Old 11-03-2001, 11:42 AM   #1
JustAnotherSquid
Member#: 11791
Default I'm an idiot (where's the oil filter?)
LOL. As we speak, the WRX is in my driveway, oil plug out, and old oil sitting in the pan (along with the drain plug - yes, I did drop it in there ).
So I go to take the old oil filter off and ... wha? Where's the oil filter?
Help.
JAS
JustAnotherSquid is offline   Reply With Quote
Old 11-03-2001, 11:51 AM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
It's within a foot of the oil plug on the passenger side of the engine.
supermarkus is offline   Reply With Quote
Old 11-03-2001, 11:51 AM   #3
tahrndt
Member#: 1315
Have you checked you glove box yet?
TIm
tahrndt is offline   Reply With Quote
Old 11-03-2001, 11:59 AM   #4
JustAnotherSquid
Member#: 11791
That was the first place I looked! But no dice. Then I checked the trunk, and damnit it wasn't there either.
I felt around in the area by the drain plug and did find it - but the oil filter is totally hidden from sight up under the front tray.
Part two of the Incredible Journey is that none of my four oil-filter wrenches fit the Subbie oil filter. Nothing is ever easy.
JAS
Old 11-03-2001, 03:58 PM   #5
Austin
Member#: 7089
2016 STi
Glad to see you've overcome this seemingly insurmountable task of locating the oil filter... teehehe j/k!
Austin is offline   Reply With Quote
Old 11-05-2001, 01:48 PM   #6
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
You should not need an oil filter wrench to loosen the Subie oil filter unless the grease monkey at the dealership over torqued the thing. You suppose to torque it in by hand, not with a wrench.
Richard
http://www.whitetyphoon.com/impreza/
Richard L. is offline   Reply With Quote
Old 11-05-2001, 02:02 PM   #7
jds
Member#: 7991
Yes, it's SUPPOSED to be hand-tight. However, when I did the first oil change in my sube, the factory filter was so tight I needed a belt wrench to get it off.
Maybe FHI hired Popeye to install filters on the line.
-Joe
jds is offline   Reply With Quote
Old 11-05-2001, 06:35 PM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Drive a screwdriver into the side of it and turn the filter with the screwdriver... you won't be reusing the oil filter after all .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
You and the Captain make it happen!
Old 11-05-2001, 09:12 PM   #9
Austin
Member#: 7089
2016 STi
I think they hired the Incredible Hulk... They *should* all be able to be loosened by hand, but my first change did require a monster size screwdriver to get that damn filter out.
Old 11-06-2001, 07:02 PM   #10
Audi RS4
Member#: 11560
1972 Datsun 510
Orange
Default tools, tools, tools...
yeah BIG screw driver or BIG channel locks... fun stuff! Hope you get it!
Audi RS4 is offline   Reply With Quote
Old 11-11-2001, 09:59 PM   #11
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
this tool has yet to fail to remove even the most stuborn filter in the 10+ years that I've had it.
Peaty
Peaty is offline   Reply With Quote
Old 11-11-2001, 10:10 PM   #12
Bradus
Member#: 10036
2008 Infiniti G35x
Volvo XC90-T6
-Joe
With the assistance of Hpirally - thanks Joe! - I learned how to change the oil on my WRX on Friday night. Like JDS, the oil filter on my car was so tight, we almost imagined we'd never get it off. We both spent several minutes a piece trying to twist it off.
I like Brian's suggestion about ramming a screwdriver into the old filter.
Anyway, the new filter - stock filter from Subaru - was hand tightened and shouldn't be nearly so difficult to remove 3000 miles from now.
David
Bradus is offline   Reply With Quote
Old 11-12-2001, 07:14 PM   #13
Austin
Member#: 7089
2016 STi
Peaty - where'd you get that? Seems like it'd be useful to have around.
Old 11-12-2001, 07:20 PM   #14
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I got mine from a NAPPA mine is a KD brand but there are other ones. I've seen them at the local AutoZone I think.
Old 11-12-2001, 07:23 PM   #15
Austin
Member#: 7089
2016 STi
Hmmm... I've never seen one... I'll have to go look. Thanks!
Old 12-09-2001, 09:55 PM   #16
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Cool
Just did my first oil change today, and fortunately I remembered this posting, it saved me from a lot of trouble! I actually used an awl because it was easier to get it into the filter. But they really must have godzilla tightening the filters at the factory, there's no way I could have gotten it off by hand. I regretted not investing in a filter wrench, but at that point the oil in the car was already drained.
