Old 11-03-2001, 06:22 PM   #1
FormerSubTech
Member#: 11913
2000 Forester
Default cobb intake vs. Ganzflow with optional 3" inlet
have there been any flowbench or dyno comparisons between these two options?
it seems that the cobb air filter would have less surface than the OEM filterin the picture alone. furthermore, punching out the inlet of the stock (MAP) air box to 3" seems to accomplish the same thing as the entire cobb intake.
FormerSubTech is offline   Reply With Quote
Old 11-03-2001, 08:09 PM   #2
FormerSubTech
Member#: 11913
2000 Forester
the compass intake seems like a good option as well.
Old 11-04-2001, 03:50 AM   #3
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
I would think the straight pipe of the COBB would create much better airflow, no?
Old 11-04-2001, 06:07 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the airflow pattern of the Cobb Intake is MUCH smoother at Higher RPM. IF you combine their CAI with their street cams you have an AWESOME package.
jeremy
Old 11-04-2001, 05:14 PM   #5
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
actually... the surface area of the PRM filter(the cobb intake filter) is actually probably larger than the OEM filter, it's just arranged differently. It's a cone filter and if you cut open a cone filter and lay it out next to a panel filter, the cone is larger... I'm just guessing, but I would assume the PRM would be the same... also the design of the PRM has better flow than a panel and the rest of the Cobb filter maximizes the flow even more
mrbell is offline   Reply With Quote
Old 11-05-2001, 12:03 PM   #6
auricom
Member#: 3088
'01 2.5 RS
i just put my ganzflow on 2 days ago, was not as easy of an install as i thought but so far so good. decent sound not as loud as i hoped but it is just an intake so i shouldn't expect too much.
auricom is offline   Reply With Quote
Old 11-06-2001, 02:51 AM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
It's all a mater of how much you want to spend. I still go by the slogan, "GanzFlow, The best bang for the buck"
I have a PRM here in my hands, and it does not look to have the surface area of the panel filter.
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 11-06-2001, 02:52 AM   #8
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
PS: If you look at www.imprezars.com/shoppingcart.htm you'll see I do sell the Cobb too, just in case you can't decide
Larry
Old 11-06-2001, 12:36 PM   #9
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Use an intake that KEEPS the factory airbox in place. It adds throttle response and low-end torque. Also, keeping the air filter close to the throttle body helps to straighten out the air before it enters the throttle body. This improves air flow...
subarumantoo is offline   Reply With Quote
Old 11-06-2001, 01:16 PM   #10
jwainwri
Member#: 7805
I am pretty sure Cobb has shown that they don't loose low end power. Pluse the stock panel filter is a large rectangle and the throttle body a smaller circle so the air is not straightened out no matter what K&N says.
The real deciding factor is cost. I will probably end up getting the ganzflow because I already have the K&N panel filter. I don't think the gains from the Cobb would justify the added cost. Even their own web site says you need to change the cams before big gains can be had by the intake.
jwainwri is offline   Reply With Quote
Old 11-07-2001, 04:05 AM   #11
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
Definatly, if you already have the drop in filter, get the ganzflow.
SR30 to SR56 with sr57 3" inlet housing 03SuBbYWrX Factory 2.0L Turbo Powertrain 1 06-26-2007 03:17 AM
COBB CAI vs GANZFLOW Yebisu69 Normally Aspirated Powertrain 25 10-23-2003 01:57 PM
COBB Intake vs. Weapon-R Intake DoodieHead Normally Aspirated Powertrain 39 11-03-2001 03:57 AM
Is it worth it? Cobb PRM $270 Intake VS Ganzflow? triXXXter Normally Aspirated Powertrain 37 07-22-2001 09:27 AM
('93-'01) 1/4 mile w/cobb intake vs. JC intake, proof scootr Impreza Forum 15 05-11-2001 08:26 PM
Message Board Statistics All times are GMT -4. The time now is 04:39 AM.
