09-27-2006, 09:19 PM | #1 |
Member#: 123924
SWIC
Vehicle:2002 WRX WRB |
Vishnu Xede plugin...car runs like crap!
Hey everyone,
Ok so a couple weeks ago I hooked up my Vishnu Xede. At the time I didn't have my laptop. So I drove it around for a couple days before I was able to get my laptop and a serial cable for it. I went to Vishnu's website, downloaded the Xede tuning software and downloaded the Stage01 91Octane map and loaded it up on the Xede. Went to the Xede Information option in the software and it reads out "Current Map: Stage01 91Octane. ...well, ok i guess that means it worked. My god my car runs like crap. No check engine light on so that was good. Untill from a stop I punch it. At like 4,000rpm my boost like ENDS and then kicks back on again. The second the car does that quick LAG spike in the boost my Check Engine light flashes on. 2nd gear seems to have NO guts anymore either Do i possibly have a boost leak? Its like when I get to a certain boost pressure it kicks off?? DOES ANYONE KNOW WHAT THE HELL DO I SHOULD DO!?!?!
09-28-2006, 09:17 AM | #2 |
Member#: 123924
SWIC
anyone?
09-28-2006, 01:48 PM | #3 |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
If it ran fine before you loaded the Stage 1 map, then something is wrong with the way you loaded the map or the map file itself.
Try loading a blank map and see if the car behaves normally again. |
09-28-2006, 02:12 PM | #4 |
Member#: 123924
SWIC
when it rains my car runs like crap | toulakid | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 11-15-2006 02:20 AM |
car running like crap | alptekin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 11-11-2004 08:01 PM |
Need help: just got 02 and CEL makes the car run like crap | 17cTSi | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 05-26-2004 07:22 PM |
HELP...car running like crap... | Samirr76 | Tri-State Area Forum | 22 | 03-26-2003 04:59 PM |
Anybody's car run like crap after... | Tokay | Normally Aspirated Powertrain | 1 | 07-17-2002 10:32 PM |
