Old 11-03-2001, 02:38 PM   #1
Scooby75
Member#: 11885
2007 Impreza WRX STi
Obsidian Black Pearl
Default higher redline
I have a turbo 2000 2.5 and REALLY need to get some more high end power. The Low end is crucial but that 62000rpm limiter has got to go. Turbo spools at 2 grand so i've got power, just need the higher RPMs to teach some of the hondas a lesson on the highway. Anyone know someone that can take the redline to 7000 ro 7500RPM or so? I don't know if its just an ECU replacement or new valve train or both.
Scooby75 is offline   Reply With Quote
Old 11-03-2001, 04:10 PM   #2
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
You'll need an aftermarket ECU such as the Tec II.
The stock valvetrain starts to float at about 7200-7400 RPM (IIRC), so if you planned on revving that high, valve springs may be in order.
I just noticed this, but what's wrong with your car...you should be able to go like 100 miles an hour in first with that fuel cut
Impreza Rider is offline   Reply With Quote
Old 11-03-2001, 04:11 PM   #3
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Both. The stock valvetrain is not up to the task of 7500rpm, especially with boost. Valve float is not your friend.
Ben
bsquare is offline   Reply With Quote
Old 11-03-2001, 04:23 PM   #4
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Plus your cam will not make any power that high. If you look at our torque/hp curve, the power starts to dip off way before that (regardless of turbo or NA). If you shift higher, your next gear that you go into will ALSO be above the power curve and you will get even worse performance. Stick with what you have right now and if you want to go higher, get some cams and get some better springs
Eric
Eric SS is offline   Reply With Quote
Old 11-03-2001, 07:37 PM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
valve timing, perfectly balanced rods n pistons, cams, wallet deeper then the grand canon
Old 11-03-2001, 08:14 PM   #6
kaos200
Member#: 2692
trust me, power up top without a turbo is weak!
But with a turbo... OMG
get some engine work done (rods or just ARPs) some springs and retainers will help.
and as people have already mentioned engine management is a must
Kian
kaos200 is offline   Reply With Quote
Old 11-03-2001, 08:15 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I noticed the same dropoff with my turbo over 6,000
Eric
Old 11-04-2001, 01:24 AM   #8
XT6Wagon
Member#: 524
04 STi
I doubt very much that you need to touch the bottom end to hit 7,500-8K. Above that I might start to worry. The top end DOES need work as the springs are too soft and the cams are too small.
I doubt that it would be very expensive to build even a 9 or 10K rpm EJ-25, but the cost goes up alot as you push closer and closer to the theoretical limits of the motor. Which if you do a little math is higher than ANY non-hybrid Honda B-series. I'd guess that a B18C with a B16 crank might be about equal to the EJ-25. Please note that a shorter stroked EJ-22 will run with the best of them, and I don't have the specs but I'd guess the EJ-16 and EJ-18 might have even shorter strokes.
XT6Wagon is offline   Reply With Quote
Old 11-04-2001, 01:34 AM   #9
RS-LOVER
Member#: 4463
2000 Impreza RS
Blue Ridge Pearl
You ever heard the saying "If it ain't broken dont fix it" That might be your best bet right now. Just my .02 cents
RS-LOVER is offline   Reply With Quote
Old 11-04-2001, 03:33 AM   #10
Scooby75
Member#: 11885
LOL yeah I noticed the 62000 thing right as I hit post reply, DOH!!! (hand slap).
Old 11-04-2001, 03:38 AM   #11
Scooby75
Member#: 11885
Don't worry, I wasn't thinking about doing it any time soon. Hell I was just curious to see if it could be done. I'm planning on getting the Cobb Tuning turbo cams within the next month or two, (paycheck pending). So I'm gonna be one step there. Don't really need the high RPM for autoX and Solo 1 and 2 racing though, which is what I really wanna get into. Gonne be tough on a daily driver, but oh well, gotta do what you love right?
