North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC > NWIC Vendor Classifieds
Closed Thread
Old 09-26-2006, 05:43 PM   #1
Rallitek.com
Vendor Sales Rating: (15)
Member#: 34814
08 WRX
Lightning Red
Default Tire Pressure Monitoring System - TIRE SPY!!
Monitors tire temp as well!! Sale Price - $214.99
Extra sensors are also available as is a sensor for your spare, should you so choose.
Aftermarket tire pressure monitoring systems (TPMS) have been around for about 10 years, but they’re very expensive and offer very limited information. Recent technological developments have made the systems more affordable, as well as providing the driver with very detailed and accurate information.
Our TIRE SPY TPMS has a compact display that mounts at the top of the windshield on Volvo models and provides you with real-time tire pressure and temperature of all four tires. The system automatically cycles through all four tires about four times every minute. The flashing tire on the display indicates which tire is currently being monitored. The system comes with pre-set high and low pressure and temperature limits and you can select metric or SAE units. You can also set your own activation limits. When the system senses a problem, you’ll get both an audible and visual alert with specific details on the tire that is out of spec. When you rotate your tires, the system allows re-configuration through the sensor exchange mode, a simple selection on the display. By purchasing an additional sensor, you can also monitor the condition of your spare tire (available below). If you run different sets of wheels and tires (winter/summer) you can purchase a spare set of 4 sensors so that the system will function with either set of tires (also available below). Once installed and set up, the system functions automatically and doesn’t require any user input to function and provide continuous real-time monitoring for the ultimate in safety and convenience.
Installation is straightforward. The display uses a mounting bracket that adheres to the windshield and the display snaps to the bracket so you can easily remove it to make changes in your settings when needed. Simple three-wire connection to a constant 12-volt source, a switched 12-volt source and a chassis ground, all of which can be accessed in the driver’s cockpit area.
Rallitek.com is offline
Closed Thread
Get rid of this - Subaru tire pressure monitoring system Mooneyes13 General Community 93 11-09-2008 10:59 AM
Tire Pressure Monitor System, got one? Bbasso Tire & Wheel 16 09-15-2008 06:03 PM
I hate tire pressure monitoring systems!!!!! DJRob72983 Off-Topic 74 12-23-2006 05:15 PM
Tire Pressure Monitoring Systems Safe Drives Wheels/Tires 45 09-25-2006 12:17 PM
Tire pressure monitoring systems out there.. Undepelo Tire & Wheel 4 12-21-2004 01:11 PM