My mechanical skills are not very highly developed, I probably set a record for the longest time anybody ever took for an oil change. While godzilla is tightening the oil filter, they must also have him tightening the drain plug. I only had a small open wrench, and I couldn't get it off with that, I was also afraid of stripping it using too much force. So I went to Sears and got myself a nice set of combination wrenches. The next challenge was getting the old crush washer off the plug, it took me quite a while to get it loose. Then came the oil filter saga...
Anyway, thanks to all the tips here, the operation ended up being successful! I'm glad I did it myself, even though I spent more time than expected, I'm sure I will be much faster next time. Some details: I used the standard jack to lift up the car on the drivers side, it got very tight with the large drain pan I bought otherwise. I filled with Valvoline 5W-30, will probably go with synthetic in a couple of oil changes.
Thanks again to everybody for sharing their wisdom with us mechanically challenged people.
TheWRX is offline   Reply With Quote
Old 12-10-2001, 03:03 PM   #17
Red-Impreza
Member#: 3884
Exclamation
Next time you're at Sears (and before you attempt to change your oil again), pick up a set of jack stands. It's not wise to lay under your car and yank on a wrench with just the factory scissor jack. I'd also recommend finding a mechanicaly enclined friend to help you develop those skills before getting in too deep next time.
Red-Impreza is offline   Reply With Quote
Old 12-10-2001, 05:15 PM   #18
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Thumbs up
For oil changes I like to use a set of Rino-Ramps rather than jack up the car and place jack stands under there. Just a suggestion. They also come in handy if you change the rear sway bar or do any minor exhaust work. But like Red-Imp says, it's really a bad idea to get under a car using the OEM jack. The good news is after removing the factory filter and drain plug the first time it's a lot easier after that.
Also if you don't have a performance guage pack with the Oil temp sending unit in the drain plug, get one of these to make the change go quicker with less mess (and no need for a new crush washer):
http://www.scoobymods.com/mods/impre...drainvalve.php
Peaty
Old 12-10-2001, 08:25 PM   #19
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I can change my oil & filter without the Rhino ramps!
PS the filter is covered up by the "plastic front undertray" on the WRX.
ANZAC_1915 is offline   Reply With Quote
Old 12-10-2001, 09:58 PM   #20
jhonas
Member#: 9015
2002 Impreza 2.5RS
Platinum Silver Metallic
I second the fumoto drain valve. I put it on after much hard work of undoing the drain plug and filter that was tight as all hell from the factory. I wonder how tight the other fluid drain plugs are...
jhonas is offline   Reply With Quote
Old 12-11-2001, 08:17 PM   #21
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
If that's the case then it is no longer the oil in the car, it's the oil out of the car. j/k
IMPREZive 02 WRX is offline   Reply With Quote
Old 12-12-2001, 04:47 PM   #22
Darwin
Member#: 2704
2001 Impreza 2.5 RS
Blue Ridge Pearl
Fumotovalve makes it easy! but you still get a mess when you remove the filter. =(
probably best to punch a hole in the filter and drain it before pulling it off.
anyway, you don't need to jack up ANYTHING to get everything changed in a subie.. as long as your arm fits under the nose. Even without a fumoto, it's one of the easiest oil changes out there.
Darwin is offline   Reply With Quote
Old 12-13-2001, 10:51 PM   #23
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
I didn't really lie under the car, I was still in front of it. I just lifted the car by a couple of inches (the tire was still slightly touching the ground) to give me more room and a better view to access the drain plug and oil filter. I did in fact get jack stands, and was planning to use them if I needed to lift the car more.
I took a car maintenance class a while ago, and had done an oil change on my previous car, it was only the first on the Subie.
It wasn't as bad as it might have sounded, it just took long. I prefer to do things slowly and carefully, I don't think I was in any danger of hurting myself or the car.
Old 12-19-2001, 06:42 PM   #24
jk147
Member#: 7621
you really don't need a jack to change the oil. I did it last time without lifting the car. Since the oil filter is right behind the bumper, I was able to just reach in and grab it. Really convenient.
jk147 is offline   Reply With Quote
From one problem to the next!!! I'm an idiot... subarustate Alaskan Impreza Club Forum -- AKIC 17 10-24-2007 05:17 AM
Locked my keys in the car this morning! I'm an idiot rant. 95sti Mid Atlantic Impreza Club -- MAIC 1 11-17-2006 08:50 AM
Help, I'm an idiot and new to the Intarnet The_Triton Off-Topic 19 09-03-2004 03:37 AM
where's the oil filter? markyrage Service & Maintenance 9 11-07-2003 10:23 PM
('93-'01) I'm an idiot or something is wrong. Joncas Impreza Forum 16 04-21-2001 08:36 AM
