Old 11-03-2001, 03:00 PM   #1
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default Cold winter morning...
...I noticed in the morning when I start my car that it starts up/idles rough...but after a few miles (everything circulates) its fine...is it time for winter maintenance...if so, what's on top of everyone's list???
Thanks for the tip(s),
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 11-04-2001, 12:35 AM   #2
Jademonkey
Member#: 9213
2000 RS
Red
Are your fluids synthetic...that helps with "cold starts"????
Jademonkey is offline   Reply With Quote
Old 11-04-2001, 08:37 PM   #3
Loki
Member#: 4543
2003 WRX
Do you let the car warm up at all? You don't need to wait 5 minutes ... but I always give my car at least 30 second of idle in the morning. sometimes about 2 minutes if it is cold.
If I don't let it warm up, just start and go, it makes a clicking sound for about a minute. Kinda strange
When you start your car, does the choke hold the RPM at about 1500? maybe your choke isn't working for some reason, and the car is struggling with the low idle speed of most of our subies.
~Loki
Loki is offline   Reply With Quote
Old 11-04-2001, 10:31 PM   #4
FastPorsche
Member#: 11125
2000 Impreza 2.5 RS
Silverthorne
The cold is back. You may consider some service for car if due by miles. FYI I have a 2000 RS and have only been trough one winter with it but two things that happened last year when it was cold out. First thing I noticed that the car like yours will run rough and hunt for idel speed when firts started. Then (most likly when it gose into closed loop) after a shot time it idels up alittle and runs fine. The other thing that happened twice both on VeryVERY cold Michigan mornigs, my car stalled almost imediately after start up. It had less that 4000 miles at the time and I attribute it to the extremly cold temprature that the enigen managment system dose not understand. However this summer I did remove a spark plug to see what they looked like. When I saw they were Champion brand I quickly discarded them and installed some NGK's. My experience has shown that Jap cars run really good on NGK's, German cars run really good on Bosch plugs, and lawn mowers will run on Champions. Since I replaced the plugs my car idels smooother all the time not just in the cold. Just my $0.02 hope I didnt bore you.
FastPorsche is offline   Reply With Quote
Old 11-05-2001, 12:10 AM   #5
HomerJay
Member#: 1135
2005 WRX WAGON
I switch to 5w-30 Mobil 1 during the winter. I don't live in cold weather but I drive up to the local ski area all the time. I always like to warm up my engine and let the fluid circulate. As far as winterizing your car goes, change wiper fluid to the deicing kind, make sure you have enough coolant/antifreeze( change it if you haven't in 2 years) Changing plugs isn't part of it, but it always helps. Also, you might want to get an engine warmer if you live in a particularly cold area. Oh yeah, check your battery. You can check your hoses also, but since you have newer car, it probably won't be an issue.
HomerJay is offline   Reply With Quote
Old 11-05-2001, 10:29 AM   #6
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Well, since you're having a cold start idling condition, I would check/replace plugs, wires, and filters if you haven't done those. Also, clean the battery terminals.
tmat3 is offline   Reply With Quote
Old 11-05-2001, 09:06 PM   #7
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Damn Ken! it aint that cold here yet!
Rudy
jagcars26 is offline   Reply With Quote
Old 11-05-2001, 11:02 PM   #8
steve_d
Member#: 315
I hear ya jag....
What are these guys talking about??? it was 72 and sunny again today....
sjd
Nomex on...I used to live in Michigan...glad I'm gone.
steve_d is offline   Reply With Quote
Old 11-06-2001, 07:45 PM   #9
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
A CHOKE? LMFAO! your car most deifinantly does not have a choke... those went out about the same time Jimmy Hoffa did...
seriously though, fuel injected cars do not have chokes, and the idle speed on your Sub is controlled directly by the pcm. still LMFAO
yamarocket630 is offline   Reply With Quote
Old 11-06-2001, 10:45 PM   #10
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
actually... I've seen some throttle body injection cars with fuses suggesting an auto choke... eh, whatev... this is me having no nicotine and 2 hours of sleep
SoobATV is offline   Reply With Quote
Will the stock battery work during the freezing cold winter? driver Electrical & Lighting 18 12-21-2004 09:24 AM
A little help please with starting on a cold Indy Morn... mdcmotorsports Mid West Subaru Owners Club Forum -- MWSOC 16 12-07-2004 10:09 AM
umm brake light went on when it was cold this morning. bosozoku Electrical & Lighting 10 01-10-2004 03:57 PM
Cold Winter Cloths (I'm talking 0* and below) Need Advice.. WRXedUSA Off-Topic 37 01-04-2004 10:49 PM
New car break-in-period during freezing cold winter months...? driver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-13-2003 08:01 AM
