Old 09-27-2006, 06:14 AM   #1
zephyr451
Member#: 2456
2007 Outback XT
Default Subaru Factory Nav.
We just took delivery of our '07 Outback XT w/Nav. Has anyone figured out how to hack the system such that you can change/add destinations while moving. Currently Subaru disables the most of the Nav functions when the vehicle starts to move. While this is very clever, it's also completely annoying.
TIA,
-Michael
zephyr451 is offline   Reply With Quote
Old 09-27-2006, 08:56 PM   #2
rallysquirrel
Member#: 7006
2007 SpecB
I'm wondering the same thing.
I'd like to see the boost gauge and EGT instead of the fuel gauges.
rallysquirrel is offline   Reply With Quote
Old 09-27-2006, 11:56 PM   #3
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
do you know the manufacturer of the unit?
pioneer, clarion, etc? that might help lead into more insights of how to bypass it.
we install the Ford factory navs and 6 disc units at work and they are all built by pioneer.
also does it block route entering only when out of park? or could you be stopped and have it in D and it still work?
thedaddyb is offline   Reply With Quote
Old 10-02-2006, 02:29 PM   #4
elduderino11
Member#: 75464
'05 WRX sedan Stg 2
2.3L CGM, Harman Tuned
Don't know if this will help, but my buddy recently got the pioneer unit installed in his duramax and had the issue with not being able to make changes whilst moving. His fix was to simply cut a wire going to the parking break. Not sure which wire it was and if it will even help you, but simple google search will bring up a number of nav hacking sites...good luck!
elduderino11 is offline   Reply With Quote
Old 10-02-2006, 04:25 PM   #5
elsanto
Member#: 34832
1989 M3
try pulling up the parking brake one click.. if this works then you can try that.. cut the sendor on the parking brake. or just run around with it pulled up.. id loosen the cable though first so you dont drag them till they are worn down.
elsanto is offline   Reply With Quote
Old 10-02-2006, 05:59 PM   #6
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
worst idea ever.
if the unit does actually intergrate through the parking brake lead, it will intergrate at somepoint throughout the car. find that point and disconnect it and ground it.
Old 10-02-2006, 06:05 PM   #7
2mprzya
Member#: 34053
2003 WRX
Black Bugeye
is there a sequence you have to do (brake pedal, ebrake, pedal, brake) ? if so, simple grounding it will not work. you would have to get a switch to ground so you could flip it on/off. you could try ebay, as they have an interface for the dvd player units that work the same way.
2mprzya is offline   Reply With Quote
Old 10-02-2006, 06:19 PM   #8
AnnapolisSubaruSales
Member#: 125091
It is a Kenwood unit, if that helps at all...
AnnapolisSubaruSales is offline   Reply With Quote
Old 10-02-2006, 07:14 PM   #9
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
that does help, how does the unit actually work though?
do you have to engage the parking brake to enter in a new route?
if so then it would be a simple grounding solution.
does the car have to be in park?
if so it probably ties into the transmission sensor switch (or neutral safety switch)
if you can enter it whenever the car is stopped and not moving it is either based on speed sense or an internal gyro. making it very difficult to bypass. pioneer units have many tricks to bypass those features, but a kenwood I'm not too sure on.
Old 10-02-2006, 10:08 PM   #10
4EVO2NV
Member#: 51692
04 STi JBP
Enginuity Tuned
there will be a wire on the back of the radio that detects the parking brake is on. all you will have to do is remove this wire from its circuit and connect it to ground. This would work as long as the gps does not use any type of gyro sensors.
4EVO2NV is offline   Reply With Quote
Old 10-03-2006, 01:26 PM   #11
Member#: 125091
It doesn't care about the parking brake for entering a destination. If you're at a stop light, car is in drive, brake pedal is down, you can change/enter the destination. You can even do it coasting slightly to a stop.
So, that says to me speed sensor.
Again, hope it helps.
Old 10-03-2006, 02:24 PM   #12
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
aggreed. sounds like the speed sense wire to me as well.
Not much you can do in this situation. If you disconnect it, the gps will loose it's accuracy. You could wire it up to a switch where if you flick it on it temporarily to cut the connection to the VSS. Then you could run into other issues if it grounds out and shorts the unit, your gauges, or even ecu.
better off looking for a software hack or maybe some other internal way to bypass it.
Old 10-03-2006, 03:43 PM   #13
LastResort
Member#: 99289
Actually, it sounds like GPS to me. It would be able to know that you are not at exactly zero speed with VSS, but any calculations that use GPS location would have a time constant built in. That will be even tougher to break. Though this is ALL a guess.
LastResort is offline   Reply With Quote
Can 09 G37s w/o factory nav be outfitted with factory nav?? SBPhilly Off-Topic 13 02-02-2010 02:59 AM
Factory Nav vs. Aftermarket - please help me decie sbkim Car Audio, Video & Security 8 12-30-2008 11:45 AM
factory nav AFTER the fact? zmw Car Audio, Video & Security 0 11-30-2008 12:09 PM
Is the factory Nav worth getting? ScoobyDaddy Newbies & FAQs 11 04-29-2008 11:39 AM
Factory Nav Question dvon1981 Car Audio, Video & Security 45 11-15-2007 09:49 PM
