessess about the power increase
Maybe forgot something...
Thank you in advance for any information!
tony
tonytiger is offline   Reply With Quote
Old 11-04-2001, 03:26 PM   #2
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
You might the turbo crossmember from the type of car you are taking these things from.
Take it Sleezy
Graham
Graham is offline   Reply With Quote
Old 11-04-2001, 06:23 PM   #3
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Default Leone
The Leone has a EA81 engine not an EJ18. There is NOTHING in common with these engines. I dont think the exhaust are the same either. Are you sure your 93 Legacy has a 1.8L most came with a 2.2L. The engine code is stamped on the block under the alternator, check it out and let me know.
I just saw you are from Finland. Maybe this info wont apply.
Scoobie Steve is offline   Reply With Quote
Old 11-05-2001, 04:20 AM   #4
tonytiger
Member#: 3844
1993 Legacy 1.8
Cool
Scooby Steve: I have EJ18 in the heart of Subie. We have here in Finland Legacys with 1.8, 2.0, 2.2, 2.5 litre motors. Some you can have with turbos.
Anyhow, I'm afraid that you might be right with the Leone issue. That really ruins my project, if they have EA81 motors and it can be assumed it's the same around the world in Leones. I have to check out...
Thanks for the info...
... disappointed currently
No really - thanks!
tony
hoodscoop installation issues: need advice zer0_thirteen Mid Atlantic Impreza Club -- MAIC 6 01-12-2005 02:54 PM
Falkens installed backwards: Need advice lightbringer Brakes, Steering & Suspension 9 10-08-2002 02:28 PM
Problem with legacy turbo, need advice ralyrcr Legacy Forum 6 05-03-2002 05:40 PM
Found legacy turbo, need advice!! nd4spd Legacy Forum 2 09-16-2000 01:22 PM
Found Legacy Turbo!!, need advice on whether to buy!? nd4spd Legacy Forum 6 07-31-2000 04:43 PM
