Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 09-27-2006, 06:52 PM   #1
civichunter2
Member#: 70150
2004 WRX
Black 4eat
Default help wiring up gauges where the clock use to be
im about to install 3 gauges and a pod there where the clock was and as far as gettin power to them should i cut the harness off the clock and wire them in that? i here some people cut the clock plug and get air bag lights and the radio stops workin ,i have a 04 not sure if that is just with the 06's or all. any help would be great
civichunter2 is offline   Reply With Quote
Old 09-27-2006, 07:35 PM   #2
ILSMKU2
Member#: 77908
2011 E92 ///M3
RIP 11, 09, 06, 03 STI's
No, dont cut any wires or harness off. Just buy some vampire clips and tap into the 12v line. As far as I know, the 06's you cant remove the clock. Im told you have to remove the clock from the plastic housing, and set it aside UNDER your new gauges. That way its out of the way and still works as designed. You just wont see it.
Not sure if 04 is same way. Regardless, just use vampire clips.
ILSMKU2 is offline   Reply With Quote
Old 09-27-2006, 07:46 PM   #3
civichunter2
Member#: 70150
2004 WRX
Black 4eat
so if i install my gauges and leave the plug harness just hangin under my gauges no connected think il have any trouble?
Old 09-27-2006, 08:00 PM   #4
ILSMKU2
Member#: 77908
2011 E92 ///M3
Does your show the ABS status next to your clock? IF YES, then remove clock from plastic housing and put it down in the hole WITH power wires connected to it.
If you dont have ABS light next to your clock, then you should be able to unplug it and tap into the plug you just removed from the clock.
Old 09-27-2006, 08:11 PM   #5
civichunter2
Member#: 70150
2004 WRX
Black 4eat
ive never seen a abs light so i take it i dont im just scared to tap in to it and open a can of worms so i might just run the wires to a diffrent source and keep the plug free in case i have trouble.
Old 09-27-2006, 08:31 PM   #6
ILSMKU2
Member#: 77908
2011 E92 ///M3
Dude, its easy. If you dont got an abs light up there (which is ALWAYS on) then your fine. Look at the back of the clock, you will see which wire does what. It should clearly show you that on the back of the clock. Tap into whatever wire you need.
Old 09-27-2006, 08:53 PM   #7
civichunter2
Member#: 70150
2004 WRX
Black 4eat
ok thanks
Old 09-28-2006, 06:59 PM   #8
ILSMKU2
Member#: 77908
2011 E92 ///M3
Did you figure it out?
Old 09-28-2006, 08:01 PM   #9
civichunter2
Member#: 70150
2004 WRX
Black 4eat
yea i did it a few min ago all good cept my old cheap boost gauge is alittle off like when the key is off its just barley on 0 so it reads alittle off so il need to get a newone other wise it all worked out thanks for the help.
Old 09-28-2006, 08:52 PM   #10
ILSMKU2
Member#: 77908
2011 E92 ///M3
My stock one was never in the same place when I turned my car off.
Old 09-29-2006, 01:38 AM   #11
DinoGuan
Member#: 42233
04 WRX waGGon
Hmm, I just cliped all the wires off the back of the connector to the clock, and solderd my gauges in, and taped off any stray wires. No problems,, yet. I have an 04, no airbag light.
DinoGuan is offline   Reply With Quote
Old 09-29-2006, 01:58 AM   #12
ILSMKU2
Member#: 77908
2011 E92 ///M3
You removed the harness?
Old 10-02-2006, 05:29 PM   #13
civichunter2
Member#: 70150
2004 WRX
Black 4eat
yea i just took a u shaped spade clip cut one side off the U and put it in the stock harness works very good and didnt have to cut the harness
Old 10-02-2006, 05:32 PM   #14
ILSMKU2
Member#: 77908
2011 E92 ///M3
^^^ Right on!
Does the clock have to be hooked up for your radio to work? nrowensby Interior & Exterior Modification 16 10-20-2009 01:05 PM
How do you wire up gauges in a clock pod fastlanerex Electrical & Lighting 0 02-23-2008 04:25 PM
Gauges where the AC/heater knobs used to be oldhat Interior & Exterior Modification 3 11-08-2006 07:35 AM
Welding metallic cat where TXS cat used to be... gooder77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-23-2006 01:59 PM