Old 11-04-2001, 12:17 PM   #12
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Depending on how they layout the Solo 2 course in your area, you might want the higher redline. When I was N/A I would come pretty close to having to shift into 3rd on a lot of our courses. Now that I am turbo, I know I will have to if I don't raise the redline
Eric
Old 11-05-2001, 02:34 AM   #13
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
is ignition timing going to be a concern at these rpms? what mgmt would someone use.... I was going to bump up my hybrid because the EJ22T block had a higher redline but i thought against it,,, since it was too much trouble... especially since i'm running piggys...
HOK is offline   Reply With Quote
Old 11-05-2001, 03:09 AM   #14
bsquare
Member#: 1911
2000 Impreza 2.5RS
See the first reply in this thread that suggests a TEC-II (obviously, other high quality standalone systems will work, as well).
Ben
Old 11-05-2001, 05:01 AM   #15
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Yes... i appreciate that the TEC 2 will solve all problems... but i'm seeing if the stock crank sensor can handle this.. ie... just using piggy backs or the stock ignition system and a unichip to change timing... since the TEC2 comes with a high res crank sensor its an easy answer... but with its cost involved i was just wondering if the stock on can handle it... and also what are the timing maps like on the stock ECU after the rev limit?
Old 11-05-2001, 03:32 PM   #16
Danny5
The Emperor Protects
Member#: 13
2014 Chevy Cruze
Diesel
Speaking from my limited experience...
People that have over-reved their engines have usually blown the motor. Granted, the cases I have heard of were boosted cars, but this *could* be indicative of lack of maps at higher revolution levels.
Irregardless, there are some factors limiting high rev performance in the 2.5 motor. I have taken the first step in my car, and have installed better valve springs. Stronger valve springs will keep your valves from floating at higher rpm and boost levels, keeping your air mixture true to cam profile.
But the cam itself is a limiting factor. The cam will run out of steam at 6800 to 7000rpm, depending upon other modifications. In my friend's car, where his rev limit is 7k rpm, but has no other rev increasing mods, he runs out of go at about 6750 and you don't really get any benefits from reving past that. In my car with knife edged crank and stronger springs, I can go to 7k rpm before it becomes pointless.
The question you need to ask is how much is enough, and how much do you want to spend? Springs aren't cheap. Cams aren't cheap. Aftermarket ECUs aren't cheap. Its a vicious cycle that is funded by your dwindling disposable income.
I guess this begs the question of why you need more revs. IIRC, top speed in 5th gear at 6200rpm is 140mph! If you need to go faster than this, then I want to know where so I can avoid that road! If it's a track, then try a road course that is tighter. If its a drag strip, then you won't hit those speeds until you break into the 9s anyway. Good luck to you in your quest!
-Danny
Danny5 is offline   Reply With Quote
Old 11-05-2001, 05:10 PM   #17
bsquare
Member#: 1911
2000 Impreza 2.5RS
Irregardless? Ow.
Old 11-05-2001, 05:47 PM   #18
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
yup DannyAtwork thats what i thought... no point in doing all that for 800 rpm...
Old 11-06-2001, 12:58 AM   #19
Scooby75
Member#: 11885
Well like I said, I wasn't gonna actually do it. Just wondering if it could be done. I just get mad at the Honda owning idiots who brag about being able to take their cars to 8000rpm. Course with a boosted Impreza if you start a race anywhere below 100mph you will walk the dog on just about anything (I have an S2000 stamped on my fender). But I've heard that you can take the car to 8000rpm with an STi Version 5 or 6 ECU and injectors, since they go that high stock. Just one more rumor I suppose. Thanks a bunch.
09 WRX redline... 6,500?? Higher?? stickjohnsonaah Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 07-16-2009 02:46 PM
higher redline mannyOlicious Built Motor Discussion 14 11-14-2008 03:34 PM
higher redline White 2.5rs Normally Aspirated with bolt-on Forced Induction Powertrain 17 09-24-2003 06:33 PM
Higher redline FloridaWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-12-2002 12:01 AM
higher redline madmax1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 11-02-2001 08:39 PM
